Nreality column 80-89 locked. Need help.
Octave
Postby stafflute » 2009.06.06 (15:34)
Hello guys!
In these weeks I've begun playing N (Nreality).
But I've a problem:
The column 80-89 is locked.
How can I unlock this column?
Sorry I'm not good in English.
This image explain the problem
Postby Tunco » 2009.06.06 (15:48)
Italian wrote:Hello guys!
But I've a problem:
Finish episode 79, and continue to 80.
When you finished 80, look at it if it is opened or not.
It should be.
MBTI Type: ESTP
Postby kkstrong » 2009.06.06 (17:41)
You should always be able to play the first episode of a column no problem...this is weird.
I dont have experience with this, so this is just a guess. It looks like you entered in a cheat code from n1.4, and then opened NReality. Either that or completed on practice mode, I don't know.
I would try:
restarting NReality (close and restart)
logging into NReality (under configure)
redownload NReality (from the website)
If none of those work, then I'm sure Unreality could probably do something on his side of the server.
Octave
Postby stafflute » 2009.06.06 (19:27)
kkstrong wrote:You should always be able to play the first episode of a column no problem...this is weird.
I would try:
I tried but nothing of those work.
Postby Izzy » 2009.06.06 (19:29)
Tunco123 wrote: Finish episode 79, and continue to 80.
It should be.
You don't have to play in order. You should always be able to play the first episode in a column. That's pretty strange.
MBTI Type: ESTP
Postby kkstrong » 2009.06.06 (19:50)
And I don't even think it might have anything to do with NReality... try in v1.4
Octave
Postby stafflute » 2009.06.06 (20:07)
kkstrong wrote:And I don't even think it might have anything to do with NReality... try in v1.4
It's the same.
Postby EdoI » 2009.06.06 (20:54)
It's the same.
In this screenshot you've got 81 unlocked, in the first one you don't. Both NReality and N are using the same .sol file, so either you somehow unlocked 81 in the meantime, or there's something very wrong here.
Try open it with cheats, and then beat it regularly.
Octave
Postby stafflute » 2009.06.06 (21:09)
EdoI wrote:Try open it with cheats, and then beat it regularly.
The cheats written in n_cheats.txt?
MBTI Type: ESTJ
Postby Kablamo » 2009.06.06 (22:50)
are you by chance in practice mode? this could be one of the problems.
Hi Everybody!
Postby KlanKaos » 2009.06.06 (22:57)
Kablamo_Boom wrote:are you by chance in practice mode? this could be one of the problems.
This could be the problem. Try going to Configure and and turning practice mode off.
Octave
Postby stafflute » 2009.06.06 (23:43)
The practice mode has already turned off.
Postby Unreality » 2009.06.07 (08:39)
http://matrixoft.infunity.com/agent/calvin/n/fix80.rar
i hope this file fix your problem
to other people, don't run this exe cause it will set your column 80 unbeaten except ep 80
Italian please let me know if this doesn't work
perhaps you have this situation is because you tried using practise mode to beat level 79?
Octave
Postby stafflute » 2009.06.07 (11:25)
Unreality wrote:http://matrixoft.infunity.com/agent/calvin/n/fix80.rar
It works!
Unreality, you are a GOD!!!
Thank you very very much!!!
Postby Unreality » 2009.06.07 (14:18)
Italian wrote:Unreality, you are a GOD!!!
indeed XD
Octave
Postby stafflute » 2009.06.07 (14:24)
Thanks also the other users who have helped me.
