N2High Save Files Upload Thread
Moderator: EddyMataGallos
Postby shomman » 2015.08.06 (01:36)
Had the idea of the History of a 0th on the N2High suggestions thread, and Eddy said he would be able to do it but we'd need a lot of save files to make it worth while.
I've found that the forums don't allow .hs2 files to be uploaded. Does anyone have any suggestions of how we can do this? Sidke has unlocked this so thanks
If everyone could upload their .hs2 files that'd be awesome.
And click to see the list of my personal 6 favourite features to put in n2high :)
Total Level Score (including only top 10's) - would mainly be something of interest
Ska mentioned in september 2013 - When exporting a "no ties" 0th rankings, even though your program says "0th rankings (no ties).txt" the file I got was just "0th rankings.txt" which replaced my existing file. A very minor thing, but nevertheless something you might want to fix on your next version. Cheers!
Overall top 10 changes - Just include all improvements - People can look at the level and notice if they have gone down. Otherwise it'll be too big, as you said.
The ability to create lists of of "Episode Mediocrities" and "Episode Sets", as per this thread
forum.droni.es/viewtopic.php?f=72&t=10270&p=173394&hilit=mediocrity#p173394
top 5 rankings as a separate function
top 3 rankings as a separate function
25-2-15.hs2
(177.9 KiB) Downloaded 1399 times
06-02-15.hs2
(177.83 KiB) Downloaded 1317 times
23-01-15.hs2
(177.33 KiB) Downloaded 1463 times
1-12-14.hs2
(175.96 KiB) Downloaded 1391 times
8-11-14.hs2
(175.47 KiB) Downloaded 1400 times
Stats
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
2.5 Average Rank (3rd)
1 Episode Ownage b5 :):(
Other Stuff
Image Thanks Nyan!
Postby oxymoron93 » 2015.08.06 (12:52)
I will add more after another post.
Also, sho, you accidentally upload same score file twice. And the more crazier thing is that score file you attached is actually score file that exist in N2high folder, and it is called scores2.hs2. xD
20141228.hs2
(176.77 KiB) Downloaded 1351 times
20141220.hs2
(176.66 KiB) Downloaded 1407 times
20141217.hs2
(176.57 KiB) Downloaded 1346 times
20141215.hs2
(176.53 KiB) Downloaded 1351 times
20141214.hs2
(176.51 KiB) Downloaded 1396 times
Postby shomman » 2015.08.06 (22:45)
Ah ok yeah I was just testing while sidke was trying to get it working.
Uploaded my 5 earliest on previous.
7-03-15.hs2
(178.01 KiB) Downloaded 1387 times
2-03-15.hs2
(178.07 KiB) Downloaded 1332 times
1-03-15.hs2
(178.06 KiB) Downloaded 1297 times
28-02-15.hs2
(178.05 KiB) Downloaded 1411 times
26-02-15.hs2
(177.92 KiB) Downloaded 1252 times
Stats
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
Other Stuff
Image Thanks Nyan!
Postby shomman » 2015.08.06 (22:47)
5 more
16-03-15.hs2
(178.25 KiB) Downloaded 1373 times
14-03-15.hs2
(178.17 KiB) Downloaded 1442 times
11-03-15.hs2
(178.06 KiB) Downloaded 1354 times
9-03-15.hs2
(178.02 KiB) Downloaded 1402 times
8-03-15.hs2
(178.02 KiB) Downloaded 1364 times
Stats
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
Other Stuff
Image Thanks Nyan!
Postby oxymoron93 » 2015.08.07 (00:29)
5 more
20150610.hs2
(179.28 KiB) Downloaded 1347 times
20150606.hs2
(179.17 KiB) Downloaded 1406 times
20150413.hs2
(178.47 KiB) Downloaded 1382 times
20150322.hs2
(178.31 KiB) Downloaded 1410 times
20150222.hs2
(177.83 KiB) Downloaded 1326 times
Postby oxymoron93 » 2015.08.07 (00:35)
5 more to round up my scores files from June. xD
20150629.hs2
(179.52 KiB) Downloaded 1348 times
20150627.hs2
(179.52 KiB) Downloaded 1343 times
20150626.hs2
(179.48 KiB) Downloaded 1364 times
20150625.hs2
(179.49 KiB) Downloaded 1419 times
20150616.hs2
(179.41 KiB) Downloaded 1374 times
Postby shomman » 2015.08.07 (01:59)
Finished March started April.
I've got almost daily files at some points from April on
03-04-15.hs2
(178.44 KiB) Downloaded 1378 times
29-03-15.hs2
(178.41 KiB) Downloaded 1288 times
25-03-15.hs2
(178.35 KiB) Downloaded 1301 times
19-03-15.hs2
(178.27 KiB) Downloaded 1361 times
19-03-15.hs2
(178.27 KiB) Downloaded 1311 times
Stats
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
Other Stuff
Image Thanks Nyan!
