Nv2.0 User levels 0ths
Discuss the Metanet map server and the submissions to it
Moderator: XandoToaster
Postby panstromek » 2013.10.24 (13:08)
I decided to make this thread to help highscoring on userlevels.
-Just write name and author of the map where you took 0th, you can write your rating, too, if you want
-Don't post boring, noob levels, just the fun ones :) what you think other people would like to try to take.
-Don't post level where 0th means you are only one who beated it, unless it is good run, challenging for other highscorers
-Doesn't matter how old it is but don't post it too early after publishing, because someone propably beat you very quickly
-Url is not needed, you must open it in game anyway
For beginning:
asd by GrzegorzPl (for the first time I beated Eddy :), little innov) ; 5/5
Mine cave_2 by rlargus0302 ; 4/5
Mini 009 [2 player mode] by Fujita Seiko (little innov) ; 4/5
Interstationed by M4xwell ; 5/5
Postby M4xwell » 2013.10.24 (17:37)
What happens if you're not good enough to make 0th but you make the levels? D:
"...well then."
Sponsered by panstromek...
Postby M4xwell » 2013.10.24 (20:15)
It's pretty funny, but for now, I have 0th on "For M4xwell" http://www.thewayoftheninja.org/nv2.html?l=17530
"...well then."
Postby EddyMataGallos » 2013.10.25 (17:27)
panstromek wrote:asd by GrzegorzPl (for the first time I beated Eddy :), little innov) ; 5/5 Mine
Mine cave_2 by rlargus0302 ; 4/5 Mine
Mini 009 [2 player mode] by Fujita Seiko (little innov) ; 4/5 Mine
Interstationed by M4xwell ; 5/5 Mine
M4xwell wrote:It's pretty funny, but for now, I have 0th on "For M4xwell" http://www.thewayoftheninja.org/nv2.html?l=17530 Mine
Postby alsojp27ace » 2013.10.25 (20:08)
Taken
Postby EddyMataGallos » 2013.10.25 (23:43)
Taken
Retaken
Postby james_S » 2013.10.25 (23:45)
World hardcore-1 www.thewayoftheninja.org/nv2.html?l=1196 -You could beat this easily probably as I ran it when I wasn't very good, you can see its one of the first N2 maps. I wonder if you guys remember it. I'm posting it here to show off the trick with the lasers I did :) ..and I did wonder if there was an easier way?
Postby M4xwell » 2013.10.26 (00:01)
"...well then."
NUMA Profile: http://www.nmaps.net/user/thrasher26
Postby thrasher26 » 2013.10.26 (00:57)
Reddormu by Fujuita Seiko. 4/5
Formal Curve by ghjihg (Hey Eddy; te supere por un punto :P Se que no te quedaras contento con el segundo lugar). 4/5
thump test 3 by FamilyJewellz. 4/5
How I feel when I play Thrasher's 'Pro' Levels by SPeric. LOOOL 4/5
Postby EddyMataGallos » 2013.10.26 (03:21)
james_S wrote:World hardcore-1 http://www.thewayoftheninja.org/nv2.html?l=1196 -You could beat this easily probably as I ran it when I wasn't very good, you can see its one of the first N2 maps. I wonder if you guys remember it. I'm posting it here to show off the trick with the lasers I did :) ..and I did wonder if there was an easier way? Mine
thrasher26 wrote:Reddormu by Fujuita Seiko. 4/5 Mine
Formal Curve by ghjihg (Hey Eddy; te supere por un punto :P Se que no te quedaras contento con el segundo lugar). 4/5 Mine
thump test 3 by FamilyJewellz. 4/5 Mine
How I feel when I play Thrasher's 'Pro' Levels by SPeric. LOOOL 4/5 Mine
Btw nice spanish thrasher :P Just an N-related correction: those are frames, not points.
Postby panstromek » 2013.10.26 (14:28)
Awesome run on Interstationed, Eddy.
One circle by panstromek (yes, it's me. Beated vankusss with intended route)
Little problem by panstromek (also me)
Guards protect their secret. by panstromek (If you think it's me, you're right!)
And what about to add some longer/more challenging ones?
