Btw, I think its about time you have a go at the occupy xela movement, isn't it?
EDIT: I just realized that the fastest non-cj run for 11-0 is 149.225. For those that are using that route (golf?, Hendor?), I have a 150.500 non-cj route:
That was my first completion with it, 150.475, it can definitely be cleaned and you can beat Melchoir with it. 151 is probably not plausible for both bottleneck and cleaning issues, but its definitely worth a shot.
P.S. I am having trouble pasting demo data into NHigh's demo analysis... has anyone else ever had this issue? I've never had it before (Using 2.0.1)
Oh so had anyone done that route already? If not, its an innovation! It's of course a mixture of previous routes though.ska wrote:Not really an innovation, so much as a possible opportunity. A couple of years or so ago, swipenet took 06-3; however, his beginning uses a slower method. The launchpad route in the bottom-right corner (compare swipe to my run or xaelar's for example) is considerably quicker. (maybe 0.2-0.25 seconds faster.) Since the level is relatively long (about 1200 frames), swipenet's run is clean enough aside from this slower start to make up time and outrun xaelar. Consider this a big hint for Eddy or macro, or anyone else for that matter, to try to nab it.
Regarding NHigh, its working fine for me. What's happening with yours?
I don't know, but I got it working again; it was probably just a bug.EddyMataGallos wrote:Oh so had anyone done that route already? If not, its an innovation! It's of course a mixture of previous routes though.ska wrote:Not really an innovation, so much as a possible opportunity. A couple of years or so ago, swipenet took 06-3; however, his beginning uses a slower method. The launchpad route in the bottom-right corner (compare swipe to my run or xaelar's for example) is considerably quicker. (maybe 0.2-0.25 seconds faster.) Since the level is relatively long (about 1200 frames), swipenet's run is clean enough aside from this slower start to make up time and outrun xaelar. Consider this a big hint for Eddy or macro, or anyone else for that matter, to try to nab it.
I must have missed this part of your reply. I would have just called the launchpad route the "normal" route. I certainly won't take and credit for being an "innovation". For some reason swipenet used a slightly slower wall-jump route; perhaps under the mistaken belief that it was faster than the wall-jumps.EddyMataGallos wrote:Oh so had anyone done that route already? If not, its an innovation! It's of course a mixture of previous routes though.ska wrote:Not really an innovation, so much as a possible opportunity. A couple of years or so ago, swipenet took 06-3; however, his beginning uses a slower method. The launchpad route in the bottom-right corner (compare swipe to my run or xaelar's for example) is considerably quicker. (maybe 0.2-0.25 seconds faster.) Since the level is relatively long (about 1200 frames), swipenet's run is clean enough aside from this slower start to make up time and outrun xaelar. Consider this a big hint for Eddy or macro, or anyone else for that matter, to try to nab it.
It is known; it's just not that easy.Izzy wrote:It's probably been mentioned already, but grabbing the switch on 35-3 right after the walljump should definitely save a bit of time. Messed up the double a couple of time after getting it that way. :(
MBD for proof:
Oh no, I meant my 11-0 no-cj route. It takes parts from 2-3 different routes, plus a new ending. I don't think this had ever been used before, hence why I called it new route, or innovated route.ska wrote:I must have missed this part of your reply. I would have just called the launchpad route the "normal" route. I certainly won't take and credit for being an "innovation". For some reason swipenet used a slightly slower wall-jump route; perhaps under the mistaken belief that it was faster than the wall-jumps.EddyMataGallos wrote:Oh so had anyone done that route already? If not, its an innovation! It's of course a mixture of previous routes though.ska wrote:Not really an innovation, so much as a possible opportunity. A couple of years or so ago, swipenet took 06-3; however, his beginning uses a slower method. The launchpad route in the bottom-right corner (compare swipe to my run or xaelar's for example) is considerably quicker. (maybe 0.2-0.25 seconds faster.) Since the level is relatively long (about 1200 frames), swipenet's run is clean enough aside from this slower start to make up time and outrun xaelar. Consider this a big hint for Eddy or macro, or anyone else for that matter, to try to nab it.
Are either these possible while still avoiding the rocket?
Normal (Down, Up, Down, Up): 225f --- Current route.
Wall Jump and Only One Double Jump (Up, Down, Up): 209f --- Easy, but will probably get caught by the rocket.
Double Jump to Backwards Wall Jump (Down, Up): 190f --- Definitely possible with current route, but hard and a complete run ruin-er if failed.
Man! That' a nifty idea.TheRealOne wrote:57-4
Woah that last one looks awesome, that would definitely be the fastest if someone can pull it off.TheRealOne wrote:57-4
I tested the first one and was running into the rocket all the time, this way avoids the rocket and I found it to be slightly faster too:
Edit: Taken
This is a faster beginning:
works also with the rocket:
It's not raised in the first map, you need a cj. I raised it out of lazyness, to prove the rocket part. I hoped it would confuse people, so +1 me.alsojp27ace wrote:I sat here for about a minute thinking I swear I tried that jump, before I realized you raised the ground :p
That said, you could try something like this:
Ah yeah I just went and re-watched it, it certainly had me confused for a bit, I've never gotten the hang of that kind of cj.vankusss wrote:It's not raised in the first map, you need a cj. I raised it out of lazyness, to prove the rocket part. I hoped it would confuse people, so +1 me.alsojp27ace wrote:I sat here for about a minute thinking I swear I tried that jump, before I realized you raised the ground :p
Nice work JP. I had a feeling that the two options I showed weren't the only possibilities; the previous route to your 0th just seemed unnecessarily slow. Great innovation and run executing it.alsojp27ace wrote:Woah that last one looks awesome, that would definitely be the fastest if someone can pull it off.TheRealOne wrote:57-4
Edit: Taken
Things are escalating quickly. This map definitely has a lot left in it with these innovations and some cleanliness.alsojp27ace wrote:I sat here for about a minute thinking I swear I tried that jump, before I realized you raised the ground :pvankusss wrote:Nice finds.
occupy xaelar
My fingers just aren't quick enough for that first jump though, I hit the mine every time.
Edit: An example run with a purposefully slower start, so it's definitely possible for those of you with quick fingers:
It's interesting, because I was shortlisting this 0th as a possible candidate for de-xaelaring, but I think we'd need an N veteran with expertise in mathematical networks to determine the most optimal route (or close to it.)alsojp27ace wrote:For occupy xaelar, if you have a look at my 38-4 run, I'm convinced there's enough time left in cleaning to grab that first gold and still beat the same drone cycle.
Start
Current (117f):
New (crappy execution, 100f):
Gold in the middle
Current (366f):
New (355f):
Regarding the second one, I have a slightly faster one (349f):
That thing has much more potential though, I think. Specially by doing this:
Man that must save a bunch :P
(He looks way older...)
