Moderator: EddyMataGallos
Took a4-1 with a drone-beating route. Took by 50 frames. Some really close and tough calls there, especially in the middle top room. Argh. Tried to improve and got +1 frame :/
Passed 75 0ths yay! How long until oxy brings me down?
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
2.5 Average Rank (3rd)
1 Episode Ownage b5 ![]()
Thanks Nyan!
Good job for taking 23-3, I won't try that one. I didn't like that level at all, I just did it cause i wanted to try that way of ending. It definitely wasn't awesome run, which you showed by taking it with more than 10 frames!
Great a9-0 too. You did faster ending that is good. You can check "132502", which I made long ago, for even faster endings. Tho difference between Meta, who did corner jump, and spin who did it the same way you did, is just 4 frames! That is the reason I never tried faster endings, cause It wouldn't give me much with my slow run during the whole run before last jumps. Maybe I could try, someday but definitely not soon.
And, finest for the end! a4-1 is so exceptional, awesome work there. You shouldn't worry about that one. I don't take levels where new routes are added. I have some kind of respect for such runs!
Retaken 25-1, where jp added new, harder, beginning. Everything else I did the same way as before. jp27's run is different again, but I can say it is various of the route you and I did.
[Edit] Retaken 25-1 again!
Oh yeah, I had 97 (13 tied) 0ths. Which is my max for now. Unfortunately I wasn't on my PC, so I don't have that score file. I also didn't have time to send it to my mail or some other way to save it. Just to mention that. I am downloading scores now. And if nothing else is changed I should have 96 (13) 0ths! xD
[Edit] I believe I have 98 0ths atm. Can't download scores over here, cause I am still in student dorm, where internet is weak.
[Edit #2] 100 0ths!!! I want confirmation from someone who can download scores? (pls, don't take any 0ths of mine before that xD)
100 0ths milestone achieved! :D
0th Rankings as of Tue Sep 15 14:00:44 2015
0th cooperverdon - 191 [39 ties]
1st EddyMataGallos - 146 [19 ties]
2nd oxymoron93 - 100 [13 ties]
3rd SpartaX18 - 85 [43 ties]
4th shomman - 76 [ 7 ties]
Yep, in a1-2 is definitely possible to get into top right room with gold, without using additional walljump! Then drones can become problem, when you try to enter into top left room with gold, cause they could detect you and make you a problem when you try to leave the that room.
Also, taken b7-0. That jp27's 0th was the longest remaining one in b column and the only one that hasn't changed since July 28th 2013. Yep, the date of the oldest score file we have!
[Edit] I just noticed that a1-2 0th held before by Eddy, was the only one in a column that hasn't changed since our oldest score has been made! xD
And, 0th (with ID=100 xD) is, again, taken from jp27. New route on b8-4!
Yes that's possible in a1-2. I pulled it off 5+ times and every time it caused drones to follow me into top left room! So annoying! I won't try and take that level.
Nice route. Impressive. I'm glad that all the 0ths are becoming newer.
Level with ID=100 is 19-4. Cooper has that level - what level did you mean?
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
Thanks Nyan!
500 that's crazy. I didn't know you were so close.
Again: Oxy for grandmaster. You're the best dude.
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
Thanks Nyan!
Shomman, I noticed your parole before, too. It made me laugh. xD I don't believe I have time nor skill to become new grandmaster. Many coop's 0ths are great, and only Spartax18 can compete him there. Number of maps where I can fight for 0ths and where you don't have a 0th are slowly dropping down. xD
Tho, thanks for thinking like that! xD
Taken 85-3 and tied 91-4. It turned out not to be hard to tie it, just 100s of tries and almost same number of mistakes in last jump...
As for 85-3, you shomman or anybody else can see what I modified in previous route so it is now easier to begin and to be faster. Even to beat the drone before taking exit key. Unfortunately, I don't get much that way cause of my sloppiness in that run. You all can try to take it to the next level, as I will try, too. Even to add something new, or some other route!
[Edit] OK, I managed to find new route on 85-3 that fits great to the innovs I added. xD
- Gross
jp27ace wrote:Nice runs Oxy, gratz on the 100 0ths. I've lost a lot of 0ths since I last played, and it looks like you are one of the main reasons :p
Retaken b7-0 and b8-4, and also took a4-3, a6-3, b3-0 and b5-1.
