undoubtedly faster. Though I am going to assume since you posted it here rather than taking the 0th for yourself it is exceedingly difficult?macrohenry wrote:77-3
Difficult, yes, but doable. I might try harder later.TheRealOne wrote:undoubtedly faster. Though I am going to assume since you posted it here rather than taking the 0th for yourself it is exceedingly difficult?macrohenry wrote:77-3
Idea for 23-2:
Triple bb jump, corner jump on the 1-tile, corner shove (or whatever it is called). Not sure if it works, but if it does it should save some frames.
Totally possible. That is Raif's MBD route except he avoids the LP and goes to the BB after the gold. I am going to assume he tested both the CS > LP route vs the WJ > BB route and concluded the BB was faster. (Probably easier for real time as well.)macrohenry wrote:
Idea for 23-2:
Raif's MBD
- Member
- NUMA Profile: https://www.nmaps.net/user/nadroj347
Where do you guys pull Raif's MBD's from? Is there like a database or topic that has all of them?TheRealOne wrote:Totally possible. That is Raif's MBD route except he avoids the LP and goes to the BB after the gold. I am going to assume he tested both the CS > LP route vs the WJ > BB route and concluded the BB was faster. (Probably easier for real time as well.)macrohenry wrote:
Idea for 23-2:
Raif's MBD
Also, don't you also have some MBD's TRO?
Here ya go: http://forum.droni.es/viewtopic.php?f=2 ... &start=375nadroj347 wrote:Where do you guys pull Raif's MBD's from? Is there like a database or topic that has all of them?TheRealOne wrote:Totally possible. That is Raif's MBD route except he avoids the LP and goes to the BB after the gold. I am going to assume he tested both the CS > LP route vs the WJ > BB route and concluded the BB was faster. (Probably easier for real time as well.)macrohenry wrote:
Idea for 23-2:
Raif's MBD
Hm, I should check out the MBDs before I post another "innov" here that's been discovered long ago... *blushing*TheRealOne wrote:Totally possible. That is Raif's MBD route except he avoids the LP and goes to the BB after the gold. I am going to assume he tested both the CS > LP route vs the WJ > BB route and concluded the BB was faster. (Probably easier for real time as well.)macrohenry wrote:
Idea for 23-2:
Raif's MBD
- Legacy Elite
Here's a pastebin with 170 of his MBDs. Lots of the attachments on here are gone, so i prefer using this. He updated a few of these runs just last weekend, so it's up to date.nadroj347 wrote:Where do you guys pull Raif's MBD's from? Is there like a database or topic that has all of them?
http://pastebin.com/J3amFUHG
I updated my MBD collection in September too, based on his first post collection and adding his last packs, but it also includes the MBDs I did, the one jp did, and basically all I could find. It's 174 MBDs:Hendor wrote:Here's a pastebin with 170 of his MBDs. Lots of the attachments on here are gone, so i prefer using this. He updated a few of these runs just last weekend, so it's up to date.nadroj347 wrote:Where do you guys pull Raif's MBD's from? Is there like a database or topic that has all of them?
http://pastebin.com/mHxqmXVV
I guess we should do some kind of collating to get the "full" list out of those 2 files, but I'm too lazy to find the differences xD (Not sure if I already shared this file, I have a vague memory but I can't find any post of myself sharing this, even though it was already on pastebin).
Nice execution on 72-1. That is certainly the right way to do it. I am not skeptical of 73-2 and the RCJ. I think you will need the "right" kind of RCJ to be faster, but it is probably faster.MiBeM wrote:I came up with a couple of little tricks on 72-1 and 73-2 sr (beating the drone on 72-1, cornerjump on 73-2), I use them in my submitted runs so have a look at them to see what I'm talking about. Used properly they could save a few frames, but I don't have the patience (for now, anyway) to clean up my runs enough to make a difference.
