You should also be stoked about the frame you snagged on 11-0. xaelar's 0th was a pre-NReality run as well.macrohenry wrote:Oh, I know what you mean. For me it's a weird feeling between being proud and feeling slightly guilty.
Metanet 0ths Thread
11-0 is pretty clean as well, a pity there's a bottleneck at the end. Honestly, I always thought those drones are beatable, if you feel confident, you can try to implement my speedrun start, it cleans 20-30 frames and its not that hard. When I took the 0th with it I thought on developing a route for hs by including it to see if I could change something, but at the end I was too lazy to do it.
edit: oh damn forgot infunity is down haha, I'll see if I can grab the demo from my sol.
EDIT: I just did before you told me macro hah!macrohenry wrote:That's why I wrote "another ancient 0th". Time to update your list, Eddy! ;)
Non-NReality level 0ths
11-3 Ben_Schultz_11
30-2 clux (NReality-tied)
32-4 macrohenry
34-3 Ben_Schultz_11
57-1 Mr_Lim (NReality-tied)
67-2 Just4TheFun
69-2 Mr_Lim
77-4 clux
82-4 xaelar
83-0 macrohenry
85-4 macrohenry
87-0 xaelar (NReality-tied)
90-4 macrohenry (NReality-tied)
92-3 macrohenry
95-0 Mr_Lim
Non-NReality Episode 0ths
86 esp
FBFed 0ths
02-2 Goo
02-4 Goo
09-3 kryX-orange
22-1 crappitrash
26-1 naem
26-4 L3X
27-4 ANGERFIST
32-1 kryX-orange
46-3 L3X
53-0 kryX-orange
87-0 ANGERFIST
89-0 crappitrash
90-3 kryX-orange
This is also sick.EddyMataGallos wrote:Haha that was sick macro, awesome execution.
O_Omacrohenry wrote:Took 80-0, beating the MBD. And it's still improvable because I held jump at the end for too long.
Not sure where golf thinks you're going to pull another three or four frames from, though. Looked very tight to me in real time.
- Cowboy Magician
Annnd so what exactly is the best thing to do to get rid of the lag (it is lagging right, its not just the lack of smoothness?) -i remember hearing something to do with the graphics settings?
That's exactly where I was seeing them. You definitely are above the exit by the time you actually get there horizontally, so there's extra frames where you're falling into the exit. Those can be gotten rid of if you simply don't hold jump as long :) I seem to remember that its possible to not jump high enough to clear all the tiles between the jump and the exit, so if you held for 6 frames I would think 4 is the max you can shave, maybe only 3. Care to try it out?macrohenry wrote:I analyzed the run with NHigh and I found out that I held jump for six frames. :( I think another three or four frames are actually realistic if you do a one or two frame jump.
Umm... What...?! You just out did an MBD on a map like that?! Unfuckingbelievable. Raif... I think you have some explaining to do.macrohenry wrote:Took 80-0, beating the MBD. And it's still improvable because I held jump at the end for too long.
This wouldn't be to hard to check, just take the demo data from the run and edit out the hold frames. Should be very easy to edit the demo after the CK.golf wrote:That's exactly where I was seeing them. You definitely are above the exit by the time you actually get there horizontally, so there's extra frames where you're falling into the exit. Those can be gotten rid of if you simply don't hold jump as long :) I seem to remember that its possible to not jump high enough to clear all the tiles between the jump and the exit, so if you held for 6 frames I would think 4 is the max you can shave, maybe only 3. Care to try it out?macrohenry wrote:I analyzed the run with NHigh and I found out that I held jump for six frames. :( I think another three or four frames are actually realistic if you do a one or two frame jump.
Yeah, but that depends on the angle which you hit the tile with. Macro's ck was pretty powerful and I think even a single frame would have taken him far enough. If you check my demo, on the other hand, you will see I had to hold longer because I didn't hit the ck with a powerful angle. I also think some time can be saved on the leftmost jump.golf wrote:That's exactly where I was seeing them. You definitely are above the exit by the time you actually get there horizontally, so there's extra frames where you're falling into the exit. Those can be gotten rid of if you simply don't hold jump as long :) I seem to remember that its possible to not jump high enough to clear all the tiles between the jump and the exit, so if you held for 6 frames I would think 4 is the max you can shave, maybe only 3. Care to try it out?macrohenry wrote:I analyzed the run with NHigh and I found out that I held jump for six frames. :( I think another three or four frames are actually realistic if you do a one or two frame jump.
Anyway thats just talking about technical limits, not human limits, macrohenry's run pretty much reaches it already haha. But honestly jaw-dropping run macro, 4 cj's done so cleanly is impressive.
EDIT: Here's the demo, I edited out all the hold frames, a single frame jump is enough:
The result is 102.025, so you technically lost 6 frames, sorry macro :/ (would have been a little less in real life of course, but still that could have been astou ding).
Oh, and Eddy, how did you get the demo data?
- Cowboy Magician
http://forum.droni.es/viewtopic.php?f=45&t=355james_S wrote:fine then. thanks for the quick help robots
There is a subforum for that, and having spended there just two minutes you'd found the answer quickly or even have asked there. Anyway, check the bottom of the first post in that link (NReality Main Thread) for what you can do to fix NReality's lag in OS which are not XP, although the best thing is play it in Windows XP, it has no lag and runs frankly smooth, much better than Nv2.0. I think the best way to play N, is playing NReality_6g2 under XP.
You're welcome.
EDIT: Please, go and buy a XP computer system! XD
zoasBE@NUMA
VODKALOVER@NUMA
the23@NUMA
insatiable@NUMA
COMMANDOS
//stoneman
9000
:3
CORaN
Astro Chimp
My 100 Vehemence 4 Maps
MOSS
Vehemence 4 as THE23
VODKALOVER Session One
VODKALOVER Session Two
Infunity: http://n.infunity.com/get_lv_demo_only.php?pk=85278 Try clicking on the scores, it takes you to the demo.macrohenry wrote:8 frames faster than Raif's MBD?!? Holy shit! But of course I had to mess up the very end of the run. -.- I might try to get some more frames someday. Btw, I think an even more powerful ck is possible.
You can also get it from HarveyCartel (Metanet boards).
It is indeed impressive how faster that is compared to Raif's MBD. As for the ck, yeah a more powerful one could be possible, but I'm not sure you would save more time (you gain height, and you need to fall, so unless the ck is really horizontal, you would still need the same time to fall, but anyway thats very optimistic hehe).
i'm pretty sure i speak for most of us when i say i secretly believe they're the sameska wrote:Negative.▲▪►▪▼◄▲ wrote:Wait, just to be clear, this "Zella" fellow is xaelar, right? xela -> Zella
Or am I just nutso?
It's a popular misconception - one that I initially held.
Topic.
As I said earlier... I'm not going to be that surprised one way or the other... Last_FairyTail was an interesting alias... To do so again would just be... well... a bit lame. :/999_Springs wrote:i'm pretty sure i speak for most of us when i say i secretly believe they're the sameska wrote:Negative.▲▪►▪▼◄▲ wrote:Wait, just to be clear, this "Zella" fellow is xaelar, right? xela -> Zella
Or am I just nutso?
Topic.
Oh, great 63-2, jp, but why didn't you post it here?
I was too tired the night I took it :pmacrohenry wrote:Took 57-0, 57-3 and improved 57-1, making Ep57 my first ownage. ^_^
I also tied raif on 63-4 but couldn't quite get another frame
Edit: Just finished watching Episode 57, they are all amazing runs. gratz on the ownage.