Tunnel system by panstromek (yeah, it's me again, I finally made good run on this one)
Two circles by panstromek (I can't believe it's me again, how annoying)
...(sponsored by panstromek)...
NUMA Profile: http://nmaps.net/user/ghjijhg
Postby ghjijhg » 2013.10.26 (19:15)
I have 0th here: http://www.thewayoftheninja.org/nv2.html?l=17892.
At least I have it for now.
Postby M4xwell » 2013.10.26 (19:27)
"...well then."
Postby Inevitability » 2013.10.27 (16:39)
Thank you, panstromek, for good levels.
Taken.
btw "Guards protect their secret." and "Tunnel system" are very tricky (Spent like an hour on Tunnel system)
Postby panstromek » 2013.10.27 (17:32)
Inevitability wrote:Taken.
I have been checking those maps since I posted here so I saw some of your runs before. Awesome run on tunnel system. You were so close to the mine in the end :D (near the blue button). And nice Innov on One circle.
Yes, these ones are tricky but not as much as some others. Try Spirit of Tetris, Cancer or Fusion if you want. I wanted to post them here because I have 0ths on them, too but with lame runs and I thought no one would want to play them :D. Total hard for AGD.
Inevitability wrote:Thank you, panstromek, for good levels.
Thanks!
Postby thejumper£#! » 2013.10.27 (19:02)
Ganbatte - Fujita Seiko - www.thewayoftheninja.org/nv2.html?l=10220
5/5 very hard at this speed! :)
(Now EddyMataGallos [but is real this guy? :D] take this in 10001...)
thecircus741: Drone-trainer
Postby panstromek » 2013.10.27 (19:17)
Sengoku 03 by Fujita Seiko (I finally beated one of my favourite maps)
One circle retaken
Little problem retaken
thejumper£#! wrote:Ganbatte - Fujita Seiko - http://www.thewayoftheninja.org/nv2.html?l=10220
Nice!
Edit: Just made relatively clean run at Torture chamber by TrollerLOlz, awesome map.
Postby _danielr_ » 2013.10.27 (22:26)
thejumper£#! wrote:Ganbatte - Fujita Seiko... 5/5 very hard at this speed!
Doesn't seem too bad to me... ;)
Postby EddyMataGallos » 2013.10.27 (23:13)
Haha thanks, I'd like to be playing all levels that are posted here but I'm pretty busy with university lately and I can barely play. Took that one though ;)
Postby _danielr_ » 2013.10.27 (23:20)
EddyMataGallos wrote:Took that one though ;)
Like I wasn't expecting that ;)
By the way, Eddy, what do you study? And where?
Postby panstromek » 2013.10.28 (10:30)
I post it here, too because you propably don't read "Nominate and talk about nv2 userlevels" thread.
So again. I made map called "Sign up on forum.droni.es " ...) to invite people to forum. Please view it and rate 5 to keep it visible for as many people as possible. I opened the game this morning and map had 3,7. I feel like I'm in madhouse. I really don't understand why some idiot must ruin my effort.
EDIT: I took it to fit into rules :)
Postby EddyMataGallos » 2013.10.28 (14:28)
I study Maths at the University of Murcia (my city), which I understand no foreigners will have heard of :P
You also study Maths as far as I remember right?
Postby alsojp27ace » 2013.10.28 (15:22)
I've heard of Murcia, but only because my uncle has a holiday home in La Ahozia on the coast just south of there :p
I'm studying Maths too, but on a year out working atm.
I took a few random 0ths from this thread to stay on topic, I can't remember exactly which ones but I'm sure Eddy will take them soon anyway :p
I think my favourite to play so far is Odd Angles by M4xwell
Postby james_S » 2013.10.28 (18:56)
LMAO- Eddy took it in 10101 what can I say Nice one!
Postby EddyMataGallos » 2013.10.28 (19:09)
_danielr_ wrote: Like I wasn't expecting that ;)
Oh yeah La Azohia what a beautiful place, I've gone hiking a couple times there. Interesting you are doing Maths as well, I know zaps is doing them as well, so thats 4 people already, wow considering how unpopular Maths tend to be (at least here) thats impressive.