Postby shomman » 2015.08.07 (02:01)
Each post requires words.
12-04-15.hs2
(178.48 KiB) Downloaded 1292 times
11-04-15.hs2
(178.46 KiB) Downloaded 1342 times
10-04-15.hs2
(178.46 KiB) Downloaded 1328 times
09-04-15.hs2
(178.46 KiB) Downloaded 1313 times
09-04-15.hs2
(178.46 KiB) Downloaded 1285 times
Stats
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
Other Stuff
Image Thanks Nyan!
Postby shomman » 2015.08.07 (02:03)
Almost finished April
23-04-15.hs2
(178.57 KiB) Downloaded 1285 times
21-04-15.hs2
(178.56 KiB) Downloaded 1269 times
15-04-15.hs2
(178.5 KiB) Downloaded 1307 times
14-04-15.hs2
(178.49 KiB) Downloaded 1242 times
12-04-15 (2).hs2
(178.48 KiB) Downloaded 1279 times
Stats
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
Other Stuff
Image Thanks Nyan!
Postby shomman » 2015.08.07 (02:05)
Into May
12-05-15.hs2
(178.82 KiB) Downloaded 1260 times
10-05-15.hs2
(178.81 KiB) Downloaded 1396 times
04-05-15.hs2
(178.74 KiB) Downloaded 1293 times
03-05-15.hs2
(178.73 KiB) Downloaded 1386 times
25-04-15.hs2
(178.67 KiB) Downloaded 1266 times
Stats
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
Other Stuff
Image Thanks Nyan!
Postby shomman » 2015.08.07 (02:21)
Almost Finished May.
June july is the most hectic i think
25-05-15.hs2
(178.88 KiB) Downloaded 1196 times
24-05-15.hs2
(178.88 KiB) Downloaded 1247 times
18-05-15.hs2
(178.85 KiB) Downloaded 1402 times
12-05-15.hs2
(178.82 KiB) Downloaded 1261 times
10-05-151.hs2
(178.81 KiB) Downloaded 1295 times
Stats
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
Other Stuff
Image Thanks Nyan!
Postby shomman » 2015.08.07 (02:23)
May Finished exactly. How Neat.
31-05-15.hs2
(179.02 KiB) Downloaded 1330 times
30-04-15.hs2
(178.98 KiB) Downloaded 1324 times
28-05-15.hs2
(178.94 KiB) Downloaded 1363 times
27-05-15.hs2
(178.94 KiB) Downloaded 1209 times
26-05-15.hs2
(178.93 KiB) Downloaded 1378 times
Stats
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
Other Stuff
Image Thanks Nyan!
Postby oxymoron93 » 2015.08.07 (02:38)
My July.
20150713.hs2
(179.58 KiB) Downloaded 1346 times
20150711.hs2
(179.6 KiB) Downloaded 1331 times
20150710.hs2
(179.6 KiB) Downloaded 1378 times
20150709.hs2
(179.59 KiB) Downloaded 1235 times
20150701.hs2
(179.54 KiB) Downloaded 1351 times
Postby oxymoron93 » 2015.08.07 (02:41)
Some daily files from late July are coming.
20150724.hs2
(179.58 KiB) Downloaded 1295 times
20150723.hs2
(179.57 KiB) Downloaded 1330 times
20150722.hs2
(179.58 KiB) Downloaded 1387 times
20150721.hs2
(179.57 KiB) Downloaded 1338 times
20150720.hs2
(179.56 KiB) Downloaded 1309 times
Postby oxymoron93 » 2015.08.07 (02:43)
I was drunk on 26th...
20150730.hs2
(179.67 KiB) Downloaded 1429 times
20150729.hs2
(179.65 KiB) Downloaded 1267 times
20150728.hs2
(179.61 KiB) Downloaded 1383 times
20150727.hs2
(179.6 KiB) Downloaded 1304 times
20150725.hs2
(179.59 KiB) Downloaded 1306 times
Postby oxymoron93 » 2015.08.07 (02:46)
My latest 5 files. Yeah, I downloaded my latest just now, so I can upload 5 of them. xD
20150807.hs2
(179.69 KiB) Downloaded 1319 times
20150805.hs2
(179.71 KiB) Downloaded 1323 times
20150804.hs2
(179.71 KiB) Downloaded 1317 times
20150801.hs2
(179.69 KiB) Downloaded 1428 times
20150731.hs2
(179.68 KiB) Downloaded 1296 times
Postby shomman » 2015.08.07 (08:32)
The very similar titles are ones that are in the same day. 07-06-15 comes before 7-06-15 in the day etc.
