A suggestion
Moderators: Rose, Sunset
Postby blackson » 2009.03.10 (21:57)
Leaff wrote:I think the max float system would be better if it was after a certain amount of time it would start to "sink". Remember that tidal wave map that was on Hot Maps for most of yesterday? "Cumbre Vieja," I think. That's on the second page as I type this. I know it's awesome, but it's taking attention away from other maps.
And I agree with the idea of 25 maps on the Hot Maps page.
Blackson wrote:If x becomes greater to z, then it is automatically set = to z, to prevent maps from staying on the page for too long, because of the added rate effect. Basically, once a map gets a certain number of rates, that map will have the same Float Value, no matter how many more ratings it gets.
Raigan and the Horse-Woman
Postby sidke » 2009.04.07 (03:53)
Taken from NUMA's released source:
map.rating = (map.rating * map.votes + rating) / (map.votes + delta)
map.votes += delta
map.rated = (map.votes >= Map.RATING_THRESHOLD)
new_bar = None if not map.rated else min(int(round(map.rating)), 4)
map.float_num += delta * Map.FLOAT_DELTAS[rating]
1: Adds the new vote to average in with the map's current rating.
2: Delta's almost always one, so all this does is increase the map's vote count by one.
3: Determines whether or not the map has a public rating based on Map.RATING_THRESHOLD, which is five.
4: Sets those ninja guys, 1-5. Basically takes a rating like 3.6_ and turns it into 4.
And now, for the magic line (the theory is by b_t, if I'm not mistaken):
5: This spectacular line is what arranges the maps on the hot maps page. The float_num starts off as the map's ID (i.e. 150000, mintnut is well cool :3). Every time someone votes, it alters this float_num by a certain amount. Based on Arachnid's release of the source, the alterations are as follows:
RATE, CHANGE
0, -2
1, -1
2, 0
3, 0
4, 1
5, 2
The maps are then listed by this float_num, descending. So say you rate a map 5... In a controlled environment where no other rates are going on, the map will appear before (above) the next 1 or 2 (I haven't read the maps listing enough to tell which) map(s) that are posted. Therefore maps that receive fifty 5's end up staying up much, much longer.
Blackson's idea for a limit could be implemented as such (change line 5):
map.float_num += (delta * Map.FLOAT_DELTAS[rating]) if map.votes < Map.FLOAT_LIMIT else 0
Where Map.FLOAT_LIMIT is a number determining the amount of votes that affect a map's float_num. This, of course, might end up being a detriment to a map's overall stance, but if FLOAT_LIMIT were high enough, it wouldn't matter; if a map is getting more than 20 votes, it obviously has stayed on the hot maps for more than enough time as it has received its fair share of attention.
Anywho... I dunno if the hot maps has been explained before, but here it is again, and the possible limit that blackson was talking about.
My two cents :3
Postby blackson » 2009.04.07 (16:14)
Sidke wrote:Blackson's idea for a limit could be implemented as such (change line 5):
Right. You know how much I know about coding, but would this be possible?
map.float_num += n(delta * Map.FLOAT_DELTAS[rating]) if map.votes < Map.FLOAT_LIMIT else 0
(This probably isn't represented right)
N is some number to give ratings a higher affect. Maybe we could make it vary with the ammount maps being submitted?
Let's say a map is submitted every 20 minutes. n=1
Now it's a very popular time of day, maps are being submitted every 5 minutes. Could n change itself to 4? This way maps are always suited for the ammount of maps being submitted, and the float value is always relevant. For example, say something gets 10 ratings in peak hours, and then NUMA gets quieter. This maps float value wouldn't remain 4 times higher then the norm. , but instead auto adjust itself.
sidke wrote:My two cents :3
Postby sidke » 2009.04.07 (17:39)
Blackson wrote:Now it's a very popular time of day, maps are being submitted every 5 minutes. Could n change itself to 4? This way maps are always suited for the ammount of maps being submitted, and the float value is always relevant. For example, say something gets 10 ratings in peak hours, and then NUMA gets quieter. This maps float value wouldn't remain 4 times higher then the norm. , but instead auto adjust itself.
All I can say is it'd be hella impractical trying to implement something to record how many maps are being submitted per hour for the sole purpose of adjusting the weight of voting during peak hours. I've just realized it's quite a bit, what you're asking... For popular maps to go down faster, and maps that you believe deserve attention to stay up longer. I, myself, might care only for the former although it is not as common. It's been proven that maps /can/ get attention, and they do. Maybe some don't get much as one would like, but that's life.
I'm very apathetic towards NUMA as an source of feedback or appreciation at the moment, so I really don't mind these 'problems'.
NUMA Profile: http://nmaps.net/user/Hanzo
Postby Titanium » 2009.04.12 (15:54)
Add a link to map commenting thread and all other map guides on the front page of NUMA.
Postby blackson » 2009.04.12 (16:04)
Titanium wrote:Add a link to map commenting thread and all other map guides on the front page of NUMA.
People know they exist. And they shouldn't need a thread to express their opinion of maps.
Postby Cheez » 2009.04.12 (18:14)
There's too much garbage on Hot Maps these days.
Numa needs a feature that says something like:
"We're sorry, but you have recently submitted 2 maps in the last (#) of hours. Please wait a while before trying again."
This way, it will clean up more spam garbage. Also, moderators can just sit on their arses all day without doing anything.
| last.fm | NUMA | RYM |
<@Izzy> van prefers it long.
Postby blackson » 2009.04.19 (15:47)
MyCheezKilledYours wrote:Numa needs a feature that says something like:
I think that two maps on the hotmaps page at a time is fine. Nobody looks any further then that.
Users browsing this forum: Google Adsense [Bot] and 21 guests
