I know what you mean. The problem is trying to gauge if route B is actually faster than route A. It was difficult for me guess visually if it would be faster. JP, how sure were you that the route was faster before testing? How sure do you have to be to actually put a new route to the test? Maybe we need to be more aggressive with new route possibilities, even if they might seem unorthodox or counter-intuitive at first. Also, I like your little trick at the start to save a few more frames... keep up the great innovs!macrohenry wrote:Nice innovation, as always. I actually thought of that one too, but I didn't bother to test if it was faster.alsojp27ace wrote:Taken 20-4 with a new route.
Metanet 0ths Thread
EDIT: Also took 93-2 with a run which I didn't expect to be fast enough. Innov by jp (of course!).
I had completely forgotten 93-2 even existed. The community has not visited this level in a long time. That run is awesome. The first descent and ascent up the middle is some serious technical work. Great job Macro.macrohenry wrote:Took 20-4 by 0.75 seconds. Amazing how much can be gained in this level by plain cleaning.
Great 20-4! I improved my run past 107 yesterday, and have pushed past 108 today. I'm pretty satisfied with this run, although there are many places for improvement in my run. Highscoring this level gave me a good sense of just how polished macro's run is.TheRealOne wrote:I had completely forgotten 93-2 even existed. The community has not visited this level in a long time. That run is awesome. The first descent and ascent up the middle is some serious technical work. Great job Macro.macrohenry wrote:Took 20-4 by 0.75 seconds. Amazing how much can be gained in this level by plain cleaning.
93-2 (which I thought for a second was 92-3 [as macrohenry was a master of this level], and golfkid saying:
Comparing 93-2 with the various changes and the various lead swings makes me think there is still room for improvement; and furthermore, it increases my desire to see an MBD of this level. Paging jp2ace.golfkid wrote:I had completely forgotten 93-2 even existed. The community has not visited this level in a long time.
Anyway, good stuff, macro!
I might have a go at an mbd, but thats the kind of level that will take quite a long time.
Taken 66-0, I'm disappointed to have only taken it by a frame, I had plenty of better AGD-1 runs.
Very nice. I just got an agd- .875 run.alsojp27ace wrote:Very nice runs macro, I planned to take 93-2 for occupy xaelar but then gave up and forgot to mention my innov.
Edit: check this out, JP: http://forum.droni.es/viewtopic.php?f=2 ... 00#p172700
EDIT: 04-3 with innovs.
Damn 22-1 is a super clean run. And on 4-3 forget the innovations on the way in (though those are nice touches.) The three perfect exits through the 1 wide gaps on the way out from the center are far more impressive. Those spots are true run killers and are much much harder than they look. Great stuff Macro.macrohenry wrote:22-1 from crappitrash. :) Added a tiny innovation on the left, but the rest is cleaning. I also did a .575 AGD-1 so there's still a lot left.
In the second 1 wide gap exit, its faster to jump a bit earlier to get a push in the top corner, although this is barely significant (maybe 1-2 frames).
Great job, macro! Amazing that you took half a second off a level which is a bottleneck for the first half. I think "innovation" is a bit generous for both levels, especially the latter which is really a tweak and is a fairly axiomatic idea, but its elusiveness is due to the fact it relies on executing a tricky chimney 2000 frames into the run. Either way you slice it, both runs are deserving of credit. Also, I am now working full time, and most of the time I am not working will be used on editing and research for my book. Ergo, I am retiring from highscoring N permanently. I will still be active on the forums and numa, however.macrohenry wrote:22-1 from crappitrash. :) Added a tiny innovation on the left, but the rest is cleaning. I also did a .575 AGD-1 so there's still a lot left.
