The Highscore Rankings
Postby ska » 2011.01.19 (08:25)
You should count all the top 20 59-0 0ths. As TFK says, just because some levels are easier to max out than others, we shouldn't discount the tied runs just because they were made later. Where do we draw the line? 5-2 took me and I'm sure clux and I know it took Hendor hours just to get that elusive score.
Postby TheRealOne » 2011.01.19 (15:54)
ska wrote:You should count all the top 20 59-0 0ths. As TFK says, just because some levels are easier to max out than others, we shouldn't discount the tied runs just because they were made later. Where do we draw the line? 5-2 took me and I'm sure clux and I know it took Hendor hours just to get that elusive score.
I am fine with this. It is the right thing to do and it is what would be accurate. Plus it won't be that much extra work. I only have to add one to JF's count since I only do the top20 0th holders. However if we get more hackers soon I will have to add 1 to seifer's and trib4l's counts.
Postby TheRealOne » 2011.01.25 (04:54)
- As of 01/24/11
- Includes Tied 0ths
New 0th Report
20-1 - Old: [vankusss, 139.375] New: [Last_FairyTail, 139.525] => [EddyMataGallos, 139.575] => [Last_FairyTail, 139.725]
50-0 - Old: [vankusss, 164.400] New: [Last_FairyTail, 164.500] => [vankusss, 164.550] => [Last_FairyTail, 164.625]
64-3 - Old: [xaelar, 107.300] New: [vankusss, 107.325]
64-4 - Old: [vankusss, 349.525] New: [vankusss, 249.600] => [vankusss, 351.525]
Total 0th Rankings
0 vankusss - 173
1 xaelar - 166
2 eru_bahagon - 73
3 Mr_Lim - 60
4 golfkid - 19
5 lookatthis - 18
6 Ben_Schultz_11 - 17
7 Izzy - 16
8 Seifer - 15
9 macrohenry - 10
10 Kool-aid - 7
- Hendor - 7
- Analu - 7
13 clux - 6
14 EddyMataGallos - 5
- ToeFaceKiller - 5
16 The_TGM_Project - 4
- Meta_Ing - 4
- Darkshadow1416 - 4
- johnny_faneca - 4
Level 0th Rankings
0 vankusss - 161
1 xaelar - 155
2 Mr_Lim - 51
3 eru_bahagon - 20
4 Ben_Schultz_11 - 17
5 Izzy - 16
6 lookatthis - 15
- Seifer - 15
8 golfkid - 12
9 macrohenry - 10
10 Kool-aid - 7
11 clux - 6
12 EddyMataGallos - 5
- ToeFaceKiller - 5
- Hendor - 5
- Analu - 5
- Meta_Ing - 4
- johnny_faneca - 4
Top-20 Rankings
0 eru_bahagon - 554
1 lookatthis - 550
2 xaelar - 533
3 Mr_Lim - 490
4 Hendor - 369
5 vankusss - 329
6 golfkid - 320
7 ToeFaceKiller - 301
8 Analu - 290
9 Ben_Schultz_11 - 264
10 glib_jase - 253
11 johnny_faneca - 245
12 EddyMataGallos - 174
13 Darkshadow1416 - 165
14 Izzy - 147
15 Chouse - 142
16 trib4lmaniac - 121
17 macrohenry - 119
18 jg9000 - 108
19 zapkt - 99
Community Total Level Score
Seconds - 71800.950
Hours - 19.945
Seconds left until 20 hours - 199.050
Frames left until 20 hours - 7962
This week Last_FairyTail came out swinging taking both 20-1 and 50-0. The mystery player took 20-1 by quite some time adding a chimney to the run. Eddy capitalized on this route taking the 0th by 2 frame only to lose it when FairyTail improved by another 6 frames. FairyTail also held van at bay on 50-0 after taking it twice from him this week. Vankusss had some fun of his own this week getting owange on Ep64. Van took -3 by a frame with major route change. He also took -4 by 3 frames only to later change the route and save almost 2 seconds. The community went +2.600 seconds in total level score this week bring it up to 71.8k meaning there is less than 200 seconds left until 20 hours.
