Just thought I'd share it with you all. :P
Generally case fans are 12V, because the only open connectors on computer PSUs are molex, which are 12v (or they run off the motherboard, but that is off the 12v part of the giant 24 pin power connector going to the motherboard)LittleViking wrote:Neat. Are there 5v case fans? 'Cause you could splice it straight into a USB cable if you had that.
No, the molex connectors offer +5v too, it's the red connector on a molex accessory connector (yellow is +12v). Disc drives and the like use the 5v to drive electronics and the head servo. the floppy power connector also offers +5 (once again, red) as does the less common 6-pin connector. those square ATX connectors, however, only offer +12v.smartalco wrote:Generally case fans are 12V, because the only open connectors on computer PSUs are molex, which are 12v (or they run off the motherboard, but that is off the 12v part of the giant 24 pin power connector going to the motherboard)LittleViking wrote:Neat. Are there 5v case fans? 'Cause you could splice it straight into a USB cable if you had that.
