Forums overhaul
Postby 乳头的早餐谷物 » 2013.09.17 (09:19)
Okay so I just went and overhauled the forum structure a bit. Don't like it? -Too bad-.
I think it's fairly self-explanatory. There was a desperate need to separate the 1.4 stuff from the 2.0 stuff so I did that. At the moment I haven't added separate mapping, contest, etc. subforums for 2.0; if the demand for them occurs we can do that. It's a little rough but it's... I mean, having two similar but incompatible versions of the same game makes it necessarily a bit messy. Beyond those changes I shuffled up the order a bit, moved the N stuff above the off-topic stuff, other minor adjustments. All forum moderators have been removed, opening the way for staff changes soon.
Discuss?
Postby panstromek » 2013.09.17 (10:37)
Good idea man.
Postby Vyacheslav » 2013.09.17 (12:50)
Woohoo! Much needed. Hopefully this will spark new discussions too
Postby aids » 2013.09.17 (13:47)
As long as you follow through with promotions, I'll begrudgingly approve of these Daveian changes.
Postby zoasBE » 2013.09.17 (14:46)
Really good idea separate v2.0 from v1.4. Also good job with the new structure. I like it.
just as friends as enemies
even fewer friends
Postby 29403 » 2013.09.17 (20:09)
I like it - looks more organised. I always thought it was weird for the N-related stuff to be near the bottom of the arrangement of sub-forums.
You know... it's more like the old forums! ^_^
Postby 999_Springs » 2013.09.17 (20:20)
nice layout, i approve
one thing that bugs me is the need for two identical datestamps on the guest homepage
(11.29 KiB) Downloaded 428 times
like where it says 2013-09-17 (259.657) there's no need to have both the 09-17 and the 259 since they both mean the same thing
please tell me if that was intentional or not, so that order can be restored to the universe
Postby Donfuy » 2013.09.17 (23:41)
29403 wrote:I like it - looks more organised. I always thought it was weird for the N-related stuff to be near the bottom of the arrangement of sub-forums.
It made sense back then, when the community as a whole was very active. Nowadays it's less active, and people mostly only come here for n. Which is a bit sad but what it was meant to be since the beginning so it's nice I guess? :c
The off-topic forum looks a bit too big, and I can see some forums that could merge with another (Tabletop Gaming, per example). But for the most part, I'd say it's a very successful overhaul.
On moderators, we could have a moderator for each general forum or add a couple more active gmods.
Postby otters~1 » 2013.09.18 (00:19)
i sense that my forevergoal of becoming moderator of the tabletop gaming forum is once again within reach
Postby M4xwell » 2013.09.18 (00:37)
It seems more organized than before and it's a hell-u-va lot easier to proclaim in the accurate thread(s).
"...well then."
Sponsered by panstromek...
Postby 乳头的早餐谷物 » 2013.09.18 (01:03)
999_Springs wrote:nice layout, i approve
I thought decimal time might confuse and alienate guests so I supplemented it with a more normal timestamp.
Postby james_S » 2013.10.20 (17:50)
Hi ℴh nℴ I tried to email you just now as activation emails for new members don't seem to be being sent out. But strangely your name appears blank in the email I sent (i.e I cant click you).
Raigan and the Horse-Woman
Postby sidke » 2013.10.20 (19:12)
hello
i went and fixed the email problem
Postby aids » 2013.10.20 (22:46)
nevada wrote:hello
thank you holy sidke, many praises onwards to you
