Tool-Assisted Highscores/Speedruns
75-2 highscore - [133.875, 7.050 faster than Mr_Lim]
- Attachments
- 75-2 MBD.txt
- (3.49 KiB) Downloaded 526 times
Unreality's awesome mod
An idea: Wouldn't it be faster to wallslide on the right and then fall to the left(around the frames 820 and 1170)?
Possibly, but you may need to slow down so much to get over the LP that it would end up being slower even with the extra leftward momentum.macrohenry wrote:Woah! That's what I look like now ---> :o
Awesome job Eddy that is incredible for your first MBD. I see very little that could be improved on that run. Maybe a few tricks about getting around corner an optimizing turns. But that run is solid all the way through. And it is always great to see how much can be improved in this game.
I would also love to see Raif take a shot so we can see some mdb competition :P Although that would need to based on honesty, because you can just copy the other guy.
They aren't very impressive, but I wanted to take a shot at Ep00 and beat some raif MBD's :P Im sure he would beat me if he did them again though, but anyway here they go:
00-1 Speedrun [303 frames, 2 faster than Kool]
00-2 Speedrun [343 frames, 1 faster than Raif's MBD, 2 faster than Kool]
00-3 Speedrun [331 frames, 2 faster than van, 3 faster than Raif's MBD]
75-2 Highscore [133.875, 7.050 faster than Mr_Lim]
You can see I also included my previous first MBD of 75-2 hs, thats because I want to follow his tradition of doing sets of MBD's.
- Attachments
- DemosAO.txt
- (8.9 KiB) Downloaded 507 times
- Walking on Broken Glass
- NUMA Profile: http://nmaps.net/user/Kool-aid
Edit: I'm curious about how many frames are left in 00-0, why not give it a go if you have the time? I bet you can get a 343 out of it.
Only 343 Kool? ;)Kool wrote:Edit: I'm curious about how many frames are left in 00-0, why not give it a go if you have the time? I bet you can get a 343 out of it.
A lot harder than it looks to MBD due to how many times I had to change routes 'cause of drones.
So v2.0 demos,
Demos are found at http://bucket.thewayoftheninja.org/[lev ... serid].txt
Level number for 00-0 is 1 and 01-0 is 6 and so on.
The userID is a unique number representing every player . For example, the userID for Eddy is 38, Kool is 58 and mine is 126.
You can find your userID in your savefile, called "n_account.sol" found in localhost as usual.
Your .sol will look something like: "blah blah solokeyconfig blah blah savedEpisode userID 126 user Raif blah blah blah"
So for example a possible link for a demo is: http://bucket.thewayoftheninja.org/1-38.txt. This gives the demo data for Eddy's 00-0 highscore.
The data you get from here is in base64 and is compressed using zlib as I found out from this thread.
So for example to convert Eddy's 00-0 Highscore into readable format:
- Take the base-64 data from the link:
eNpjYSEVsAIBOzszMmBnBwmy4tDAxoQVsGE3GtlwiLGsWA1nw2cQTofjMg03YAAAhecEdQ== - Convert from base-64 to hexadecimal giving:
78da63612115b002013b3b333260670709b2e2d0c0c68415b061371ad97088b1ac580d67c367104e87e3320d3760000085e70475 - Decompress string using zlib giving:
0404040404040404040404040404040404040404040404040404040404040404040404040404040404040404040404040404050505050707030303030303030303030303030707050505050504040404040404040404040404040404040404040404040602020202020202020202020202020202020202020202060404040404040404040404040404040404040505050505050707030303030303030307050505050505050505050504040404040404040404040404040404060202020202020202020604040404040404040404040404040404040404040404040404040404040404040404040404040405050505050505050505050504040404040404040404040404040404040404040404040404040404040404040404040404040404040400 - Reverse every 2 digit "code" giving:
4040404040404040404040404040404040404040404040404040404040404040404040404040404040404040404040404040505050507070303030303030303030303030307070505050505040404040404040404040404040404040404040404040406020202020202020202020202020202020202020202020604040404040404040404040404040404040405050505050507070303030303030303070505050505050505050505040404040404040404040404040404040602020202020202020206040404040404040404040404040404040404040404040404040404040404040404040404040404050505050505050505050505040404040404040404040404040404040404040404040404040404040404040404040404040404040404000
- 00 - nothing
- 10 - jump
- 20 - left
- 30 - left jump
- 40 - right
- 50 - right jump
- 60 - left right
- 70 - left right jump
I wrote a short (quite shit, I'm sure) Python script to convert the base64 demo to a readable format.
import zlib
import base64
demo = 'eNpjYSEVsAIBOzszMmBnBwmy4tDAxoQVsGE3GtlwiLGsWA1nw2cQTofjMg03YAAAhecEdQ=='
demo = base64.b64decode(demo)
demo = zlib.decompress(demo)
demo = demo.replace('\x00','n.').replace('\x01','j.').replace('\x02','l.').replace('\x03','lj.').replace('\x04','r.').replace('\x05','rj.').replace('\x06','lr.').replace('\x07','lrj.')
print demoCode: Select all
r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.rj.rj.rj.rj.lrj.lrj.lj.lj.lj.lj.lj.lj.lj.lj.lj.lj.lj.lj.lj.lrj.lrj.rj.rj.rj.rj.rj.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.lr.l.l.l.l.l.l.l.l.l.l.l.l.l.l.l.l.l.l.l.l.l.l.lr.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.rj.rj.rj.rj.rj.rj.lrj.lrj.lj.lj.lj.lj.lj.lj.lj.lj.lrj.rj.rj.rj.rj.rj.rj.rj.rj.rj.rj.rj.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.lr.l.l.l.l.l.l.l.l.l.lr.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.rj.rj.rj.rj.rj.rj.rj.rj.rj.rj.rj.rj.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.r.n.- If you ain't first, you're last!
After much work managed to get a MBD done on 00-4 of v2.0
Got a score of 6515 using a bbtriple (current 0th is 6513)
More details when I am not as sleepy, but basically what I did was redirect connections from nserver.thewayoftheninja.org and bucket.thewayoftheninja.org to localhost, so that N loaded it's highscores from text files on my computer.
So I was able to get the game to play any demo I wanted :D
eJxjYkIDzCCA4LKSA1ioDIi1ASwDQszEAnTfkwe4AB1lBH0=- Attachments
- nv2democodegenerator.zip
- (625 Bytes) Downloaded 498 times
Your score in seconds*60Izzy wrote:Probably been posted somewhere already, but what does the number shown in the highscores mean?
For example Eddy has a time of 115.200 on 00-0, so
115.200*60 = 6912 which is what is shown.
Also good job overcoming the n2.0 online demo system.
Is that last piece of gold even possible to get?
Also, the last two pieces of gold I took are only worth 7-10 frames max, so they are probably not worth going for in realtime.
