how do you make user levels show up on the list
The Loneliest Number
Postby 47dragon » 2009.01.18 (23:14)
how do you make your user levels show up on the list
Postby 29403 » 2009.01.18 (23:19)
This should be in N Troubleshooting
And which list? If you want your userlevels on the userlevels list, add it at the bottom of the userlevels.txt file. Enclose it with $level name#author#type#{level data here}#
Postby Pixon » 2009.01.21 (00:03)
Moved to N troubleshooting.
Postby George » 2009.01.23 (14:33)
You must ensure the string &userdata= is located at the top of the document. Keep your userlevels below the string in the format 29403 has outlined.
What's also important is that the userlevels.txt file is located in the same folder as the N application.
Postby jim? » 2009.02.13 (00:11)
i copied the data from top box, enclosed in proper syntax, refreshed user level list on the game, but the level still didn't show on the game. any ideas?
Now this is my kind of shoe!\
Postby golf » 2009.02.13 (04:44)
Make sure the userlevels.txt file is in the same folder as the N flash file. Also, make sure that you entered the level data below the "&userlevels=". Beyond that, I don't know what else to say if that doesn't work.
Commodus
Postby Rule » 2009.02.13 (20:09)
You must close and re-open n-game to make sure the level is added.
Maybe this is your problem.
Postby Amadeus » 2009.02.15 (17:29)
I have been having the same problem
You CANNOT use a shortcut on the desktop-both the game and userlevels must be together in the folder N_v1.4
Postby blackbelmoral » 2009.04.06 (01:53)
[3d]sigh[/3d]
put a userlevels file in the same folder as n
YAR HAR!
X2
Sigs:
29403|?NicNac?| Kablamo
Postby Exüberance » 2009.04.24 (22:29)
Also, to be clear, you need ONE &userlevels= in your file, NOT one for each map. The program reads all of your maps as one string, then breaks it up itself.
It should look something like this:
&userdata=
$Switching the Flow#Exuberance#Action#map data#
$Walking the Rocket-Dog#Exuberance#KRA#map data#
$76-1: Classix#cucumber_boy#action#map data#
$Kurukururin#ZivilynBane#round1#map data#
(replacing map data with the map data of course)
Note the $ before each map and the # after it. The maps should already be formatted as above when you copy from NUMA, but you might want to double check all your maps to make sure you didn't copy only part of one map- that would mess everything below it (inclusive) up, and possibly everthing else too depending on how it parses the information.
Nmaps.netNmaps.net
Postby Neil_Bryan » 2009.05.29 (03:28)
George wrote:You must ensure the string &userdata= is located at the top of the document.
Yeah, you got to be sure about this. Make sure it's only one on the top. Also, not on top of each map.
golfkid wrote:Make sure the userlevels.txt file is in the same folder as the N flash file.
If it isn't, the userlevels won't really show up, because it's located at a different location.
Rule wrote:You must close and re-open n-game to make sure the level is added.
Even if you have done the first and second step listed here, none of these would apply except if you close then open the game again.
Names of Towns
Shortest: Y
Postby EdoI » 2009.05.29 (21:04)
I think you're wrong. It is much easier to click Refresh List button, that is located at the bottom of the maps list, on the left side.
EDIT: That reminds me, if you ever start using NReality, Refresh List button isn't working.
*goes to report this problem to Unreality, and thinks: "How didn't I reported this to him as soon as I downloaded it, I noticed it immediatly when I opened it!"
