One Life Challenge: Revival
Postby vankusss » 2011.06.14 (16:57)
999_Springs wrote:I'm meant to be the best in the world at Ep33 and I can't one-life it... fail.
Why?
Postby 999_Springs » 2011.06.15 (18:53)
Why?
Because one of the secret unwritten rules of taking metanet episode 0ths is that you have to do the entire episode in 1 life. If you don't, then although you still become the rightful owner of 0th, the God of N will haunt you and make your head triangular shaped for the next two weeks afterwards unless you lose the 0th. I did that with my Ep15. [/sarcasm]
Anyway, 34-4 and I died by forgetting that there was a time limit.
edit: 35-0 >_>
Postby vankusss » 2011.06.15 (19:19)
999_Springs wrote:Because one of the secret unwritten rules of taking metanet episode 0ths is that you have to do the entire episode in 1 life. If you don't, then although you still become the rightful owner of 0th, the God of N will haunt you and make your head triangular shaped for the next two weeks afterwards unless you lose the 0th. I did that with my Ep15. [/sarcasm]
But how does that unwritten rule make you being meant to be best at ep33? Do you hold 0th there or... (as a matter of fact, I can check that, brb) ... Nvm.
PS: As a sign of a goodwill I omitted the parse error.
Postby ari22hoops » 2011.06.24 (17:43)
aerodynamic wrote:
ari22hoops wrote: I'll work on extending that record for you though.
aha, nice
Ok then. I present 9-0. I don't think I'll be topping that anytime soon.
