The Epic4ever Megathread!
- Almost as Bad as One
999_Springs, I just got up to 188-4 today. It is such a pain. And it took me 4 days straight to beat MTI; didn't turn my computer off to stay on the damned level.
- Richard Richards
- NUMA Profile: http://nmaps.net/user/Fdaniel
I knew I´m not the only one!
Same thing, happened to me, son. http://forum.droni.es/viewtopic.php?f=45&t=8998
Our .sol file probably got wiped. But the weird thing is that it happened to both of us in a very tight period of time.
@Unreality
- Richard Richards
- Demon Fisherman
Fdan: Did you try what I suggested in the other topic? Search for your .sol file in its correct location, right-click and select "Restore previous versions". Does that help at all?
- Richard Richards
- Richard Richards
- Richard Richards
But if you're having trouble, I suggest that you play in in practice mode.
- Richard Richards
- Richard Richards
Thanks to zoasBE for dedicating this full episode to me!:  00-0 00-100-2 00-3 00-4
- Richard Richards
Its Location
Windows Vista, 7:
Windows 2000, XP:
Windows 95, Me:
To be able to see the files:
Go to Control Panel > Folder Options > View.Select the option to show hidden files or folders.
A simple way to find your .sol file is to use the Search program. Search for All Files and Folders. Type in .sol in the first box. Before engaging the search, drop down to More Advanced Options and be sure that "Search system folders", "Search hidden files and folders", and "Search subfolders" are checked.
Mac OS 9:
Mac OS X;
- Richard Richards
- Richard Richards
Usually the .sol file gets deleted by antivirus software, etc as well as by NReality errors, or bad computer switch-offs (like unplugging it and things like that) so its a good idea to have a backup in another folder where it, i assure you, wont be deleted.
- Richard Richards
- Donator
