Postby vankusss » 2012.09.01 (12:23)
golf wrote:I don't think you can use my trick on the left side, because you need to be coming at the bb from the side with a decent speed, and not from above. Otherwise a very good route, I agree it probably is able to be Analu's time.
As I said, I did that trick once on the left side, and now I can do it pretty consistently, too (the key is holding 'left' during the jump). Anyway, this is the new 0th route: (this was my first try skipping top left gold jump on the block, so I dunno how exactly the drones can move after)
Postby ska » 2012.09.18 (16:31)
so.. I was improving my episode 87 score, and in the process, improved my 87-1 run to 2nd. there are a few major improvements; some of which i think could be used to take the 0th, especially the ending.
Postby golf » 2012.09.18 (20:36)
That does look like some pretty good improvements there ska. I noticed you improved that episode, its one I'm going to do at some point after I get on 63.
Postby EddyMataGallos » 2012.09.18 (21:21)
Those are some frickin' sweet innovs ska, Im sure 0th can be attained with them, definitely gonna try those out soon :D
Postby ska » 2012.09.19 (16:35)
EddyMataGallos wrote:Those are some frickin' sweet innovs ska, Im sure 0th can be attained with them, definitely gonna try those out soon :D
gracias, hermano!
buena suerte!!
Postby vankusss » 2012.09.22 (12:41)
60-2, dunno if faster, but cooler :D
Postby ska » 2012.09.22 (13:46)
vankusss wrote:60-2, dunno if faster, but cooler :D
Nice... If you got a better kick off the thwump, I think you could pinch it.
Postby glib_jase » 2012.10.25 (18:29)
60-4, variation of the "old" high scoring route:
If you can sneak in between those 2 bottom mines on the right then collecting that gold should be very fast and you should be able to beat the drone coming back over the top. The CJ can take you through the gap in the mines above but at that angle and speed (along with the drone hampering you) you end up slowing back down and no better than the standard "old" route.
Postby vankusss » 2012.10.25 (18:52)
glib_jase wrote:60-4, variation of the "old" high scoring route:
THE question is, will it be faster? The best time i see on the boards using the old route, is 124.225, almost 2 seconds behind Izzy. Does beating the drone at top gain you 2 seconds?
As for that 60-2, i tied 0th with it a while ago, so it's definitely faster. I would have probably taken it if I'd let go jump few frames sooner. (i have no idea what times i used in this sentence)
Postby ska » 2012.10.26 (06:08)
Confirmed. I released a few frames earlier and managed 96.900 on 60-2 which can be seen in underclock mode. BTW, where's that "cheated runs inclusive" excel file with the absolute fastest score recorded for each level? I'd be interested to update that if someone can hook me up...
Postby Raif » 2012.10.26 (16:24)
ska wrote:Confirmed. I released a few frames earlier and managed 96.900 on 60-2 which can be seen in underclock mode. BTW, where's that "cheated runs inclusive" excel file with the absolute fastest score recorded for each level? I'd be interested to update that if someone can hook me up...
Here is the file. I haven't updated it for like 6 months; so you have quite a bit of work if you want to update it.
HS 0ths.xlsx
(60.91 KiB) Downloaded 275 times
Postby ska » 2012.10.27 (06:43)
Thanks. Are all your MBD's current? That would be a great start if they are all current. If not, could you please update just those? Then, I'll update all the legit 0ths, underclock etc.
I'm just curious like the rest of the community, of how close to 72k we are if legitimacy is not a restriction...
Postby Raif » 2012.10.27 (06:53)
ska wrote:Thanks. Are all your MBD's current? That would be a great start if they are all current. If not, could you please update just those? Then, I'll update all the legit 0ths, underclock etc.
Yeah my MBD's should be updated.
As for your other question the total level score is already 72163.075 without even updating the realtime column.
Postby ska » 2012.10.27 (11:03)
wow.. nice. thought that would be the case, but not that much!
Postby EddyMataGallos » 2012.10.27 (12:01)
Thats awesome ;)
Postby glib_jase » 2012.10.28 (11:52)
I think it would be faster. The problem with the old route is that once you reach the drones at the top left they are in the wrong position to be able to get the exit switch quickly. Beating that drone on the right SHOULD let you nip in and out for the exit switch.
On an unrelated note, has anyone got N working well on Windows 8 yet? I haven't spent much time on it but just switching to XP compatibility mode doesn't seem to help, it still lags like a biatch.
Postby ska » 2012.10.29 (00:26)
XP FTW!
Postby darkshadow » 2012.11.13 (22:32)
Ok guys. Time for a totally impractical, only slightly faster, but extremely cool route change (it also probably doesn't work because you catch the thwumps coming down on the way back). 60-2 thwump corner jump.
Edit: And a more practical one for 181-4
Unreality's awesome mod
Postby EddyMataGallos » 2012.11.13 (23:39)
Hey dark, nice to see you around ^^
Postby darkshadow » 2012.11.14 (04:17)
Thanks Eddy. You are now untouchable by the way. Seriously. I can not believe the runs I've been seeing out of you. Keep it up.
Edit: Just noticed people were posting about a thwump kick route for 60-2 above. What a weird coincidence.
Postby Izzy » 2012.11.14 (06:24)
yay dark.
Also, OP edited because whatever.
Postby darkshadow » 2012.11.14 (20:58)
Came up during a discussion on irc with kool. The only possible route change I see left in 40-2. I'm not sure the red version is possible but if so is probably easier than the green one.
Edit: Also this should be a little faster on 25-4 sr:
Postby EddyMataGallos » 2013.02.07 (20:31)
Hey guys, Im trying to figure out if its possible to beat the last drone in 26-3. I beat a middle drone with an innov already, but doesnt seem to be enough:
Another possibility would be this, although I doubt its doable:
Probably not enough lead (comparing with swips recent 0th). Im the ninja:
Postby macrohenry » 2013.02.07 (21:20)
Do you think doing a double jump using the slope and hitting the ceiling would work?
Postby EddyMataGallos » 2013.02.07 (21:25)
Yeah I tried that, but I couldnt beat the drone :/ I think there must be a change on the middle, or you will never be able to beat the drone.
