I have avenged Raif's demise :pjasdanu wrote::D Yup. But even before this I had beaten Raif by one frame way back when the map was featured. I realized I could shave 1-3 frames off and went at it again. Glad I didska wrote:thanks for avenging my demise.jasdanu wrote:After tiring my fingers for 10 minutes I finally beat Raif's speedrun on 162592
Post a Run!
yeah, nice one - it looks exceptionally clean.jasdanu wrote::D Yup. But even before this I had beaten Raif by one frame way back when the map was featured. I realized I could shave 1-3 frames off and went at it again. Glad I didska wrote:thanks for avenging my demise.jasdanu wrote:After tiring my fingers for 10 minutes I finally beat Raif's speedrun on 162592
Your position in relation to the thwump, combined with your downward velocity, caused you to be forced down. It looked a bit glitchy, I'll admit, but nothing mind-blowing...macrohenry wrote:What was that? O_O
- NUMA Profile: http://nmaps.net/user/LouDog004
Yup that also happenned to me last day when taking it, and I gotta say the first time I was surprised, I do think its weird, I don't recall having ever seen that. I mean I've been simply propelled downwards and crushed, but not this. What I concluded is basically that you wait too much to walljump, and hence two things happen: Firstly, you are on the bottom half and so you are propelled downwards, and secondly, you walljump after the thwump push, which is not the usual thing. I guess that causes the walljump being detected on a frame, but by the next frame, when the wj should be executed, you are already past the thwump's wall because of the powerful push, and so you execute it on air, crashing with the thwumps bottom side afterwards. That's just some explanation I speculated when it happened.ska wrote:Your position in relation to the thwump, combined with your downward velocity, caused you to be forced down. It looked a bit glitchy, I'll admit, but nothing mind-blowing...macrohenry wrote:What was that? O_O
Seems legit.EddyMataGallos wrote:Yup that also happenned to me last day when taking it, and I gotta say the first time I was surprised, I do think its weird, I don't recall having ever seen that. I mean I've been simply propelled downwards and crushed, but not this. What I concluded is basically that you wait too much to walljump, and hence two things happen: Firstly, you are on the bottom half and so you are propelled downwards, and secondly, you walljump after the thwump push, which is not the usual thing. I guess that causes the walljump being detected on a frame, but by the next frame, when the wj should be executed, you are already past the thwump's wall because of the powerful push, and so you execute it on air, crashing with the thwumps bottom side afterwards. That's just some explanation I speculated when it happened.ska wrote:Your position in relation to the thwump, combined with your downward velocity, caused you to be forced down. It looked a bit glitchy, I'll admit, but nothing mind-blowing...macrohenry wrote:What was that? O_O
Nice run Jas. That top right chamber will make this run tough to beat.jasdanu wrote:Beat RR on 231567 by just 5 frames. Still at least a good 5 more left IMO
You are right to fear the beast.alsojp27ace wrote: That's a surprisingly fun map considering how small and simple it is, taken. (I'm too afraid to go near Metanet 0ths atm).
Taken with a cool ending. ;)golf wrote:228264 hs, as suggested by loudog. Thanks for the base route there, but I think it needed a little improvement :)
THIS is the kind of all-roundedness i was talking about on the podcast...macrohenry wrote:Taken with a cool ending. ;)golf wrote:228264 hs, as suggested by loudog. Thanks for the base route there, but I think it needed a little improvement :)
I thought about getting the gold on the right side on the way down, but couldn't see a quick easy way back up afterwards. Guess you found it lol. Great ending, I didn't think there was quite that much time left after my run.macrohenry wrote:Taken with a cool ending. ;)golf wrote:228264 hs, as suggested by loudog. Thanks for the base route there, but I think it needed a little improvement :)
yeah, i wasn't sure... i should have tested it moremacrohenry wrote:Taken as well. The jump at the top platform is not necessary. Feel free to beat me, I won't defend the 0th.
edit: improved by 0.100, still frames left...
This was really only the 2nd route decent route I came up with, so there might be faster.
Side note: Nexx has announced his retirement after 9 years of being in the community. I think all of us highscorers should give him a fitting send off by demoing as many maps of his as you can, and make sure you leave the demos as comments on his various maps. I think it would be a fitting way to send him off!
jasdanu wrote:A casual speedrun for 232283
