What's on your copy right now
Commodus
Postby Rule » 2008.11.23 (18:12)
http://nmaps.net/146314
That leads to this btw;
Nmaps.net ^^
Postby bufar » 2008.11.23 (18:51)
It's a Very Cool DDA:
Postby Vyacheslav » 2008.11.23 (21:07)
Postby bufar » 2008.11.23 (21:26)
Wizard Dentist
Postby SkyPanda » 2008.11.24 (11:22)
Commodus
Postby Rule » 2008.11.24 (19:15)
www.vandale
Yeah I know ^^
But it's a site of a dictionary. Used it for my homework lolz
Postby beethoveN » 2008.11.25 (16:00)
yeah, still in progress.
If we shadows have offended,
William Shakespeare
Commodus
Postby Rule » 2008.11.25 (17:36)
Why Me
Postby isaacx » 2008.11.25 (17:39)
1 - Rock is for Rookies
In RPS circles a common mantra is "Rock is for Rookies" because males have a tendency to lead with Rock on their opening throw. It has a lot to do with idea that Rock is perceived as "strong" and forceful", so guys tend to fall back on it. Use this knowledge to take an easy first win by playing Paper. This tactic is best done in pedestrian matches against someone who doesn't play that much and generally won't work in tournament play.
2 - Scissors on First
The second step in the 'Rock is for Rookies' line of thinking is to play scissors as your opening move against a more experienced player. Since you know they won't come out with rock (since it is too obvious), scissors is your obvious safe move to win against paper or stalemate to itself.
3 - The Double Run
When playing with someone who is not experienced at the RPS, look out for double runs or in other words, the same throw twice. When this happens you can safely eliminate that throw and guarantee yourself at worst a stalemate in the next game. So, when you see a two-Scissor run, you know their next move will be Rock or Paper, so Paper is your best move. Why does this work? People hate being predictable and the perceived hallmark of predictability is to come out with the same throw three times in row.
4 - Telegraph Your Throw
Tell your opponent what you are going to throw and then actually throw what you said. Why? As long as you are not playing someone who actually thinks you are bold enough to telegraph your throw and then actually deliver it, you can eliminate the throw that beats the throw you are telegraphing. So, if you announce rock, your opponent won't play paper which means coming out with that scissors will give you at worst a stalemate and at best the win.
5 - Step Ahead Thinking
Don't know what to do for your next throw? Try playing the throw that would have lost to your opponents last throw? Sounds weird but it works more often than not, why? Inexperienced (or flustered) players will often subconsciously deliver the throw that beat their last one. Therefore, if your opponent played paper, they will very often play Scissors, so you go Rock. This is a good tactic in a stalemate situation or when your opponent lost their last game. It is not as successful after a player has won the last game as they are generally in a more confident state of mind which causes them to be more active in choosing their next throw.
6 - Suggest A Throw
When playing against someone who asks you to remind them about the rules, take the opportunity to subtly "suggest a throw" as you explain to them by physically showing them the throw you want them to play. ie "Paper beats Rock, Rock beats scissors (show scissors), Scissors (show scissors again) beats paper." Believe it or not, when people are not paying attention their subconscious mind will often accept your "suggestion". A very similar technique is used by magicians to get someone to take a specific card from the deck.
7 - When All Else Fails Go With Paper
Haven't a clue what to throw next? Then go with Paper. Why? Statistically, in competition play, it has been observed that scissors is thrown the least often. Specifically, it gets delivered 29.6% of the time, so it slightly under-indexes against the expected average of 33.33% by 3.73%. Obviously, knowing this only gives you a slight advantage, but in a situation where you just don't know what to do, even a slight edge is better than none at all.
8 - The Rounder's Ploy
This technique falls into more of a 'cheating' category, but if you have no honour and can live with yourself the next day, you can use it to get an edge. The way it works is when you suggest a game with someone, make no mention of the number of rounds you are going to play. Play the first match and if you win, take it is as a win. If you lose, without missing a beat start playing the 'next' round on the assumption that it was a best 2 out of 3. No doubt you will hear protests from your opponent but stay firm and remind them that 'no one plays best of one for a kind of decision that you two are making'. No this devious technique won't guarantee you the win, but it will give you a chance to battle back to even and start again.
Commodus
Postby Rule » 2008.11.25 (17:40)
Why Me
Yeah still the same lolz
Postby Xious » 2008.11.25 (18:58)
http://www.youtube.com/watch?v=iHCImrWfBWg
A rockband vid I was watching, not sure why it was on my paste
Postby MattKestrel » 2008.11.25 (19:06)
Postby beethoveN » 2008.11.26 (17:10)
yeah, a longer version.
William Shakespeare
Commodus
Postby Rule » 2008.11.27 (16:00)
A demo data to some kind of map
Postby MattKestrel » 2008.11.27 (17:43)
Postby Brocerius » 2008.11.27 (18:26)
Lemme in already
I was briefly perusing the classic forums...
-----=======Doubtlessly Dastardly=======-----
Postby Eiturlyf » 2008.11.27 (23:08)
Postby rambo5252 » 2008.11.28 (01:12)
Thanks Toasters for the siggy
Other sigs
ø„¸¨"°º¤ø„¸¸„ø¤º°" ¨¸„ø¤º°"¨
¨"°º¤ø„¸RAMBO ¸„ø¤º°"¨
¸„ø¤º°"¨¸„ø¤º°"¨¨"°º ¤ø„¸¨"°
Commodus
Postby Rule » 2008.11.28 (16:51)
http://nmaps.net/146995
My latest incomplete art.
Postby unoriginal name » 2008.11.28 (19:02)
Map tags for blufar.
Postby bufar » 2008.11.29 (03:26)
gloomp, even though it's Line Free Rider data (I think) please put it in map tags anyways.
PS: I like the track.
Postby Donfuy » 2008.11.29 (03:36)
Commodus
Postby Rule » 2008.11.29 (13:44)
haha, nice speech bufar :D
$Whiskey. Tango.
Latest map of heatwave.
Postby bufar » 2008.11.29 (16:44)
I don't recall playing this map.
Postby 29403 » 2008.11.29 (16:51)
It's One More Radiation
Users browsing this forum: No registered users and 38 guests
