Sound Problem.
The other night, as I was going to sleep, I put my Zune software on and listened to the entirety of Blink-182's Blink-182. I fell asleep listening to the album, and by the time I woke up, there was no more sound in my computer.
I'd been meaning to reformat because I wanted to dual-boot Kubuntu, so I figured if I was having a driver issue, this would be killing two birds with one stone.
However, after my reformat, I continue to not get any sound out of my speakers. If I go into "sounds" and look at the status, it shows the bar moving up and down, as if the computer genuinely believed sound was playing. I've checked the device manager and noticed no problems.
Finally, and here's the freak part, plugging earphones into my earphone jack does give me sound, but it is horribly distorted and crackly.
Please help! :?
For me it occured after a reformat, with which I was trying to repair a broken MBR. Has nothing to do with sound though, so I don't think that has anything to do with it.
Good them.
That is about what I was going to say.SlappyMcGee wrote:Toshiba just told me that my sound card probably melted.
- Cowboy Magician
- Cowboy Magician
Simple but faultless analysis.
N.B. This is also assuming that you tried the headphone and speakers from the same headphone/audio socket.
Maybe the sound card has just lost it's connection to the speakers and has a bad connection with the headphone slot.
Or, maybe the headphone slot runs dr
irectly to the Motherboard. Hahaha.
if your headphones don't use USB, the problem is your speakers.
- Cowboy Magician
That might be your problem!SlappyMcGee wrote:Vista
Seriously though, it might part of the problem considering 95% of my computer problems are caused by Vista and the other 5% I don't know what caused it, but it seems obvious to me that your speakers themselves- not the drivers or Vista- are broken. But before you give up hope:
I had a similar problem. I have a laptop. I have Vista. (Windows 7, please come out soon! I'm tired of stupid Vista).
No matter what I did, everything sounded like it was... well it's really hard to explain. Kind of like it was doing Mono sound in Stero, but not really. Kind of echoy without actually echoing if that makes sense. It just sounded... wrong. I plugged actual speakers in. Fine.
My solution? Shut down the computer. Start up the computer.
I guess a sound driver failed to load properly for some reason. Maybe it was HP. Maybe it was Vista. Maybe it was just a fluke. Haven't had that problem again though.
