Post a Run!
164140 speedrun (834 frames)
- RoboBarber
16-0 by 3 frames. I know that's improvable, I wanna see what xaelar can do. (101.3 or faster ?)
@ xaelar : you should improve your 91-4 and your 96-4 so you'll have 19:50 (71'400 sec) of total game score :) It'd be amazing.
You also have unsubmitted level on nreality's server, like your 48-3. (210.9 on nreality and 212.575 on metanet)
- Quarks
xaelar wrote:16-0 by 2 frames.
lol, thanks for taking all of my 0ths in the first half of the game. Those ep. 34 runs are amazing, though. I couldn't believe you beat my 34-4 by so much without beating the top drone.xaelar wrote:and 34-4.
Yes... I mutivated you alright ;Pxaelar wrote:34-1 and 34-4.
Inspired and mutivated by ska on irc :D
- RoboBarber
:O I got 53-3 0th while playing ep 53. (i get back my ep 0th)
I also improved my 53-4 of yesterday by 0.450 to get the legit 0th. It's still improvable ! (i think L3X is beatable without beating the drone at the beginning)
Finally i reached 40 0th. (with only 10 level 0th :S)
40 0th, that's excellent, it's good to see xaelar getting some competition on his mission to get them all ;-)
53-3 really frustrates me ... after only my 5th or 6th try I hit both corner jumps to get all the top gold, but then messed up in the bottom corner missing the top left gold of the bunch. I did a third jump to get this (bad bad move) which meant I didn't quite have enough speed to clear the final leap - I hit the last mine with about 133 on the clock. Since then I have been unable to hit both corner jumps with a run clean enough to avoid the drone on the 2nd jump :-(
164693 speedrun (41 frames)
164693 highscore (94.325)
50-4 with plenty of room for improvement. There's also a slight alteration to the route that would improve it by about half a second and another route entirely that might be faster though probably not. I also don't know whether my beginning is faster or not, I simply like it better.
Unreality's awesome mod
Man, you've been a genius with innovations lately.
Thanks. Since I can't, with rare exceptions, get 0ths through cleanness I have to get them somehow.
Edit: Speaking of exceptions with a little more work I could take 0th on 34-2 without any real innovation. (I simply got sick of the level)
Edit 2: I just saw macrohenry's run on 78-3 and it's hilarious how he ends up with a keep the rocket alive finish.
64721 highscore not my best chimney, but still pretty good.
Upon further fbf inspection of my demo somehow i am able to jump again after i activate the exit O.o I really have no idea how that happened and that chimney was actually pretty good.
11111 highscore (182.675) (3.350 seconds faster than xaelar.)
Edit:- Now 183.325 and an exact 4.00 second lead over xaelar
weird - i didn't watch it but i think kryX managed to do the same thing on one of the chimenyish metanet levels.TheRealOne wrote:64721 highscore not my best chimney, but still pretty good.
also @ macrohenry's 78-3 ... O_o
Speedruns:
163608 - I used yokola's route and another little innovation of my own, but quite beatable.
164904 - Just another jumping-on-air level for you high-scorers out there; my demo is the benchmark :p
xaelar, you still need to submit your 12-2 to unreality's server and I think you have a few other runs from around the same time that haven't been submitted.
164895 , this is also my 2nd land map. I want more highscorers scream on my map so I post it here. Beat my map if you can.
You also need to submit 35-4. (I'll continue to keep an eye out for any others)
Only if there's some way of modifying an alternate route like mine to get 0th (though it might be improvable by a single frame but it's darn close to max).
Edit: 53-3 can be improved by over half a second easily. I had runs where I hit the drone that would have been around a second faster.
Users browsing this forum: Google [Bot] and 40 guests