Edit: Retaken b7-0 again, taken b7-1, b7-4 and a1-2.
Fucking hell I got wrecked.
Took my ownage as well goddammit.
Good to have you back
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
Thanks Nyan!
These days I were studying for some easy exams, so I didn't play much. I was getting few 0th, which will be listed below. xD
New route on 92-0, for gaining 80 frames. Yep , a lot! I easily got it, didn't considered improving slow parts of the route.
Small change in 27-4, for getting 15 frames ahead of Eddy. It is possible to be even faster, with hitting roof near the end. Also, there could be kinda ~20 frames improvement, if you could somehow collect last pieces of gold with falling to the right bounce block (instead of falling to the left and doing walljump) and sliding on his side. I did do it only once in my run with missing one piece of gold (that piece was irrelevant for that route, I just missed it even before getting exit key, bummer).
Also, new route on 87-1, easier for me. kkstrong is down to 12 0ths. It could be improved, cause i did make some small mistakes. Also I have another route in mind, but it will have to wait.
Barely got 87-2 from Eddy. One frame.
According to the score files we have, I am on the 4th(5th) place among players with highest amount of 0ths ever held! With 105 0ths! jp27 had 104, tho score files from that period of time are far away from each other (Eddy is the only source), so jp maybe got few more and before getting next score file, he managed to lost even more, ending with less than 104. But we don't have proof of that!
I have really important exam in 10 days, and I wont play nor do anything else related to N in that time!
Sho, make b5, yours again! xD
- Gross
According to the highscore rankings I had 150 0ths (probably more at one point).oxymoron93 wrote:According to the score files we have, I am on the 4th(5th) place among players with highest amount of 0ths ever held! With 105 0ths! jp27 had 104, tho score files from that period of time are far away from each other (Eddy is the only source), so jp maybe got few more and before getting next score file, he managed to lost even more, ending with less than 104. But we don't have proof of that!
Of course this was back when some of the levels didn't even have 10 top 10 scores, so not really very impressive :p
;( so hard. jp so good.oxymoron93 wrote:Sho, make b5, yours again! xD
Also, jp - I just watched your b7-4. That run is absolutely fucking incredible. So many close calls. There's no way I'm getting that back.
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
Thanks Nyan!
It's been great fun competing with you oxy - thanks for the fun :)
I'll just be playing userlevels when I do play, and I'll still be checking forums.
Edit: Eddy's average rank is over 2! First time!!
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
Thanks Nyan!
Oh boy, I remember when it was 0.4th xD Maybe some day I'll come back, but there's still a lot of stuff I have to do in v1.4 :Pshomman wrote:Edit: Eddy's average rank is over 2! First time!!
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
Thanks Nyan!
Since i've had no internet recently I've been playing through the episodes of Nv2 offline, and found a slight innov for 46-0 which I have just taken, using a Low Jump. In my offline run I got 74 though, so there's definitely room to improve.
I'm bad at not playing N
Edit: Tied 39-1 (Thanks for suggestion Toast). I won't take that off you oxy :P. (Mostly because I probably can't)
Edit 2: Took 87-1. I can't seem to help myself dammit.
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
Thanks Nyan!
...And 56 till grandmaster :/
EDIT: Also reached 3th place in avg. rank rankings (with 2.265th) and reached 1500 points somewhere in the past (now having 1632), still 6th place though.
- Gross
Very nice changes on 04-1, retaken for now. Also took 05-1 and 05-2.XandoToaster wrote:I took 0th on 04-1, but it was a bad run, and I'm sure that significant innovations can be made on it, so we'll see how long that lasts. I also got top 10s on 04-0, 04-2, and 04-3, and I already had 0th on 04-4. So, I now have a mediocrity with two 0ths. This is probably the closest I'll ever get to an ownage, so I'm pretty happy about this.
05-1 uses a pretty obvious innov, I'm surprised it wasn't being used already. Not a great run so I doubt I'll hold it for long.
Edit: oxy took 05-1 :/
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
Thanks Nyan!
Took 41-1, 41-4* one of the oldest 0ths I know of.
82 0ths (4th)
412 Top 10's (3rd)
360 Top 5's (1st)
3086 Points (2nd)
Thanks Nyan!
