Post a Run!
Postby ska » 2011.09.29 (00:12)
EddyMataGallos wrote:Im not posting this because its a great run, but because it contains a rare oneway glitch most people know, but nobody know why.
Yes, im talking about that one, in the run that glitch happened to me from a different height of what im used to, so i decided to post it here in case anyone can figure out whats going on with this glitch, its appears at the end obviously.
From what I remember, it's to do with the velocity of the ninja. When the ninja hits the one-way platform at a certain velocity, the stopping nature of the one-way platform is negated and allows the ninja to pass through.
Postby EddyMataGallos » 2011.09.29 (12:38)
So there are different speeds that can cause the ninja to fall through the one-way, interesting
Postby TheRealOne » 2011.09.29 (13:59)
EddyMataGallos wrote:So there are different speeds that can cause the ninja to fall through the one-way, interesting
It is a very strange glitch. Sometime you land on the oneway for 1 frame then fall through, so you can actually jump to prevent your self from falling through, Other times you fall through with out standing on the one way. It works for many different y coordinates, the x coordinate does not matter. Also the distance is not the key to this because not all y values are equal for some reason. Example: If you are on a oneway with y=200 and fall to one with a y=266 you will fall through, but if you are on a oneway at y=300 and you fall to one with y=366 you will not. Both are 66 pixels apart, but only the first works. Also the top oneway in these examples can just be where the ninja's feet are.
I made this map a long time ago to test some of these examples, here is it is to play around on with a demo of me showing what you can and can't do.
Postby EddyMataGallos » 2011.09.29 (15:10)
Yeah i remember playing that map a year ago or so, very cool glitch
Postby TheRealOne » 2011.09.29 (18:43)
Here is another example of this glitch and how you can jump when you spend two frames on the oneway before falling through.
Postby MiBeM » 2011.10.11 (12:23)
44-2 speed, it's a 0th :)
a.k.a. MoleTrooper/Molenator
Speedruns and stuff
Postby ska » 2011.10.12 (08:43)
MiBeM wrote:44-2 speed, it's a 0th :)
not anymore! ;)
In the words of Steve Jobs: "Think Different."
Postby MiBeM » 2011.10.12 (11:47)
not anymore! ;)
Now I'm sad. Good run, though :)
Speedruns and stuff
Postby TheRealOne » 2011.10.13 (20:58)
Think further outside the box
Ignore my pathetic run and imminent death, but you get the idea, don't use the LPs like Mibem, and don't get the lowest door because you can fall an get the switch under the door.
Postby ska » 2011.10.13 (23:31)
Yeah, I thought about that, but honestly, that's just cheating ;)
Postby MiBeM » 2011.10.14 (05:10)
I thought about it too, but then I decided that I don't have enough patience.
Speedruns and stuff
Postby MiBeM » 2011.10.15 (08:12)
Beat Kool by one frame in 47-4 speed :)
Speedruns and stuff
NUMA Profile: http://nmaps.net/user/Fdaniel
Postby Fdaniel » 2011.10.17 (22:50)
160-1 - HS
Postby 999_Springs » 2011.10.17 (23:23)
Fdaniel wrote:160-1 - HS
Hi Fdan, welcome to the forum... are you SURE you've got bored of the underclock boards now? Really? ;)
Postby Fdaniel » 2011.10.18 (00:42)
No records to beat anymore /:
But I´m still highscoring on the underclock boards, of course (:
Postby ska » 2011.10.18 (12:13)
Continuing the theme of 160, I took 160-3 hs with a drone close call and cheeky corner jump :P
Postby Fdaniel » 2011.10.18 (14:19)
160-4
and:
2-1, 2-4 and 3-0 - underclock mode; because I like these three runs, especially 3-0 <3
Postby golf » 2011.10.18 (17:23)
Fdan, what setting of underclock do you play on? I find that when I use it to train myself for a trick I'm trying out in a level I use about -30.
Postby Fdaniel » 2011.10.18 (18:16)
I usually play with -80, sometimes -60.
217642 - HS
Postby vankusss » 2011.10.18 (18:35)
Fdaniel wrote:No records to beat anymore /:
I don't think there were any records at all, just some people trying the feature out.
I really hope you'll just forget that whole mode and start doing the ONLY REAL MODE, THE HIGHSCORE ONE. SCREW YOU SPEEDRUNNERS AHAHAHAHA!
Postby Fdaniel » 2011.10.18 (18:40)
@vankusss
Yes, I started a few days ago ;)
Postby EddyMataGallos » 2011.10.18 (19:20)
Two funny facts:
Fact nº 1: Even with 941 0ths, you're still an hour away from xaelar's total level score.
Fact nº 2: Even with 941 0ths, you've only got 8 episode ownages o.O, i was waiting to see an huge list, and only 8 episodes appeared.
Postby Fdaniel » 2011.10.18 (19:44)
@Eddy
1. Yeah, I´m still working on my Total Level score ;)
2. You will see a huge list, soon, my son (I hope ;), I didn´t really cared about those Episode Ownages yet, but I will try to go for some in the future.
Edit:
just took 141 - 0
Postby EddyMataGallos » 2011.10.18 (20:04)
Fdaniel wrote:@Eddy
Edit:
just took 141 - 0
Yeah, the fact is that I find strange that since you own most levels, it seems you left a 0th on each episode or something :D
Postby Fdaniel » 2011.10.18 (20:15)
Fdaniel wrote:@Eddy
Edit:
just took 141 - 0
Yeah, That´s the way it is, gonna change that, though. ;)
