The Highscore Rankings
For future reference:ska wrote:Bit of a random question, but what (and when) was Last_FairyTail's peak 0th and top-20 count? I'm guessing it was sometime during 2011. Just cleaning up a few Wiki pages out of boredom. I'm sure I could find out using that Excel spreadsheet (or NHigh) records, but I'm hoping someone has an easier solution.
A reminder: In order to use this function, you have to put your NHigh files inside a folder named "scores" in NHigh's folder. I did it with all the 2011 files we put together, and found this:
0th evolution over time for Last_FairyTail
2011-01-03 - 0
2011-01-03 - 0
2011-01-03 - 0
2011-01-10 - 0
2011-01-10 - 0
2011-01-10 - 0
2011-01-11 - 0
2011-01-14 - 1
2011-01-15 - 1
2011-01-17 - 1
2011-01-18 - 2
2011-01-24 - 3
2011-01-31 - 3
2011-02-04 - 3
2011-02-06 - 3
2011-02-07 - 3
2011-02-14 - 5
2011-02-21 - 5
2011-02-28 - 5
2011-03-14 - 6
2011-03-17 - 6
2011-03-19 - 7
2011-03-21 - 7
2011-03-27 - 7
2011-03-28 - 7
2011-04-03 - 7
2011-04-04 - 7
2011-04-04 - 7
2011-04-07 - 7
2011-04-10 - 7
2011-04-11 - 7
2011-04-11 - 7
2011-04-16 - 7
2011-04-18 - 7
2011-04-20 - 7
2011-04-25 - 7
2011-05-01 - 7
2011-05-02 - 7
2011-05-09 - 7
2011-05-17 - 7
2011-05-19 - 7
2011-05-23 - 7
2011-05-29 - 7
2011-06-06 - 7
2011-06-20 - 7
2011-07-22 - 7
2011-07-30 - 7
2011-07-31 - 7
2011-09-07 - 7
2011-09-15 - 7
2011-11-01 - 7
2011-11-01 - 7
2011-11-09 - 8
2011-11-10 - 8
2011-11-15 - 7
2011-11-20 - 7
2011-11-22 - 7
2011-11-25 - 7
2011-11-26 - 7
2011-12-05 - 7
2011-12-06 - 7
2011-12-06 - 7
2011-12-09 - 7
2011-12-10 - 7
2011-12-17 - 7
2011-12-17 - 7
2011-12-23 - 7
2011-12-27 - 7
List of 0th scores for Last_FairyTail:
00-0 - 252.550
01-1 - 199.050
20-1 - 139.725
27-2 - 113.900
34-1 - 141.575
44-1 - 158.400
50-0 - 164.625
97-0 - 100.775
Total: 8 0th scores
- Doublemember
Indeed, they all look legit. I'd say it's a veteran, I woudn't expect this kind of game in 2018 but I like it hah.zapkt wrote:Who is this Donald_J_Trump? He/She got a few impressive scores recently (see http://ploudseeker.com:5000/new ). At first I thought it was a hacker that should be removed from the board because tying 00-0's 0th is not something you would expect from a new player, but the run looks legit.
I'm dissapointed he's not using NReality though, that's necessarily going to raise suspicion, because of course, you could just slow down the game and cheat in a reasonable manner, avoiding frame-perfect chimneys, tricks and reflexes to avoid the run looking suspicious. For instance, just to deliberately try to find something suspicious and being picky, what do you think about his final ascent in 00-2, the way he remains so close to the thwump? Seems maybe too daring and unnecesary in real time?
If DJT is actually a cheater, he's hiding it very well. More to the point, why would you bother? Additionally, he went from 252.850 to 252.975 to 253.000 on 00-0. The run looks plasible, and multiple improvements like that are a good sign of legitimacy. I don't suppose anyone has the demos for previous runs? I'd like run some comparisons for science.EddyMataGallos wrote:Indeed, they all look legit. I'd say it's a veteran, I woudn't expect this kind of game in 2018 but I like it hah.zapkt wrote:Who is this Donald_J_Trump? He/She got a few impressive scores recently (see http://ploudseeker.com:5000/new ). At first I thought it was a hacker that should be removed from the board because tying 00-0's 0th is not something you would expect from a new player, but the run looks legit.
I've done a visual comparison (i.e., haven't looked into keypresses) between all three submitted runs. They are all different in terms of exection. This isn't an exoneration, of course, but it does mean that he didn't just tweak his run MBD style by dupplicating part(s) of his run. I will say, though, that it's impressive that he was able to do those ceiling jumps down the bottom. It's definitely plausible, though, if he grinded the level for hours (which the timestamps hint at).
As I said there's nothing to critizice from the apparent legitimacy. The kind of cheating expected would be just slowing down the game though, so strictly speaking, none of those arguments (irregularity of the runs, progresive improvement,...) would be valid.ska wrote:I've done a visual comparison (i.e., haven't looked into keypresses) between all three submitted runs. They are all different in terms of exection. This isn't an exoneration, of course, but it does mean that he didn't just tweak his run MBD style by dupplicating part(s) of his run. I will say, though, that it's impressive that he was able to do those ceiling jumps down the bottom. It's definitely plausible, though, if he grinded the level for hours (which the timestamps hint at).
