MULTI-THEME MADNESS!!!
NUMA Profile: http://www.nmaps.net/user/RedSpartan
Postby Leonidas » 2013.01.21 (20:03)
*Slightly inspired by PARADIGM SHIFT II
Here is how it works...
-We start off with 1 theme, and 1 anti-theme. The anti-theme is something that you can not do.
-Players submit maps based on theme and anti-theme.
-After 5 maps are submitted, the current judge/theme-adder picks the best, most-fitting map for that theme.
-The chosen person becomes the current judge/theme-adder, and adds another theme. The anti-theme does not change! The previous judge becomes normal again, and can now submit a map for the next round.
-The themes keep adding on until there are too many, lets say 5 for series 1.
-Try to start off with a very broad theme, like "simple" or something, because remember: the themes will keep adding on, and making the maps narrower and narrower in theme. I will pick the anti-theme. If I am unavailable, continue using the anti-theme from the previous series.
-Once there are too many themes, like said above, all judges/theme-adders get prizes.
-The game then resets with a new series
Also, I can will usually submit an example map for each round to give an idea!
Q&A
Can I submit a map if I am the judge? Of course not.
What happens when I become judge? You have become judge because your map has been chosen by the previous judge. Pick a theme and it will be added on to the previous themes. After 5 more maps are posted, pick a map that is the best and best matches all the themes, and doesn't break the anti-theme.
I don't get the anti-themeIt is basically the opposite of a theme. It is something that you can NOT do in the current series. Like if the anti-theme is "Gold" then you can NOT place gold in your map. The anti-theme applies to the current series.
When can I join this contest?Anytime! Unlike other competitions like Apt, there is not a specific set of people involved. You join whenever you want, it doesn't have to be in a certain round.
Can I submit a map in multiple rounds?No, you can only submit a map to one round. Also, it is recommended to make the map after viewing this competition, instead of using a previously made one.
What happens if I submit a map after 5 maps have been submitted for the round?Unfortunately, it is disqualified. This is the one exception where you can submit it for another round, since it has never been judged.
I will start off as the judge/current theme-adder.
***Make sure to look at theme list below!
[align=center]SERIES 1
Anti-Theme: More Than One Floorguard (You can use 1 floorguard, or none)
Theme 1: Simple (A map that is simple in gameplay and idea)
Theme 2: Action-Packed (A map with a ton of action, maybe rockets or turrets)
Theme 3: One-Way Fun (Add some fun one-ways)
Theme 4:
Theme 5:[/align]
Click!!!
From Streetsahead
From Aidiera
Also from Aidiera
From Traveleravi
Postby Leonidas » 2013.01.21 (22:15)
Here is an example for round 1, series 1. It matches all current themes (simple) and does not break the anti-theme of more than 1 floorguard. Actually, it has NO floorguards.
http://paste.droni.es/f0b73768f0496da8f58a6c01
Click!!!
From Streetsahead
From Aidiera
Also from Aidiera
From Traveleravi
NUMA Profile: www.nmaps.net/user/Vanquish
Postby Vanquish » 2013.01.21 (23:36)
i like the idea, im in. how long do we have to post a map?
anyway, ill post the map later today. i like the idea of this, and it sounds pretty fun :D
These Go Up to 11
NUMA Profile: http://nmaps.net/user/StreetsAhead
Postby StreetsAhead » 2013.01.22 (03:29)
I really like this contest! I may be awful at making actions, but I'll still enter. Here you go: http://www.nmaps.net/225671
That guy who sometimes makes races that are considered alright.
Most under-rated race: http://www.nmaps.net/225629
Best race in a while: http://www.nmaps.net/225060
First good race: http://www.nmaps.net/223354
MAP PACK! (first one, not that good) http://www.mediafire.com/?kvbb3bta85fbl1n
Postby Destiny » 2013.01.23 (05:08)
Postby zoasBE » 2013.01.23 (09:31)
just as friends as enemies
even fewer friends
NUMA Profile: http://www.nmaps.net/user/mercuri
Postby mercuri » 2013.01.23 (15:15)
http://www.nmaps.net/225708
why not: simple + no floorguard
NUMA Profile: http://nmaps.net/user/Meanapple
Postby meanapple » 2013.01.23 (16:07)
Check out my profil for less information
Postby Leonidas » 2013.01.23 (21:24)
ALRIGHT!!! No more maps now, 5 have been entered. Time for me to judge...the winner gets to become judge and add a theme!