Postby TheRealOne » 2011.01.31 (18:39)
- As of 01/31/11
New 0th Report
07-2 - Old: [xaelar, 135.100] New: [vankusss, 135.475] => [vankusss, 135.675]
10-0 - Old: [The_TGM_Project, 118.100] New: [EddyMataGallos, 118.125]
91-2 - Old: [zj820, 146.975] New: [vankusss, 147.475] => [EddyMataGallos, 148.325]
91-4 - Old: [7aMaDX, 270.350] New: [TWA_MATO_Titan, 270.775]
Total 0th Rankings
0 vankusss - 174
1 xaelar - 164
2 eru_bahagon - 73
3 Mr_Lim - 60
4 golfkid - 19
5 lookatthis - 18
7 Seifer - 15
- Izzy - 15
9 macrohenry - 10
10 Kool-aid - 7
- EddyMataGallos - 7
- Hendor - 7
- Analu - 7
14 clux - 6
15 ToeFaceKiller - 5
16 Meta_Ing - 4
- johnny_faneca - 4
19 trib4lmaniac - 3
- glib_jase - 3
- The_TGM_Project - 3
- Last_FairyTail - 3
Level 0th Rankings
0 vankusss - 162
1 xaelar - 153
2 Mr_Lim - 51
3 eru_bahagon - 20
5 lookatthis - 15
- Seifer - 15
- Izzy - 15
8 golfkid - 12
9 macrohenry - 10
10 Kool-aid - 7
12 clux - 6
13 ToeFaceKiller - 5
- Hendor - 5
- Analu - 5
16 Meta_Ing - 4
- johnny_faneca - 4
19 trib4lmaniac - 3
- glib_jase - 3
Top-20 Rankings
0 eru_bahagon - 554
1 lookatthis - 550
2 xaelar - 532
3 Mr_Lim - 490
4 Hendor - 369
5 vankusss - 330
6 golfkid - 320
8 Analu - 289
10 glib_jase - 252
11 johnny_faneca - 244
12 EddyMataGallos - 182
14 Izzy - 147
15 Chouse - 142
17 macrohenry - 119
18 jg9000 - 108
19 zapkt - 99
Seconds - 71803.325
Hours - 19.945
Seconds left until 20 hours - 196.675
Frames left until 20 hours - 7867
This week began with Eddy breaking up a 4 way tie on 10-0 besting TGM's run by a frame; a run which has stood for several years now. Van wanted to break up xaelar's Ep owange on Ep7. He succeeded on 7-2 using a small innovation and a much cleaner run. He then improved his 0th for to extend his lead over half a second. Van also took 91-2 from zj, leaving zj with only 9-0 left for 0ths. Van took the 0th using the obvious corner jump innovation after the exit switch. he took the 0th by half a second, but only until Eddy set his sights on the 0th. Eddy put his chimneying abilities to the test and succeeded by taking the 0th from van by almost a full second. Eddy has also shown promise as he climbs up the 0th rankings he will most likely break in to the top-10 next week. There was action in the extended competition on 91-4. The map infamous for being held by several different players none of which are involved in the community. TWA came out with a great run taking the 0th by .425 using the skipped gold route. Will this bullet dodging parade of a map ever be owned by the community? who knows. This week the community went +2.375 seconds in total level score.
Postby vankusss » 2011.02.01 (00:01)
Thx for both rankings + reports. Nice reading as always :P
Anyone up for 9-0?
Postby krusch » 2011.02.01 (00:42)
Props to Eddy!
Postby TheRealOne » 2011.02.01 (02:22)
vankusss wrote:Thx for both rankings + reports. Nice reading as always :P
Anyone up for 9-0?
Thanks van. I edited the rankings because I messed up JF's rank since he gets +1 from 59-0. Also for 9-0 I was watching that run for a while when I was posting the rankings and I think that there is definitely a better route/innovations to be done. I will keep looking around and try and come up with something concrete.
Postby EddyMataGallos » 2011.02.03 (20:51)
entwilight wrote:Props to Eddy!
Thanks =D
I've been busy with school this week, I hope I'll have time this weekend to try to go for another 0th.
