Post a Run!
215091 hs <- my map, please rate/comment too if you can :D
Taken both hs and srdaricque wrote:205142 hs
- Member
- NUMA Profile: http://nmaps.net/user/Tacit
(also, my first 0th run)
EDIT: obviously this map isn't hard if you run back to the right at the start. That isn't the point. Try completing it while just holding left from the start.
Yup thank you. So if anyone has some luck beating that while only hold left from the start. Let me know or post it on the map. I am quite interested in this trick/glitchska wrote:the link you posted was the same as the featured. I assume you meant this: http://www.nmaps.net/215471
- Member
- NUMA Profile: http://nmaps.net/user/Arctic_Pony
^sig by Izzy
Taken by 61 frames. :PMiBeM wrote:8369 speed. For some reason I'm really proud of that one.
you.. got... POWNED999_Springs wrote:Taken by 61 frames. :PMiBeM wrote:8369 speed. For some reason I'm really proud of that one.
- MBTI Type: ESFP
2255 speed
2259 speed/hs
2261 speed/hs
Pretty sure 2255 is improvable by 1 frame.
You can see it on scosglenn's run (3rd on highscore, 8th on speedrun). If you watch the replay you can control the ninja after it reaches the exit.golf wrote:Had an interesting variation on the invincibility glitch when playing 2259. I completed the level, but I got launched up and left by the spring. Was able to run along the top of the normal doors, and the springs then didn't affect me afterwards. I think its because I hit the exit on the same frame as the launchpad. Unfortunately I couldn't get a replay to show.
- On the Psychic Highway
Beat you, Golf. :)
- MBTI Type: ESFP
Taken. I held jump for too long, could have been 5 frames faster.amomentlikethis wrote:215856 hs/sr :D
71 frames :Dmohamedraif wrote:Taken. I held jump for too long, could have been 5 frames faster.amomentlikethis wrote:215856 hs/sr :D
- MBTI Type: ESFP
:D
