Uzi's Images
Postby Universezero » 2009.01.18 (02:35)
Certainly.
Look closer and you shall see more.
NUMA Profile: http://nmaps.net/user/esay
Postby esay » 2009.01.18 (05:39)
lol that's cool but.. i dunno. not me.
Maybe if u made an n-like ninja (doing something amazing) and made the background more exciting!
i love the hidden features thou ;P
Lucky
Postby lotiso » 2009.01.19 (06:50)
Dimensions: 400x250
Colour Scheme: purple, blue
Renders: Image
Complexity: Indepth
Matching Avatar: No.
Thank you for your time.
If possible, can you pm it directly to me when it is finished? that would really help.
Postby Universezero » 2009.01.19 (09:32)
Octave
NUMA Profile: http://nmaps.net/user/jack_hammer4
Postby Jack_hammer4 » 2009.01.19 (13:03)
Dimensions: Any size that fits best!
Colour Scheme: Anby color that fits best!
Renders: http://chrisdesign.files.wordpress.com/ ... stract.jpg
Complexity: Really Complex!
Matching Avatar: Yes!
THANKS!
Postby Universezero » 2009.01.20 (00:23)
Image Image
Postby deltainferno » 2009.01.20 (00:26)
hi, could you pls make me an avatar/sig combo which uses the pokemon (i know, nerd etc.) tyranitar in flames, with the text, Delta_Inferno, Delta. I, D.I or D. Inferno. and all this on a contrasting blue/black background? thanks in advance ;)
-previous sigs-
Image-GloomP
Image-NicNac14
Image-Universe_Zero
Image-NicNac14
I LIKE PIE
Postby Universezero » 2009.01.20 (09:02)
deltainferno wrote:hi, could you pls make me an avatar/sig combo which uses the pokemon (i know, nerd etc.) tyranitar in flames, with the text, Delta_Inferno, Delta. I, D.I or D. Inferno. and all this on a contrasting blue/black background? thanks in advance ;)
Image || Image
Here's a few others:
Postby kai » 2009.01.20 (17:22)
looks nice, but its too small. and i didnt want the pictures to overlap. also, could we give the text a bit more color?
Postby kai » 2009.01.25 (15:46)
apologies for the double post and yes this is a bump.
you there Universezero? if your too busy with other things ill stop asking bout my siggy.
Postby Universezero » 2009.01.25 (23:55)
kai wrote:apologies for the double post and yes this is a bump.
Oh yeah, sorry. Um, I can't really make it any bigger because the pictures you gave me aren't wide enough. Get me some bigger pictures and I'll remake it for you.
Postby kai » 2009.01.27 (02:06)
its perfect, and put the text in too instead of overlord of insanity. same dimensions as the sig i have now... but perhaps a bit taller?
and make his face into a matching avatar only reversed, 100x100.
Postby Universezero » 2009.01.27 (07:24)
kai wrote:Image
Image Image
Postby Octopod Squad » 2009.01.27 (07:50)
Hey UZ! I would love to see a tutorial from you on how you do those 3d-ish abstract signatures, like the ones you made for Laurie!
Though you are reading this, this is wasting your lifetime by 5 seconds.
Also, if you feel like being a pirate, then click this. http://cristgaming.com/pirate.swf
Postby Universezero » 2009.01.27 (08:59)
Octopod Squad wrote:Hey UZ! I would love to see a tutorial from you on how you do those 3d-ish abstract signatures, like the ones you made for Laurie!
Sure. Video or instruction?
Octave
Postby Jack_hammer4 » 2009.01.27 (17:21)
UniverseZero wrote:Image Image
OMG! Its so awesome! Thanks!
Postby kai » 2009.01.27 (17:49)
its perfect, thx dude
Postby Octopod Squad » 2009.01.28 (01:16)
Depends, are you Using GIMP or Photoshop?
I use gimp.
Postby Universezero » 2009.01.29 (20:21)
I use gimp.
Same.
Postby Octopod Squad » 2009.01.30 (02:39)
I use gimp.[/quote]
Same.[/quote]
Then Instruction. Plus a request for me to help you with the requests. My work is more down than yours on the first image page =)
Postby Universezero » 2009.01.30 (04:50)
UniverseZero wrote:
Octopod Squad wrote:Depends, are you Using GIMP or Photoshop?
I use gimp.
Same.
Firstly, I need no help. Thanks anyway.
Secondly:
Abstract Image Tutorial Using Gimp
  1. In this tutorial, we will be using Laurie's Signature as an example.
  2. Start off by finding the render you want to use, in this case: Link
  3. Copy this image into a new Gimp image; make sure the canvas is already at the right size. Make sure the background is transparent.
  4. Resize the 1 and only layer containing the image so that it fits the canvas.
  5. Copy the image again into a new layer, however this time don't resize it. Make sure there are no gaps, and that the image covers the whole canvas. This will be your background.
  6. Move the larger layer to the back. Now go to "Layers" and click "Layer To Image Size". This will make things a lot easier.
  7. Now to get to work. Click the "Smuge" tool. Change the brush to "Galaxy, Big" and adjust the rate to about 30 or 40. You may have to adjust this depending on what you're doing.
  8. Smuge the background until you can't recognise it as a shape; more of a texture.
  9. Go to the top layer and smuge the edges outwards to give it a dynamic effect. Use the same smuge settings; possible less rate.
  10. Go to text and find the font you want and type in the name. Then make the text layer slightly transparent. You can also give it some effects, such as a small "Cubism" effect I used on this one. Then smuge with about 15 rate downwards on the text to give it a reflection-like effect.
  11. Give the whole image a drop shadow of 0 offset, 10 blur and 100% opacity.
  12. Save the whole image. Other effects can be added, such as color distortions etc.
Postby Universezero » 2009.01.30 (08:47)
Laurie wrote:
UniverseZero wrote: Image
Could I possibly get one like that, except with a more shattered outline and a better looking zombie coming out of it?
Finally got bored enough to do it.
esay wrote:Maybe if u made an n-like ninja (doing something amazing) and made the background more exciting!
Finally got even more bored to do this as well.
Postby 29403 » 2009.01.30 (16:33)
Please make me a simple signature on Sonic 2 Beta.
Postby Pixon » 2009.01.30 (16:48)
Thanks UZ!
Postby Universezero » 2009.01.30 (23:10)
29403 wrote:Please make me a simple signature on Sonic 2 Beta.
Here you go:
Laurie wrote:Thanks UZ!
No problem.