Postby TheRealOne » 2011.02.07 (18:29)
- As of 02/07/11
New 0th Report
96-3 - Old: [xaelar, 103.350] New: [EddyMataGallos, 103.625] => [vankusss, 103.950] => [EddyMataGallos, 104.000] => [EddyMataGallos, 104.125]
Total 0th Rankings
0 vankusss - 174
1 xaelar - 163
2 eru_bahagon - 73
3 Mr_Lim - 60
4 golfkid - 19
5 lookatthis - 18
7 Seifer - 15
- Izzy - 15
9 macrohenry - 10
10 EddyMataGallos - 8
11 Kool-aid - 7
- Hendor - 7
- Analu - 7
14 clux - 6
16 Meta_Ing - 4
- johnny_faneca - 4
19 trib4lmaniac - 3
- glib_jase - 3
Level 0th Rankings
0 vankusss - 162
1 xaelar - 152
2 Mr_Lim - 51
3 eru_bahagon - 20
5 lookatthis - 15
- Seifer - 15
- Izzy - 15
8 golfkid - 12
9 macrohenry - 10
11 Kool-aid - 7
12 clux - 6
- Hendor - 5
- Analu - 5
16 Meta_Ing - 4
- johnny_faneca - 4
19 trib4lmaniac - 3
- glib_jase - 3
Top-20 Rankings
0 eru_bahagon - 549
1 lookatthis - 548
2 xaelar - 532
3 Mr_Lim - 487
4 Hendor - 356
5 vankusss - 326
6 golfkid - 310
7 ToeFaceKiller - 280
8 Analu - 276
9 Ben_Schultz_11 - 260
10 johnny_faneca - 237
11 glib_jase - 218
12 EddyMataGallos - 175
13 Darkshadow1416 - 155
14 Izzy - 144
15 Chouse - 136
16 macrohenry - 117
17 trib4lmaniac - 115
18 jg9000 - 99
19 zapkt - 94
Seconds - 71804.100
Hours - 19.946
Seconds left until 20 hours - 195.900
Frames left until 20 hours - 7836
A very slow week from our highscorers. There was only one level competed on, 96-3. Eddy took down xela's long standing 0th by .275 using crappi's e tile double at the bottom of the first column. However, van immediately improved upon Eddy's run by skipping the double jumps up top and shaved off 13 frames. After some goading from van and myself Eddy beat van by 2 more frames bringing the 0th up to 104 seconds. After that he improved once more taking down crappitrash by a frame. This 0th bumped Eddy in to the top-10 for the first time his highscoring career. In other news because of a new hacker "Bradsta4" the top-20 rankings have taken another hit. Eru now only as a 1 top-20 lead over LAT. This week van and Eddy improved the community total level score by +0.775 seconds.
Postby vankusss » 2011.02.07 (19:07)
TheRealOne wrote:A very slow week from our highscorers.
Yea, THEY quite failed this time.
thx for report :P
Postby eru_bahagon » 2011.02.07 (19:20)
I've just updated my nhigh file and funny fact :
No more legit 0th because a hacker has 598 top 20.
I'll secure some top 20 this week. I don't want LAT to pass me. :p
PS : i still have 549 top 20 and only 15 non top 10 scores. It seems secure... but even a top 10 is not secure nowadays.
Postby EddyMataGallos » 2011.02.07 (19:54)
Thanks for the rankings :)
Postby vankusss » 2011.02.08 (18:18)
EddyMataGallos wrote:Thanks for the rankings :)
Well, for the
Postby EddyMataGallos » 2011.02.08 (19:13)
Well, for the
For the what?
Postby TheRealOne » 2011.02.09 (01:31)
Well, for the
For the what?
For the well.
Postby ToeFaceKiller » 2011.02.09 (07:02)
vankusss wrote: Well, for the
For the what?
For the well.
Fare thee well!
Postby Raif » 2011.02.09 (11:49)
For the what?
For the well.
The well!
Postby EddyMataGallos » 2011.02.09 (13:48)
mohamedraif wrote:
TheRealOne wrote:Image
For the well.
The well!
Haha great photo, I hope his desire gets conceded.
