ModMaster v1.4 *** Dronie Award :: Program Of The Year ***
- MBTI Type: ESTP
Download Modmaster 1.3: http://www.box.net/shared/6kk2thvl4k
Download Modmaster 1.2: http://www.box.net/shared/lfyvtlcj4d
Download ModMaster 1.1: http://www.box.net/shared/kkntkivzd4
To Open ModMaster:
1) Open File titled: "NReality Helper 2"
2) Use Program
This is my first application that actually has a real use. Please excuse my ignorance and amateur style of coding, designing, etc. I will get better in the future (hopefully :] ).
This was coded using Visual Basic Express Edition 8
Basic Details you will want to know:
This is meant to be only a supplement to NReality coding, to ease the way that code is made. You may notice that the output of the program comes with some words left in (e.g. x, y, path, direction, etc.) To make it so that object will work in NReality, you will need to replace these words with the correct value. I did this because I wanted to make the program so that it only dealt with NReality mods. The left words are fairly self explaintory, you may ask questions on the ModMaster thread or PM kkstrong on the forums if you have any questions.
On the objects/drones that you can code individually on:
1) You will only be able to line at a time. To make several of these objects in a map simply:
1) Enter in Values in each text box (note: if you leave a textbox blank, it will not crash the program, the program will just simply ignore it)
2) Press the "Calculate Code" Button
3) Copy and Paste Given Code, and replace words with correct values.
4) Repeat until desire is fulfilled :) (what will happen is the code will just be replaced)
Note: I have entered in the default values for all of these. If you calculate code with these given values, the object will appear normal in NReality.
On objects/drones that you cannot code individually on:
1) You will only be able to calculate one mod at a time. To use this function:
1) Choose Mods you would like to use. By checking the boxes, you will turn off the readonly function assigned to the text boxes, and you will be able to write in the text boxes. ( you can see the readonly function is marked by a slightly bluish tint)
2) Enter in values for boxes
3) Press the "Calculate Code" Button
If you would like to do this several times, remove values from
Versions History:
1.1 - initial release of program
1.2 - Fixed Several Minor Bugs
- Backround Image (Under Images Tab)
- Foreground Image (Under Images Tab)
- Icon (Under Images Tab)
- Regular Trigger (Under Triggers Tab)
- Special Trigger (Under Triggers Tab)
- Area Trigger (Under Triggers Tab)
- AI Pathing Objects (Under Pathing Tab)
- Circular Pathing (Under Pathing Tab)
- Chase Pathing (Under Pathing Tab)
- Custom Path (Under Pathing Tab)
1.3 - Fixed Major Bug in Triggers Section
1.4 - Added New Function to Drones section to allow for original drone input/output (Credit sidke for code help)
- Made drone outputs more efficient
- Fixed Area Triggers, They should now always work!
- Hyperlink in playermods sections working
- Program Icon! (Credit incluye for make the icon)
- Dronies button!
To Do List:
- Fix circular pathing, not all textboxes filling code [ tried on this one for a while, can't see where the bug is ]
If you have any questions, you may ask in the ModMaster thread or PM kkstrong on the forums if you have any questions.
Download Modmaster 1.4: http://www.box.net/shared/puggqfrfml
:) some minor little bugs, which doesn't really matter:
1. once chosen zap drone, can't edit chase speed anymore
2. alarm drone's radius decrease rate description is wrong
:) by looking at your program I realized that I have added a whole lot of functions to N :D
- MBTI Type: ESTP
http://www.microsoft.com/downloads/deta ... laylang=en
another problem might be the OS you are running. I think this works on XP, vista, and linux. No Mac.
- MBTI Type: ESTP
Unreality wrote:OMG This program is AWESOME !!!!!!!!!!!!!
Okay, I will fix those bugs.
- MBTI Type: ESTJ
well done young man, that makes it soooooo much easier, you will probably win a dronie.
Hi Everybody!
- Semimember
- NUMA Profile: http://nmaps.net/user/minimap4646
┌┴─┴─┐-┘─┘ ●● Peace Out ●●
Once again: BAHAHAHAHAHAHA stupid mac fanboy!!! ;)BionicCryonic wrote:Can SOMEONE package this as a .hqx file?
Once again: BAHAHAHAHAHAHA viruses!!! But seriously, the windows at our house is condemned. Open up IE and it crashes and goes into reboot mode, and if you can go 2 seconds without crashing, we still have dialup so everything is uber slow.ska wrote:Once again: BAHAHAHAHAHAHA stupid mac fanboy!!! ;)BionicCryonic wrote:Can SOMEONE package this as a .hqx file?
P.S. I'm getting a lot of warnings lately so: No harm intended. If you were offended, I will edit this post.
- Ego Lancer
It's about time someone made something like this.
use firefox, don't use IEBionicCryonic wrote:Once again: BAHAHAHAHAHAHA viruses!!! But seriously, the windows at our house is condemned. Open up IE and it crashes and goes into reboot mode, and if you can go 2 seconds without crashing, we still have dialup so everything is uber slow.ska wrote:Once again: BAHAHAHAHAHAHA stupid mac fanboy!!! ;)BionicCryonic wrote:Can SOMEONE package this as a .hqx file?
download AVG Free to protect your computer
- Demon Fisherman
It's not the OS that causes viruses to make their way onto a computer...it's the teenager looking at porn without a firewall on.BionicCryonic wrote: Once again: BAHAHAHAHAHAHA viruses!!! But seriously, the windows at our house is condemned. Open up IE and it crashes and goes into reboot mode, and if you can go 2 seconds without crashing, we still have dialup so everything is uber slow.
- Walking on Broken Glass
- NUMA Profile: http://nmaps.net/user/hoohah2x2sday
FAN PROGRAM OF THE YEAR
[√] ModMaster
- MBTI Type: ESTP
Okay. I wil fix.BE_nSPIRED wrote:i found an error: The speed of the rocket launcher, the code should say maxspeed. It doesn't work otherwise
And universe, why not 2009? :P
- NUMA Profile: http://nmaps.net/user/SkyRay
Also, having some time of scale or example next to each mod would be nice, so you know what kind of number to put.
For example, rocket speed .01 (slow) - 10 (fast)
Uh, I'm not into that stuff, so... Also, I forgot that my parents disconnected it from the network. Also, N doesn't work on that computer to begin with; too slow.squibbles wrote:It's not the OS that causes viruses to make their way onto a computer...it's the teenager looking at porn without a firewall on.BionicCryonic wrote: Once again: BAHAHAHAHAHAHA viruses!!! But seriously, the windows at our house is condemned. Open up IE and it crashes and goes into reboot mode, and if you can go 2 seconds without crashing, we still have dialup so everything is uber slow.
- MBTI Type: ESTP
BionicCryonic = "Torrents"
EndIf
Excellent use of that pesky mathematical sign. *wink*Universezero wrote:2010 Dronies:
[√] ModMaster
Which makes it the perfectly ideal computer to get unbiased results in testing various opperating systems. I applaud your scientific rigor!Also, N doesn't work on that computer to begin with; too slow.
(yes, that was sarcasm)
As much as I hate Internet Explorer and Vista, I have to disagr- wait a minute. How did this thread become an operating system flamefest? What were we talking about?
Oh, right! The program thing!
