Post a Run!
In the future, could you please reference map ID? Nice run btw. :)jasdanu wrote:Not an amazing run but I would like to point-out that heightless corner kick though xD
Taking a stab here, able to beat jas by 4 frames so far:jasdanu wrote:Found it. Map ID is 185592. Here is an improved demo but I'm too lazy to go for the sub-600 which is very easy to pull off.
P.S. I just found out about the Facebook Page for Metanet but I can't join since it is a closed group. Anyone willing to add me (name is Daanish Kalotia)?
Am working on a crazy innov that will easily break 600 frames, probably be sub-550 and maybe sub-500? (I'm not very good at estimating how much time innovs save... but I've done 2 proof of concept runs that tell me its definitely possible just very tricky/lucky)
golf wrote:Taking a stab here, able to beat jas by 4 frames so far:jasdanu wrote:Found it. Map ID is 185592. Here is an improved demo but I'm too lazy to go for the sub-600 which is very easy to pull off.
sub-550 is easily possible. I would be around the 543 mark if I didn't over jump near the Door entrance and hit a mine
Well then I think sub-500 is doable for you with this innov. Got a few runs completed, all within 3 frames of each other actually.jasdanu wrote:golfkid wrote:
Haven't been able to get any faster than this yet, sadly. I think I may top out around 560 or so, but I haven't been getting clean finishes and its not very often I get to even try.
Edit: Even though I can't get the awesome jumps to the gold that you can, still managed to break 550!
I'll leave it to you to break the 500 frame mark :) I have faith in you!
Once I get that last jump-pad down I can break 500golf wrote:Well then I think sub-500 is doable for you with this innov. Got a few runs completed, all within 3 frames of each other actually.jasdanu wrote:golfkid wrote:
Yeah that's definitely the hardest part since you have to get the angle just right. If I could get that jump to the left down, I could take my own stab at it too. Also, I was kinda hoping for some sort of admission at just how crazy this is to even try but maybe its not as far out there as I thought.jasdanu wrote:Once I get that last jump-pad down I can break 500
Dear Lord. That last jump rips away at your soul. I've had 4 perfect runs ruined by a wrong angle. I'm still going to keep at it.golf wrote:Yeah that's definitely the hardest part since you have to get the angle just right. If I could get that jump to the left down, I could take my own stab at it too. Also, I was kinda hoping for some sort of admission at just how crazy this is to even try but maybe its not as far out there as I thought.jasdanu wrote:Once I get that last jump-pad down I can break 500
- NUMA Profile: http://nmaps.net/user/LouDog004
taken by 5.475 seconds to be precise :PLouDog004 wrote:180146 - The rockets/tiling on this map are on point.
edit: add 214505 hs
- Semimember
It's still possible to do better since I was a bit too slow at the beginning, I only did a nice finish.
To what 05-4 are you referring?Tekeur wrote:I did a new 0th on 05-4, that level was really frustrating 'cause sometimes I went too fast and bumped into the last drone, and I also failed the last jump about 20 times...
- Semimember
The metanet level 05-4 on N v2 (electric avenue). Maybe I should've posted that run in this topic : http://forum.droni.es/viewtopic.php?f=2 ... start=3050 ?TheRealOne wrote:To what 05-4 are you referring?Tekeur wrote:I did a new 0th on 05-4, that level was really frustrating 'cause sometimes I went too fast and bumped into the last drone, and I also failed the last jump about 20 times...
Nice run, although this topic is mainly used for v1.4 user level runs, so its worth mentioning its a v2.0 run if you post it here.Tekeur wrote:The metanet level 05-4 on N v2 (electric avenue). Maybe I should've posted that run in this topic : http://forum.droni.es/viewtopic.php?f=2 ... start=3050 ?TheRealOne wrote:To what 05-4 are you referring?Tekeur wrote:I did a new 0th on 05-4, that level was really frustrating 'cause sometimes I went too fast and bumped into the last drone, and I also failed the last jump about 20 times...
The best place to post this would be here
very nice... i figured your route would be faster...macrohenry wrote:232374 hs
- Semimember
This was the 160000th post on the forums :PTekeur wrote:I took 214505 and 180146, by taking a slightly different road at the beginning on both of the levels
You sure? I think it was the 170762nd post. Perhaps there have been 10.7k deleted posts?EddyMataGallos wrote:This was the 160000th post on the forums :PTekeur wrote:I took 214505 and 180146, by taking a slightly different road at the beginning on both of the levels
viewtopic.php?p=170762#p170762
That might be the explanationTheRealOne wrote:You sure? I think it was the 170762nd post. Perhaps there have been 10.7k deleted posts?EddyMataGallos wrote:This was the 160000th post on the forums :PTekeur wrote:I took 214505 and 180146, by taking a slightly different road at the beginning on both of the levels