Postby TheRealOne » 2011.02.15 (03:21)
- As of 02/14/11
New 0th Report
21-1 - Old: [xaelar, 126.875] New: [EddyMataGallos, 126.900] => [ToeFaceKiller, 127.200] => [EddyMataGallos, 127.250] => [EddyMataGallos, 127.375]
27-2 - Old: [golfkid, 113.550] New: [EddyMataGallos, 113.625] => [EddyMataGallos, 113.675] => [vankusss, 113.800] => [EddyMataGallos, 113.825] => [Last_FairyTail, 113.850] => [EddyMataGallos, 113.875] => [Last_FairyTail, 113.900]
97-0 - Old: [Hendor, 99.575] New: [Last_FairyTail, 99.600] => [Last_FairyTail, 100.775]
97-2 - Old: [xaelar, 150.850] New: [EddyMataGallos, 150.925] => [vankusss, 151.100] => [EddyMataGallos, 152.400]
Total 0th Rankings
0 vankusss - 174
1 xaelar - 161
2 eru_bahagon - 73
3 Mr_Lim - 60
4 lookatthis - 18
- golfkid - 18
7 Seifer - 15
- Izzy - 15
9 EddyMataGallos - 11
10 macrohenry - 10
11 Kool-aid - 7
- Analu - 7
13 clux - 6
- Hendor - 6
- Last_FairyTail - 5
17 Meta_Ing - 4
- johnny_faneca - 4
Level 0th Rankings
0 vankusss - 162
1 xaelar - 150
2 Mr_Lim - 51
3 eru_bahagon - 20
5 lookatthis - 15
- Seifer - 15
- Izzy - 15
8 EddyMataGallos - 11
- golfkid - 11
10 macrohenry - 10
11 Kool-aid - 7
12 clux - 6
- Analu - 5
16 Meta_Ing - 4
- Hendor - 4
- johnny_faneca - 4
Top-20 Rankings
0 eru_bahagon - 552
1 lookatthis - 548
2 xaelar - 532
3 Mr_Lim - 486
4 Hendor - 355
5 vankusss - 326
6 golfkid - 309
7 ToeFaceKiller - 281
8 Analu - 275
9 Ben_Schultz_11 - 259
10 johnny_faneca - 236
11 glib_jase - 217
14 Izzy - 144
15 Chouse - 134
16 macrohenry - 116
18 jg9000 - 97
19 zapkt - 94
Seconds - 71807.225
Hours - 19.946
Seconds left until 20 hours - 192.775
Frames left until 20 hours - 7711
This week we saw the return of competition. Eddy sparked it all off with 0ths on 21-1, 27-2, and 97-2. On 21-1 Eddy used hitting the final 8 tile higher up to snag a frame from xaelar. TFK jumped in right after that cleaning the whole run, but Eddy wouldn't stand for this and improved twice more, shaving half a second off the original 0th. Raif MDBed a new route for 27-2 beating golfs run by about .400 seconds. Eddy took advantage of this taking the 0th and improving once, but van grabbed it from him by 5 frames. Eddy managed to take it back by a frame, but this is when Last_FairyTail jumped to the mix. A frame war began with FairyTail beating Eddy by a frame, this happened twice until FairyTail ended up 1 frame short of Raif's MDB. Eddy proved it was possible to get the extra golds on 97-2, but took the 0th with out it. Van in an effort to encourage Eddy, he took the 0th from him. After a few days Eddy did succeed in taking one of the extra gold. FairyTail also took 97-0 from Hendor, one of the longer standing 0ths on the board. Soon after he used a variant of the route van and I came up with, and had two great drone dodges beating Hendor's original 0th by 1.200 seconds.
Postby ska » 2011.02.15 (11:52)
TheRealOne wrote: The rundown will be up in a bit. I need to do something for like an hour it will be up then.
Are we working on Jupiter time or something?
Postby TheRealOne » 2011.02.15 (23:23)
Sorry, my bad shit came up last night. But the rundown is up now. Great work van, Eddy, FairyTail, and TFK for your 0ths last week.
Postby vankusss » 2011.02.16 (16:33)
TheRealOne wrote:Sorry, my bad shit came up last night. But the rundown is up now. Great work van, Eddy, FairyTail, and TFK for your 0ths last week.
Like, you weren't able to make it to the toilet and the shit just delivered itself?
Thx for report (though i didn't have anything from the cake at the end of the week, not that it matters, just saying).
Waiting for 10+ changes weeks when eddy aims at me or something.
Postby EddyMataGallos » 2011.02.16 (16:44)
Thanks for the rankings TRO :)
Also thanks for the encouragement van ;D
Postby ska » 2011.02.17 (01:49)
shittttt... Eddy has almost caught me!
Postby EddyMataGallos » 2011.02.21 (22:50)
Thanks for the encouragement ska :)
