Postby EdoI » 2009.05.10 (14:19)
Loading Level:
Loading Map
Loading Objects
-demo playback started..
-demo playback stopped.
====[N]====
I miss this too.
Postby bhz » 2009.05.10 (21:09)
EdoI wrote:
Loading Level:
Loading Map
Loading Objects
====[N]====
I miss this too.
It would be useful to see what enemy we were killed by (especially for ddas)
and I loved that "you were killed by yourself.....loooooser!!!!!"
<Izzy> Who are you?
<Meta> I'm meta?
( #n-highscores )
Postby Exüberance » 2009.05.11 (22:25)
Suggestion!
Copy the currently-impossible-to-get-unless-you-won demo data to the clipboard when you press R to replay in userlevels/NUMA mode. Currently, the only way to get your demo is if you won the level, but if you had an epic demo but then died, you get nothing. If you play in debug, you can do this but you must remember to press 2, 1 each time, must reload the map, and you can't submit scores that way
Also remove the feature that "fixes" "corrupt" map data when you go into edit mode, so that way it doesn't remove NReality stuff.
Reason: That yellow was mighty hard to see in Cobalt, so I darkened it. Hope you don't mind.
Nmaps.netNmaps.net
Postby Unreality » 2009.05.12 (01:00)
Exüberance wrote:Suggestion!
not really. NReality support dead demo. Hold shift forever when you replay your dead demo
Exüberance wrote: Also remove the feature that "fixes" "corrupt" map data when you go into edit mode, so that way it doesn't remove NReality stuff.
It's not a feature. It's the problem of original Ned. I haven't touched the codes in Ned yet.
for the loading
I will check it
Postby Nexx » 2009.05.12 (05:38)
Unreality wrote:not really. NReality support dead demo. Hold shift forever when you replay your dead demo
Could you elaborate? I'm holding shift when replaying the death demo but it's not doing anything. Is this a new feature with 6d4?
MBTI Type: ESTP
Postby kkstrong » 2009.05.12 (07:26)
when you die in a demo on a NUMA map in userlevels, if you want the death demo data, hold down shift while replaying the data. The longer the demo, the longer the wait time, so be prepared to wait for a long time.
Postby Nexx » 2009.05.12 (18:01)
kkstrong wrote:when you die in a demo on a NUMA map in userlevels, if you want the death demo data, hold down shift while replaying the data. The longer the demo, the longer the wait time, so be prepared to wait for a long time.
Oh, that's interesting! I kept thinking the window popping up because I was doing something wrong (I never just let it load to see what it was). Thanks!
And it seemed to work best if I started holding down shift right when I pressed R (so Shift + R, then let go of R).
Postby Exüberance » 2009.05.12 (23:54)
Bug: Custom icons fail to update with the object's position for objects that normally do not move (ie, mine + custom path + icon = fail)
It does properly updates for drones, however
EDIT: 2 1 more possible bugs
- mods do not work in userlevels (they load as normal N would load them)They seem to work now. I must have formatted somethign wrong somehow
- replays only work for actual userlevels, not playing NUMA levels in the userlevels sectionH'uh. It's working now too. That was very strange o.O
Also, how the heck do you get playermods to work with area triggers?
And a suggestion:
Add a new textbox (you won't need to actually modify anything this way) to Ned, which never clears itself (it shouldn't do this since it's a new addition) and appends whatever text it contains to the end of the level data when you leave edit mode. This would solve the problem of dissapearing playermods and such, and so long as you place special enemies at the end, no more dissapearing objects! This would be a HUGE help since I wouldn't have to keep copy-pasting from notepad, hoping I don't paste the wrong thing, and it would be extremely easy to implement. All you have to do is find where it "prints" the map data, add a single line of code, then make sure that the text boxs appears/disappears whith the other ones.
The only problem would be that objects with triggers and paths aren't deleted, so you'd end up with extra objects, but I guess then you would just use this feature for things that dissapear. Playermods, objectmods, background, foreground, ...
Nmaps.netNmaps.net
Postby Cheez » 2009.05.13 (21:51)
Exüberance wrote:- mods do not work in userlevels (they load as normal N would load them)
Mods do too work in userlevels. The NReality Pack works just fine for me.
| last.fm | NUMA | RYM |
<@Izzy> van prefers it long.
Postby Yoshimo » 2009.05.14 (01:29)
NrealityPack mention! =D
Also, that appending box would really help. Like, a lot.
EDIT: I found a really strange mod. Check it out, use rockets.
Postby Unreality » 2009.05.21 (06:59)
nreality server is down, i will fix it once I back home
Postby Unreality » 2009.05.21 (12:36)
it's up
Postby 999_Springs » 2009.05.22 (19:09)
I've found some bugs on n.infunity.com...