47-4
The first BWJ is probably too much for real time and/or the timing might not work out because of the thwump is too slow to be worth waiting to jump off it. The second BWJ though is certainly faster and is probably faster even if you just do a regular turn and WJ off it. It also shouldn't so fast that you run in to the drone in the top right.
This should be around 30 frames faster, resulting in a final score of about 124.600.
EDIT: 94-2
Probably impossible, but has anyone ever tried that?
Yeah exactly, so at the very least it needs to be 30 frames faster. And that would be tight as fuck. But beating the drone by a whole loop is probably impossible, so thats our best bet of improving the route (I think).macrohenry wrote:Any innovations in the main room are only valuable if it's enough to approach the drone like this:
Hey now, quit coming up with innovations for this level!macrohenry wrote:EDIT: 94-2
Seriously though, I feel like I tried that when taking the 0th. I remember finding that it was either slower, or would actually give you too much of a boost off the wall jump that you couldn't get to all the gold and would hit your head on the 1 or 6 tiles at the top.
Damn, if anyone pulls this off you have my eternal respect.macrohenry wrote:Any innovations in the main room are only valuable if it's enough to approach the drone like this:
Yeah this was my thought, but I didn't think it would require 30 extra frames. I don't think the upper BWJ will save 30 frames, so doing a CK on the BB up top would probably be necessary and even then it would be really close.EddyMataGallos wrote:Yeah exactly, so at the very least it needs to be 30 frames faster. And that would be tight as fuck. But beating the drone by a whole loop is probably impossible, so thats our best bet of improving the route (I think).macrohenry wrote:Any innovations in the main room are only valuable if it's enough to approach the drone like this:
Great route change, jp! Not sure if it's faster, but this could be a possibility to grab all the gold:alsojp27ace wrote:An idea for 44-2 which involves getting the exit switch through the door like in the speedrun, slightly faster even though its an agd-1 (and my start sucks).
I'm not sure whether its possible to get that top-right gold in the last jump.
Edit: Taken (just)
Nice find there JP. Great discovery. Macro that may work. Here is a little test map for anyone who wants to give doing AGD with JP's route a try. I think is is probably impossible but I have come very close a few times so maybe with a super lucky angled PJ you could make it happen.macrohenry wrote:Great route change, jp! Not sure if it's faster, but this could be a possibility to grab all the gold:alsojp27ace wrote:An idea for 44-2 which involves getting the exit switch through the door like in the speedrun, slightly faster even though its an agd-1 (and my start sucks).
Edit: Taken (just)
Yeah that's exactly what I tested yesterday. To be honest, I didn't get it, but I didn't try much. I'm almost 100% sure its possible, based on my tries. I'll try to get a demo this night or tomorrow, when I have some more time, but I'd be surprised if it were impossible. The angle is tight thats for sure.TheRealOne wrote:Nice find there JP. Great discovery. Macro that may work. Here is a little test map for anyone who wants to give doing AGD with JP's route a try. I think is is probably impossible but I have come very close a few times so maybe with a super lucky angled PJ you could make it happen.
The best I could get with about 15 minutes of attempts. It is a -2 but it has the right angles just not enough height. Perhaps if I had ran on the 8 tile for 1 frame instead of jumping right away I would have gotten it?EddyMataGallos wrote:Yeah that's exactly what I tested yesterday. To be honest, I didn't get it, but I didn't try much. I'm almost 100% sure its possible, based on my tries. I'll try to get a demo this night or tomorrow, when I have some more time, but I'd be surprised if it were impossible. The angle is tight thats for sure.TheRealOne wrote:Nice find there JP. Great discovery. Macro that may work. Here is a little test map for anyone who wants to give doing AGD with JP's route a try. I think is is probably impossible but I have come very close a few times so maybe with a super lucky angled PJ you could make it happen.
I managed to get this many, but the trajectory seems to be off for all gold.
Edit: This looks more promising:
Edit 2: Yeah, looks like the trajectory simply doesn't allow for it. (AGD-1 seems to be the limit, but I'd loved to be proved incorrect.)