I might check on the discord server to see if people know this guy, maybe he's an N++ player that hasn't heard about NReality.
Okay. I think it's vankusss.EddyMataGallos wrote:As I said there's nothing to critizice from the apparent legitimacy. The kind of cheating expected would be just slowing down the game though, so strictly speaking, none of those arguments (irregularity of the runs, progresive improvement,...) would be valid.ska wrote:I've done a visual comparison (i.e., haven't looked into keypresses) between all three submitted runs. They are all different in terms of exection. This isn't an exoneration, of course, but it does mean that he didn't just tweak his run MBD style by dupplicating part(s) of his run. I will say, though, that it's impressive that he was able to do those ceiling jumps down the bottom. It's definitely plausible, though, if he grinded the level for hours (which the timestamps hint at).
- Doublemember
Oh.Date Level Player Place Score Previous score Previous score's date
2018-07-31 01:17:02 00-0 Donald_J_Trump 0 253.050 253.000 2018-07-28 19:17:02
Wow. I suppose the question is... will Eddy take it back? The end of DJT's run looks improvable when compared to Eddy's.zapkt wrote:Oh.Date Level Player Place Score Previous score Previous score's date
I guess you could say that Donald J Trump is making N great again.
I can confidently say it's not me since I cannot even run N at the moment. Plus I would suck anyway.ska wrote:Okay. I think it's vankusss.
vankusss wrote:I can confidently say it's not me since I cannot even run N at the moment. Plus I would suck anyway.ska wrote:Okay. I think it's vankusss.
What's up with this? I thought this page had 1.4 records? Where can they be found? I know they have existed... do they still exist?
Well it only took me like 3 years, but I did a second thing :PEddyMataGallos wrote: ↑2016.01.01 (03:18)Anyway, that means toaster is now in the 0th rankings, tied 11th no less. I hope to see some more activity from him in the future.
I took 0th on 06-0 by a frame. I was really surprised the old 0th didn't already do the faster start method that several highscore runs, the speedrun 0th, and the episode 0th all use.
Also ska, was this the page you were looking for? viewtopic.php?f=20&t=9214
nevermind, I see the issue. The SRC page at some point was renamed to https://www.speedrun.com/n_way_of_the_ninja_v1.4
Wow! Xando from the wild blue yonder! How many Metanet 0ths do you have? When was the last new Metanet 0th? This 0th looks surpsingly suboptimal. I think Eddy can make a couple of improvements and breach 174 with an ultra-clean run. My tip for his next run is 173.925.XandoToaster wrote: ↑2019.06.30 (07:44)Well it only took me like 3 years, but I did a second thing :PEddyMataGallos wrote: ↑2016.01.01 (03:18)Anyway, that means toaster is now in the 0th rankings, tied 11th no less. I hope to see some more activity from him in the future.
And thanks for the new page URL; it was really confounding me.
That's because all those runs are more recent than my (ex-)0th. When I took it in 2012, the hs 0th was xela's 2008 run, the sr 0th was kryx's 2009 run, and the ep 0th was eru's 2010 run, neither of which use it. In fact, I have checked many other highscore runs and I haven't found one earlier than my ex-0th which uses it :P You can see that a few runs appear in sr mode in July 2012 which use it (jp, OJ and Kool), and my ep 0th from November 2012 already uses it, which suggests to me that this beginning appeared there, after my level 0th. I even have a faint memory of it.XandoToaster wrote: ↑2019.06.30 (07:44)Well it only took me like 3 years, but I did a second thing :PEddyMataGallos wrote: ↑2016.01.01 (03:18)Anyway, that means toaster is now in the 0th rankings, tied 11th no less. I hope to see some more activity from him in the future.
But anyway, nice job cleaning this one, I really like this level ;) 174 is definitely possible. Answering ska, I'd enjoy going back to v1.4 and taking some 0ths, but switching between games is a pain because you have to rewire your muscle memory to the new physics, which means that it's not worth it to go back and forth, only long term switches make sense, because I'd have to spend several sub-optimal days until I was at top level again. Which is not to say I'll never do it again, I might do it at some point when I'm satisfied with what I've done in N++ (it probably will happen eventually, but also probably not soon).
Also I agree there's a ton of frames left. I've been busy, but I'd still like to go back and try to get 174 myself. I'm really not that happy with the run I got, despite being 0th. As for how many 0ths I have, this is my first untied 0th in 1.4, and I have a few top 20s (I think less than 10). I'd like to see if I can get any other 0ths though. This one was fun!
Yeah, I didn't recall you submitting much to the highscore boards. It's good to see you around! I also completely understand what Eddy's saying. You can go from trash to competent fairly quickly, but getting to that final level of cleanliness needed to take a 0th usually takes a bit of a grind.XandoToaster wrote: ↑2019.07.03 (20:47)That's fair. Let me rephrase my point: I'm surprised that macrohenry didn't take 0th with that innovation whenever he got his run.
Well done, Xando! Looking forward to seeing more from you. Probably not going to attack this one, I was never a huge fan of this level.
