Anyone who can do stuff on the system can help by finding bugs that I didn't.Life247 wrote:Only users who could help improve the site should gain access. I'd accept.
AltArc
IRC. I've been doing some editing.
Collabs are almost done being implemented. I need to make it increment the number of maps for both authors, notify the other author that the submitter attributed the collab to him, and link to both authors' pages.
Also, if all goes well, I'll release AltArc for testing Saturday morning. I doubt the theme will be complete by then, but collabs should be functional.
There's an error with map1.html—the rating div (.head-right) is misaligned in Firefox because of a layout problem. You need to use position:absolute, top:6px and right:8px. For that to work you need to change #maphead to position:relative.
I've updated the page if you have problems. Just check the CSS.
Actually, I think I already encountered and fixed that problem using something similar to what you've mentioned.incluye wrote:There's an error with map1.html—the rating div (.head-right) is misaligned in Firefox because of a layout problem. You need to use position:absolute, top:6px and right:8px. For that to work you need to change #maphead to position:relative.
Collab support is now about halfway done; both authors are correctly attributed, and both authors' number of maps are incremented, but there's still a lot of work to do.
Beta testing has commenced! Go to the first post for link/instructions.
I can't register, it just says that it is an invalid email. I've tried multiple addresses, none work.
Also, I got the math problem 22/9. What? I mean, decimal form? improper fraction?
If I try to click through to a map or author, I get sent to "dreamtemplate.com"
Same problems as ganteka.
I got this when just trying to visit the site.
Warning: require(res/runfirst.php) [function.require]: failed to open stream: No such file or directory in /www/110mb.com/g/f/o/r/c/e/_/_/gforce/htdocs/index.php on line 2Warning: require(res/runfirst.php) [function.require]: failed to open stream: No such file or directory in /www/110mb.com/g/f/o/r/c/e/_/_/gforce/htdocs/index.php on line 2Fatal error: require() [function.require]: Failed opening required 'res/runfirst.php' (include_path='.:/usr/share/php') in /www/110mb.com/g/f/o/r/c/e/_/_/gforce/htdocs/index.php on line 2-
I know. I had to remove a certain directory for security reasons (because my web host doesn't enable htaccess by default). It's probably not going to be online until Sunday, or later.Blackson wrote:I got this when just trying to visit the site.
Also, LV, to answer your question, it's because I used a mod_rewrite hack to display the map pages, but 110mb doesn't allow .htaccess without a $9 payment.
Dammit.
Yeah, that pretty much describes how I feel about not being able to find a good webhost. :(incluye wrote:Dammit.
Why on earth are you using .htaccess in the first place? Are you setting up some zany WordPress thing for map submission?
.htaccess and mod_rewrite let you do a lot of excellent stuff with URLs.incluye wrote:Why on earth are you using .htaccess in the first place? Are you setting up some zany WordPress thing for map submission?
Eh, forgive my lack of techknowledgey.
Okay... support for collaborations is almost complete, and it will allow a theoretically infinite number of authors, as opposed to my original plan of only allowing two authors. The way the collaborative map is submitted has also changed: the submitter has a secret "key" that he can send to other users, and those users can enter the key in a certain box to have themselves added as authors.
Also, I think I may have found a better free webhost, so hopefully I can get AltArc running without needing to pay a dime.
http://altarc.sector-five.net/ is up (as a beta)! If you want to help test the site, please do register (the captcha tells you to enter the text, but if all you see is a math problem, solve it instead) and test the features of the site.
IT'S AMAZING
- Walking on Broken Glass
i cant register.
1. the 'CAPCTHA' doesnt show up as an image, although i can see the maths problem.
2. when i click 'submit' it says its loading for a millisecond then stops.
3. when i click 'submit' my passwords suddenly triple in length.
please try to sort them out...
-previous sigs-
-GloomP
-NicNac14
-Universe_Zero
-NicNac14
- Beyond a Perfect Math Score
The site is "down" atm. Was that intentional?
I... can't open the site.
EDIT:
EDIT:
Oh, I see.Avarin wrote:The site is "down" atm. Was that intentional?
No, it shouldn't be down at all. If you can't access it, it's probably a problem with x10hosting, rather than AltArc.EdoI wrote:I... can't open the site.
EDIT:Oh, I see.Avarin wrote:The site is "down" atm. Was that intentional?
Also, about the password "tripling in length": Before logging in, your password is hashed using Javascript for the sake of security.
I'll look into any further issues.
incluye, this is beautiful. I love the simplicity.
Good, I can open the site now.
I've found the issue with submitting maps. GD, the function used to generate images such as map thumbnails, is disabled at the moment, but will eventually be able on my webhost, assuming that this guy is right. Until then, map submissions will not be available. :(
Duuuude, that is slick! Both visually AND functionally! Holy wow. Too bad we can't see what it's like when there's viewable maps, but still, you can tell there's a lot of functionality here. It's simple yet powerful, as you say. Fantastic job so far! :) :) :)
P.S. You should probably do away with the line, "If you seriously need more help than that, you're probably mentally disabled, in which case we apologize for your condition."
