Saves
Almost as Bad as One
Postby Jaybles » 2008.12.05 (17:22)
Hi everyone
Whenever I this game on a different computer from home, the episodes that I have completd don't save even when i log on.
At school when I play this I have 5 episodes completed ( yes I'm terrible at this game :P) on the computer I normally use, but if I change computers or use my home one i havnt got any completed at all, even when logged on to my account,
Does anyone know what the problem is, because I want to keep my progress whenever i play on a different computer.
Postby Spawn of Yanni » 2008.12.05 (17:47)
You want to read this.
If your school is anything like mine (and you don't have access to hidden folders and such) then you won't be able to get the file you need. Since you've only finished 5 episodes, it'd probably be best to start over at home. Keep playing, and you'll be able to finish them in no time.
Postby Jaybles » 2008.12.05 (20:29)
yeah I probably can't get into those files. My schools quite strict about that sort of thing.
can always try though
thanks
Postby rambo5252 » 2008.12.05 (21:14)
just redo them 5 episodes shouldnt take long.....specially if their the first 5
Thanks Toasters for the siggy
Other sigs
ø„¸¨"°º¤ø„¸¸„ø¤º°" ¨¸„ø¤º°"¨
¨"°º¤ø„¸RAMBO ¸„ø¤º°"¨
¸„ø¤º°"¨¸„ø¤º°"¨¨"°º ¤ø„¸¨"°
Postby isaacx » 2008.12.13 (17:21)
i'm guessing that if you'd wnat to access the C: folder, you can right click the start and then explore then go through the thing the SoY said above
Postby Tunco » 2009.02.13 (19:48)
Jaybles wrote:yeah I probably can't get into those files. My schools quite strict about that sort of thing.
Yeah,mine school is very strict about that too.
Postby blackbelmoral » 2009.02.17 (18:54)
but my school blocks all control panel. cant even change my mouse
YAR HAR!
X2
Sigs:
29403|?NicNac?| Kablamo
Postby golf » 2009.02.17 (20:22)
You don't need to get into the control panel to access the .sol file. If you can get to a My Documents type folder, you should be able to get to the .sol. The filepath for the folder your .sol is in is like so: C:\Documents and Settings\User\Application Data\Macromedia\Flash Player\#SharedObjects\(random letters and numbers)\localhost
The My Documents folder is C:\Documents and Settings\User\My Documents, so if you can get there, just replace "My Documents" with "Application Data" and go from there.
Postby George » 2009.02.18 (10:34)
Note: It's probably easier to type %Appdata% into explorer. Should be quicker and less confusing that way.