7-06-15.hs2
(179.19 KiB) Downloaded 1331 times
07-06-15.hs2
(179.19 KiB) Downloaded 1311 times
6-06-15.hs2
(179.17 KiB) Downloaded 1305 times
06-06-15.hs2
(179.16 KiB) Downloaded 1326 times
03-06-15.hs2
(179.1 KiB) Downloaded 6259 times
Stats
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
Other Stuff
Image Thanks Nyan!
Postby shomman » 2015.08.07 (08:35)
4 Save files from the 8th of June! Something must have happened that day. Maybe that was cooper getting grandmaster day.
09-06-15.hs2
(179.24 KiB) Downloaded 1279 times
8-6-15.hs2
(179.19 KiB) Downloaded 1312 times
8-06-15 (2).hs2
(179.2 KiB) Downloaded 1318 times
8-06-15.hs2
(179.19 KiB) Downloaded 1372 times
08-06-15.hs2
(179.18 KiB) Downloaded 1355 times
Stats
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
Other Stuff
Image Thanks Nyan!
Postby shomman » 2015.08.07 (08:37)
Tick Tock
14-06-15.hs2
(179.39 KiB) Downloaded 1299 times
13-6-15.hs2
(179.35 KiB) Downloaded 1233 times
13-06-15.hs2
(179.34 KiB) Downloaded 1398 times
12-06-15.hs2
(179.32 KiB) Downloaded 1350 times
11-06-15.hs2
(179.29 KiB) Downloaded 1296 times
Stats
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
Other Stuff
Image Thanks Nyan!
Postby shomman » 2015.08.07 (08:38)
On the clock.
24-06-15.hs2
(179.5 KiB) Downloaded 1224 times
18-06-15.hs2
(179.43 KiB) Downloaded 1195 times
16-06-15.hs2
(179.43 KiB) Downloaded 1297 times
15-06-15.hs2
(179.41 KiB) Downloaded 1391 times
14-6-15.hs2
(179.39 KiB) Downloaded 1315 times
Stats
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
Other Stuff
Image Thanks Nyan!
Postby shomman » 2015.08.08 (00:42)
26th to the 7th I was on holidays :)
18-07-15.hs2
(179.55 KiB) Downloaded 1301 times
17-07-15.hs2
(179.55 KiB) Downloaded 1272 times
13-07-15.hs2
(179.6 KiB) Downloaded 1385 times
7-07-15.hs2
(179.58 KiB) Downloaded 1308 times
26-06-15.hs2
(179.48 KiB) Downloaded 1347 times
Stats
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
Other Stuff
Image Thanks Nyan!
Postby shomman » 2015.08.08 (00:44)
Finished July. Now just a few from August.
30-07-15.hs2
(179.67 KiB) Downloaded 1445 times
28-07-15.hs2
(179.61 KiB) Downloaded 1255 times
26-07-15.hs2
(179.59 KiB) Downloaded 1314 times
21-07-15.hs2
(179.56 KiB) Downloaded 1337 times
18-7-15.hs2
(179.56 KiB) Downloaded 1252 times
Stats
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
Other Stuff
Image Thanks Nyan!
Postby shomman » 2015.08.08 (00:46)
Just a few to go.
05-08-15.hs2
(179.71 KiB) Downloaded 1325 times
04-08-15.hs2
(179.71 KiB) Downloaded 1239 times
3-08-15.hs2
(179.7 KiB) Downloaded 1342 times
03-08-15.hs2
(179.69 KiB) Downloaded 1294 times
01-08-15.hs2
(179.69 KiB) Downloaded 1291 times
Stats
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
Other Stuff
Image Thanks Nyan!
Postby shomman » 2015.08.08 (04:10)
Finally Finished.
08-08-15.hs2
(179.7 KiB) Downloaded 1292 times
7-08-15.hs2
(179.7 KiB) Downloaded 1364 times
07-08-15.hs2
(179.7 KiB) Downloaded 1289 times
06-08-15.hs2
(179.71 KiB) Downloaded 1307 times
Stats
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
Other Stuff
Image Thanks Nyan!
NUMA Profile: http://nmaps.net/user/XandoToaster
Steam: www.steamcommunity.com/id/XandoToaster
Postby XandoToaster » 2015.08.11 (05:52)
shomman, oh my god, have you ever heard of zip files
I formatted my titles as "scoresyyyy-mm-dd" so that when they're organized alphabetically, they'll also be organized chronologically. I have 26 files from November of 2014 through August of 2015. It's probably not as complete as shomman's collection, but it may fill in some gaps.
scores.zip
(1.06 MiB) Downloaded 1271 times
Today is just a really good day, ya know?
2nd place in Npoints Season 3
Nv2 Column Run King