It's amazing that you manage to surprise us again and again with your new routes. Seriously amazing. I wonder how you do that. Keep it up. :) Took the highscore 0th with your route + Ep71 for "Occupy xaelar" and 71-4 in the process.alsojp27ace wrote:Taken 86-4 with a new route (and also took the speedrun).
nice! great route change on 86-4, jp. macro: for you should do my start for 71-1, your efficient corner-jump, and xaelar's polished ending...macrohenry wrote:Thanks, everyone. ska, although you wrote that you retired I still hope to see a few runs by you, even if it's just one per year. ;)
If you combined all those things, you would smash Eddy's 0th.
- Steam: What's Steam
Oh, wait. What is with these stupid misleading thread titles?
Personally, I'm always a fan when a woman wears Chanel No. 529403 wrote:"Obsession" for men.
Yeah, wow. Avoiding using the 1 tiles in each of the gold chambers and preemptively drifting left/right in the air to immediately do the WJ to get out and not clipping the corner on the way to the exit, doesn't seem like a lot but everything including the chimneys was faster. Well done.macrohenry wrote:Took 29-3 and 29-4. I'm surprised by how much I cleaned the ending in -3. As a side note, van is down to 10 0ths now.
Great runs macro, does that put me equal to van now? I've lost track of my 0th count.macrohenry wrote:Took 29-3 and 29-4. I'm surprised by how much I cleaned the ending in -3. As a side note, van is down to 10 0ths now.
I haven't been playing much recently except for some random top-20 runs, but I have still been lurking and I'm enjoying these column/game speedruns. I had a go at column 00 myself but some of the later levels (like 09-1) were annoying me too much. It would be nice to see some runs on some of the other columns too.
You're 3rd. :)alsojp27ace wrote:Great runs macro, does that put me equal to van now? I've lost track of my 0th count.macrohenry wrote:Took 29-3 and 29-4. I'm surprised by how much I cleaned the ending in -3. As a side note, van is down to 10 0ths now.
Oh nice, looks like its time for occupy Kool then :pmacrohenry wrote:You're 3rd. :)alsojp27ace wrote:Great runs macro, does that put me equal to van now? I've lost track of my 0th count.macrohenry wrote:Took 29-3 and 29-4. I'm surprised by how much I cleaned the ending in -3. As a side note, van is down to 10 0ths now.
Although looking at his remaining 0ths they are all crazy clean.
Also take a look at this that I got while starting the ep run:
Didn't know it was possible to go too fast. Does that mean that we'll end up with an upper limit here?
It could be possible to lure the drone down at this point, but I'm not sure:golf wrote:This thread has been looking a bit dead lately. Let's liven it up. Took 77-0 in my new episode run. Would have had the ep 0th as well but I hate 77-2...
However, great run and congrats on the 0th!
Took Ep13 yesterday. The only remaining eru 0th now is Ep37, but I'll leave this one to Eddy. :P
You were close to the ep, I think I'll have to improve it to my 2014 standards to feel alright with myself hahah :P
@macro: Damn, eru is about to fall! I'll attack that ep soon after I finish my exams (this wednesday!)
You know, even with exams going on, I was still expecting to see a new episode 0th by the time I woke up this morning lol. Glad to hear exams are almost over for you, maybe you'll be able to find time again to join us on irc. macro's been showing up every once in a while the last couple weeks, but we've been missing the reigning grandmaster. Besides, you've got a milestone coming up... 20 days until you pass xela's record for longest continuous time as grandmaster. Unless we institute an emergency Occupy Eddy movement.EddyMataGallos wrote:Hey, nice run golf, getting close to max there. Definitely, the fact that there was a bottleneck at the end of 77-0 without luring the drone was something clear, remember you can even avoid that very last slope jump, if you do a proper pl. Not enough to beat the drone of course.
- RoboBarber
Thanks, I was going to ask (as I saw above that I had 2 0th).macrohenry wrote:Took Ep13 yesterday. The only remaining eru 0th now is Ep37, but I'll leave this one to Eddy. :P
Ep 37 doesn't stand a chance (especially with the latest -4 innov'), unlike ep 13 from which you "only" managed to save 2 seconds using the innov' on -3 (I was expecting you to save at least an extra second on -2).