1. The episode 0th table has the column headings above the wrong columns;
2. Typing in episode/level numbers into the textboxes on the speedrun/underclock top20s redirects to highscore;
3. Hovering your mouse cursor over the "SHARE" button before the page loads leads to chaos;
4. Sometimes the menu bar won't load and you have to hover your mouse cursor over the "SHARE" button to get it to load (but you have to wait for the rest of the page to load first - see #3).
It doesn't detect multiaccounting, right? It seems to me that everything from *7th (gza) downwards on userlevel 10880 is a bit... well, suspicious.
Oh, and one observation: I could make my way up to 4th on the highscore level 0th top, but once I'm there, the only way is down...
Postby Yoshimo » 2009.05.23 (02:22)
Anyone want to find some cool mods with me? We could help the community and have fun.
I might compile some of my cooler mods to start us off.
Postby Unreality » 2009.05.23 (05:18)
999_Springs wrote:I've found some bugs on n.infunity.com...
fixed
999_Springs wrote: 3. Hovering your mouse cursor over the "SHARE" button before the page loads leads to chaos;
um.. I don't wanna spend time of fixing the javascript now...
999_Springs wrote:It doesn't detect multiaccounting, right? It seems to me that everything from *7th (gza) downwards on userlevel 10880 is a bit... well, suspicious.
I think it doesn't really affect anything yet... btw plue pipiman chim t-in-t speed dennis huhn murad zerba gza loli all have the same IP
999_Springs wrote:Oh, and one observation: I could make my way up to 4th on the highscore level 0th top, but once I'm there, the only way is down...
guess I can do nothing about this? but I do think you have the potential to get much more 0ths
Postby Exüberance » 2009.05.23 (13:24)
BionicCryonic wrote:Anyone want to find some cool mods with me? We could help the community and have fun.
Here's some I made (though I've only used 2 (the *'d ones):
«Spacemod» Plan on using this one soon. You have no air resistance and almost no gravity. Enough gravity so you can still run and walk, but it takes a looong time to accelerate to any significant speed.
|||||g,0.0001;normGrav,0.0001;normDrag,1;d,1;maxspeedAir,999;maxspeedGround,999;
«Realmod» I also plan on using this in a puzzle, depending on how workable the mod is. It's more realistic: you can't turn in midair (well, in real life you can, but not in a normal jump :D), you can't run quite as fast, your jump is somewhat realistic. Not so ninja anymore!
|||||g,0.3;normGrav,0.3;airAccel,0;jumpGrav,0.3;jumpAmt,1.75;jump_y_bias,1.75;normDrag,0.9975;
«BlockPuzzleMod*» You die from falling farther than 4 blocks, you can only jump (from a flat surface) just over 1 tile, you cannot walljump or wallslide. GREAT for puzzles! Used it in this map.
|||||noWallJump,1;noWallSlide,1;jumpGrav,0.1;normGrav,0.3;g,0.3;max_jump_time,15;
«SonicMod*» This is the playermod I use for my sonic levels. Fun!
|||||terminal_vel,10000;groundAccel,0.195;airAccel,0.15;maxspeedGround,20;maxspeedAir,20;noWallJump,1;noWallSlide,1;
Would appreciate credit if you use these exact playermods, but it's not really that big of a deal. It's just game settings. Not that hard for 2 people to seperately come up with similar mods.
Also, Unreality, any plans to maybe implement that text box thing I was talking about? Should be real easy to do but it will be a really big help.
Nmaps.netNmaps.net
Postby EdoI » 2009.05.29 (15:03)
Umm, Unreality, did something happened to the server? All of my scores are gone. Except for NUMA maps, where I think I've lost some of the scores, I've got only 19 of them right now.
EDIT: Forget about this above, I was looking at speedruns. : )
Postby Unreality » 2009.05.29 (15:51)
n.infunity.com will have a server maintenance in 30 May 09 from 12:00 noon to 9:00pm Hong Kong time, that is G.M.T+8
what's for? for replacing a new and faster ISP :D
Postby EdoI » 2009.05.29 (21:08)
Hey Unreality, why doesn't the Refresh List button work?
Postby Unreality » 2009.05.30 (02:39)
EdoI wrote:Hey Unreality, why doesn't the Refresh List button work?
cause it will mess the load numa map function up
Postby Unreality » 2009.05.30 (13:12)
Server ISP changed, please tell me the server loading speed, thanks ;)
MBTI Type: ESTP
Postby kkstrong » 2009.05.30 (14:33)
It took me ~5 seconds to load n.infunity.com
Postby Nexx » 2009.05.30 (18:06)
~3-4 seconds.
Postby EdoI » 2009.05.30 (20:04)
~4-5 secs on 1536kbps download speed.
MBTI Type: ESTP
Postby kkstrong » 2009.06.01 (01:50)
So.... It's about the same speed as it was...
Users browsing this forum: No registered users and 42 guests