Click!!!
From Streetsahead
From Aidiera
Also from Aidiera
From Traveleravi
Postby Leonidas » 2013.01.23 (22:03)
Judging:
StreetsAheadMulti-Theme Madness: Street's Map
7/10
_destiny^-Full Dive
7/10
meanapple108-3 Motherdip
7/10
the23/zoasbe103
8/10
mercurithe pit iv
9/10
Mercuri won!!! Mercuri, time to add a theme to the list. (The antitheme will remain the same.) Keep in mind that we already have a theme of simple, so try to make the next theme broad like simple, but a tiny bit more narrowed down, since we are progressing. This theme will add on to all other themes.
Click!!!
From Streetsahead
From Aidiera
Also from Aidiera
From Traveleravi
NUMA Profile: http://nmaps.net/user/lfaber
Postby lfaber » 2013.01.23 (23:36)
I call subbing a map in the next round!!!!!
:P
Postby Vanquish » 2013.01.24 (05:18)
damn it i was too late. i just finished the map aswell. ohwell, ill post it anyway, then next round ill try to actually submit a map for. sorry, ive been really busy and last night i was making 2 maps at once and talking to zoas on IRC.
Postby mercuri » 2013.01.24 (08:35)
ok guys here you go
-- themes posted on first post
after 5 maps are posted, stop and i judge.
(ps: the votes are very high lol; thanks, but other maps were cool too. oh, if theme doesn't work let me know)
GO GO GO GO
Postby Vanquish » 2013.01.24 (09:08)
heh heh heh, ill try to submit mine on time
Postby Leonidas » 2013.01.24 (12:55)
mercuri i changed it a bit, but same general idea. New theme is on the board.
Click!!!
From Streetsahead
From Aidiera
Also from Aidiera
From Traveleravi
Postby mercuri » 2013.01.24 (13:05)
action was what i was going for, but it seemed to general.
cool leo, i'll judge when i have time (ofc when 5 maps are posted)
Postby Leonidas » 2013.01.24 (13:34)
Hey here is my example map for THIS round:
http://www.nmaps.net/225735
Does not count for 5 maps!
~~~~~~~~~~BORDER LINE ROUND 2~~~~~~~~
Click!!!
From Streetsahead
From Aidiera
Also from Aidiera
From Traveleravi
Postby meanapple » 2013.01.24 (13:43)
Postby zoasBE » 2013.01.24 (13:55)
Simple+Rockets: http://www.nmaps.net/225737
btw, Leo,
just a quick question, you have the fully right to modify the new theme added by the new judge and theme adder each round?
even fewer friends
These Go Up to 11
Postby StreetsAhead » 2013.01.24 (14:04)
Entering the contest again, I think this map is a bit better than the first:
http://www.nmaps.net/225738
Postby Leonidas » 2013.01.24 (21:23)
zoasBE wrote: just a quick question, you have the fully right to modify the new theme added by the new judge and theme adder each round?
O i contacted mercuri and kind of figured it out, he doent mind :)
Click!!!
From Streetsahead
From Aidiera
Also from Aidiera
From Traveleravi
Postby lfaber » 2013.01.25 (04:04)
Postby Vanquish » 2013.01.25 (07:20)
here! see told you ill make it in time. hope this all classifies and all that. here you go
godamnit lfaber i can not stop laughing at your sig
Postby lfaber » 2013.01.25 (07:30)
-R3D_N1NJ4- wrote:here! see told you ill make it in time. hope this all classifies and all that. here you go
your welcome.
My wierd and maybe demonic humor is of utmost quality.
Postby Leonidas » 2013.01.25 (12:25)
!!!!!!!!!!!!!!!!!!!!!!!!!NO MORE MAPS FOR ROUND 2!!!!!!!!!!
Mercuri time to judge!
Click!!!
From Streetsahead
From Aidiera
Also from Aidiera
From Traveleravi
Users browsing this forum: Majestic-12 [Bot] and 12 guests
