If you could make a new enemy...
Babble about your incredible affections of ninja puzzle platformers here.
Moderators: raigan, Mare
Postby blackbelmoral » 2009.02.24 (02:07)
if you were chosen to be the one to create an all new enemy (or object) in n, what would it be and why?
please include a roughish sketch of it.
YAR HAR!
X2
Sigs:
29403|?NicNac?| Kablamo
NUMA Profile: http://nmaps.net/user/Minion_of_Pi
Postby Minion_of_Pi » 2009.02.24 (03:12)
Hmm... interesting idea for a thread.
Umm.. thought about this the other day, what about simply a "boulder" object? Not gonna sketch it. Just any sort of round object, that could roll, and be moved by anything that moves the ninja (floor, walls, doors, one-ways?). Also, could be resizable (1-tile, 4-tile, 9-tile) maybe? Just thought it could be useful. Also, could kill the ninja if it's dropping or rolling fast enough. (Ndiana Jones? What?)
Imagex2
Postby Amadeus » 2009.02.24 (03:15)
Hm
Nice thread
probably I would add an underwater element to N...that'd be way cool
And then I'd have torpedos
Underwater would be so cool imo
Postby Rose » 2009.02.24 (03:52)
Well, since you said, "or object": I would create "negative gold"; in other words, you actually have to avoid it, or you lose two seconds.
Postby Erik-Player » 2009.02.24 (03:55)
maxson924 wrote:Well, since you said, "or object": I would create "negative gold"; in other words, you actually have to avoid it, or you lose two seconds.
There's an nreality mod that does that, but it's a drone.
Postby Rose » 2009.02.24 (03:56)
Oh. I don't have nReality :P
Postby TribulatioN » 2009.02.24 (04:05)
Teleporting drones.
Like seeker, except more challenging. Using hefty code changes, you could make it teleport to within 5 tiles away from you, etc etc.
Postby blackbelmoral » 2009.02.24 (14:49)
erik, nreality is down.
YAR HAR!
X2
Sigs:
Postby blackbelmoral » 2009.02.24 (14:53)
i would make a multiplying zap drone, where if it ate 5 pieces of gold (or it was hit by another drone) it would split into 2 drones.
(7.52 KiB) Downloaded 2189 times
YAR HAR!
X2
Sigs:
Postby PALEMOON » 2009.02.24 (15:11)
i'd make a Rocket Drone, who moved around and fired one rocket at you for every 2 seconds you were in its line of sight
Postby MattKestrel » 2009.02.24 (16:23)
Shotgun Drone. Basically a chaingun drone, but a shorter attack sequence, less range and much more spread (although the bullets move slower, so the ninja can dodge them more reasonably). Would lead to some interesting encounters, especially in tunnels :)
Postby Pixon » 2009.02.24 (16:46)
SeanBaby Drone! Basically the same as a laser drone, but more powerful.
Also, the image that I made is bleh.
Postby Izzy » 2009.02.24 (17:15)
Kablizzy Drone.
I think I suggested a freeze drone in the old thread in the Olde Forums.
Postby Amadeus » 2009.02.25 (04:41)
ooh maybe like a laser drone that shot through tiles and could break them?
Postby Superpok » 2009.02.25 (05:37)
i wouldn't
but if i had too (gunpoint) i would make a drone that shoots bursts of green that slow you down when hit
Signature Bars
Postby sheganican » 2009.02.28 (04:40)
i would make one that would happily doddle around and explod into colorful bursts of mildly distracting light that cannot harm you.
i would also make a rolling drone. normal zap-drone shape, but it just rolls along quickly on any surfaces and it bounces off the ground and kills you at contact.
i would also make a floating platform. the most stereotypical object commonly found in mario games. you should all know what it does.
i would also make a drone that was harmless itself, but could leave behind a trail of no more than 3 mines at a time with an undecided distance between each mine.
NUMA Profile: http://nmaps.net/user/RedSham
Postby RedSham » 2009.02.28 (16:40)
I would make a litter drone, that drop sticky green goo that slows down the ninja and makes it smell bad for a week.
(844 Bytes) Downloaded 2073 times
Sig by GTM
Postby The Kitchen Sink » 2009.03.06 (15:24)
Mortar cannon.
When it sees you, a target appears around where you were (looks like the aura of the alarm drone from NReality), showing where it will hit and its blast radius. It does this on the very first frame it sees you, with a cooldown of 1 second.
One second after the target is marked, there will be an explosion in that exact area, killing you if you're in its blast radius.
It's a cannon, so it doesn't move.
Postby Tunco » 2009.03.06 (19:20)
A drone that leaves some acid behind it,so when you come there,you will be melt.
Postby Amadeus » 2009.03.07 (16:38)
eganic-nreality has a floating platform drone, if thats what you're saying
Postby sheganican » 2009.03.07 (17:22)
ganteka wrote:eganic-nreality has a floating platform drone, if thats what you're saying
thats not what im saying. i dont want more drones, i want more old-school type tileset possibilities. who wouldnt love 3 E tiles stacked like so: [ ][ ][ ] that float left to right or up to down at a steady, manageable pace? its genius! imagine having to avoid dangerous drones and mines while trying to time your jump enough so that you can get across the giant cavern. its brilliant! it ranks up there with saving princesses and fighting bosses if you ask me.
Postby Minion_of_Pi » 2009.03.07 (17:46)
I like Eganic's idea about the platform. it could also be used as a vertical elevator.
Imagex2
Postby Unreality » 2009.03.07 (18:04)
talking about moving platform in cavern, have you used NReality to play this map?
http://nmaps.net/131461
try it, it is exactly what you want!
Postby Universezero » 2009.03.11 (04:50)
Definitely a tank drone.
Oh, wait, it's been done.
In that case, a Mine Drone. Like a chaingun drone, but it fires mines that arcs at a fair speed across the screen, then lands on a tile. Once it touches a tile, it's stuck there.
Postby koipen » 2009.03.22 (15:18)
Burst cannon.
It's a black cannon, that burst a shock wave towards you. The frame it sees you, it starts a fast bursting. It has burst radius of 6 squares. Tiles will stop the bursting.
Shock cannon.
Like Burst cannon, except white, and instead of 6 square radius of killing burst, it has 7 square radius of shocking radius (stops you for 3 seconds).
Door mods
A door that stops thwumps and floorguards, but drones and ninjas can go through it. Oneway for drones, locked door and trap door that doesn't stop drones.
