44-2
But back to reality... Pulling this ending off in the same run with the annoying exit switch trick... Good luck.
- Legacy Elite
I imagine that would be a run of the year nomination for the first person to do it.TheRealOne wrote:But back to reality... Pulling this ending off in the same run with the annoying exit switch trick... Good luck.
Whale Oil Beef Hooked.TheRealOne wrote:Proved you and myself wrong. Cha-Ching!
I concur.Hendor wrote:I imagine that would be a run of the year nomination for the first person to do it.
Awesome, I had a feeling it was possible, but as you say managing it in the same run as the exit switch trick will be very difficult.TheRealOne wrote:Proved you and myself wrong. Cha-Ching!
I'd say its probably MBD level, but you can never rule out rule out macro/eddy pulling it off.
Just some thoughts on the level. I am pretty sure both of these innovations are known; I even think macro attempted the CJ one in his 0th and just missed.
CJ when coming up the left side of the map:
Methods of turning around in the top right corner to head back towards the exit.
Current Method: Slide and turn jump: 211f
WJing the twump: 206f
Corner Shoving the twump: 203f
Slide and turn jump then BWJ the twump: 198f
If nothing else, this is interesting to me that it shows exactly how much a boost a corner shove can give.TheRealOne wrote:32-4
This one is just crazy... but I would love to see somebody do that in a 0th run xD
Yeah in the purest sense a CS is usually 2 frames faster than a regular WJ. But obviously things can vary if the scenario is changed.golf wrote:If nothing else, this is interesting to me that it shows exactly how much a boost a corner shove can give.TheRealOne wrote:32-4
WJ:
CS:
Yeah this was just for a bit of fun, but I wouldn't be doing my duty if I didn't show the best possible route. It is also a lot harder than it looks; at least to do it quickly.This one is just crazy... but I would love to see somebody do that in a 0th run xDSlide and turn jump then BWJ the twump: 198f
Any ideas on how to manipulate/avoid the final laser drone at the end? I already checked, and waiting for the laser to stop firing is slower than just skipping the gold as I did.
It could clean about 1 sec, I suspect.
Nice run; it's a shame about the final laser drone. I'm not sure how you could avoid the last drone without losing time :(EddyMataGallos wrote:Hey, not really an innov but a suggestion, you might want to check my 82-1 run, its AGD -1, and I'm confident I would have beaten 163 if I hadn't had that sloppy middle ascent before the exit switch.
Have you tried entering the final part from the right side?EddyMataGallos wrote:Hey, not really an innov but a suggestion, you might want to check my 82-1 run, its AGD -1, and I'm confident I would have beaten 163 if I hadn't had that sloppy middle ascent before the exit switch.
Obviously its slower, but it looks as though you had a big enough lead on macro to still take the 0th.
It would be most efficient to turn at the gold above, but this might lead to the drone shooting too early:
Otherwise you could just try like this:
What if that drone was triggered when crossing center gold of the map from the bottom left to top right? This may delay the cycle of the drone such that when entering his chamber from the left as currently done he wouldn't be all the way to the right and you may be able to get by him while he is still firing at the entrance.EddyMataGallos wrote:Hey, not really an innov but a suggestion, you might want to check my 82-1 run, its AGD -1, and I'm confident I would have beaten 163 if I hadn't had that sloppy middle ascent before the exit switch.
Yep, that's what macro does. You get the laser to detect you by going slower at that point, however, well, that causes the bottleneck which makes macro lose time. In case you haven't seen it, if macro had taken the exit switch just slightly earlier, the bottom laser drone would have detected him and blocked the way, killing him. The problem with that route is that going slow is also a problem, so there is a very tight sweet spot to reach the switch part, which even if you get right, its still tough to pass it alive (notice how macro, after taking the switch, has a tough time dodging the laser drone on the gold chunk).TheRealOne wrote:What if that drone was triggered when crossing center gold of the map from the bottom left to top right? This may delay the cycle of the drone such that when entering his chamber from the left as currently done he wouldn't be all the way to the right and you may be able to get by him while he is still firing at the entrance.
Hmm, those seem quite interesting, I'm going to test which one is faster and experiment a little bit :Dalsojp27ace wrote:Have you tried entering the final part from the right side?
EDIT: Taken with the help of the first, quicker method. Thanks man :D
Good luck to anyone trying.
*clears throat*
Hey, can you guys, like, be sure to include levels numbers so that peons like myself can be included in the conversation. Ummm, okay, thank you.
*trips whilst walking back to his seat*
EddyMataGallos wrote:Hey, not really an innov but a suggestion, you might want to check my 82-1 run...
ska wrote:Okay, so it's not a xaelar 0th, but I have a nifty time saver for 38-3...
I think Aids is high on Life!EddyMataGallos wrote:EddyMataGallos wrote:Hey, not really an innov but a suggestion, you might want to check my 82-1 run...ska wrote:Okay, so it's not a xaelar 0th, but I have a nifty time saver for 38-3...
Quote the relevant post, please.▲▪►▪▼◄▲ wrote:I wasn't talking about those two. It was the one with three locked door switches in the innermost room. That one.
I am so confused right now... Did TRO edit them in or something?▲▪►▪▼◄▲ wrote:Crisis averted: http://forum.droni.es/viewtopic.php?p=171559#p171559
Possible?
bahaha. I'm glad I'm not the only person who was insane enough to try this at some stage.macrohenry wrote:25-2
Possible?
By the way, I might be dreaming, but I feel like Raif tested this idea when he was making an MBD run, but I could be dead-set wrong.
If anyone pulls this off, my mind will be blown.
