The Metanet Pokemon Tournament!
- NUMA Profile: http://nmaps.net/user/apse
- Phei Phei Pho Phum
Edit: I don't think it's on my end, as ShoddyBattle allows me to see/connect to servers without a problem.
- Cowboy Magician
What version are you running? I had 1.041 running, and couldn't connect to any servers. I had to un-install it and install 1.042 before I could connect to anything.Pheidippides wrote:What server is everyone using? I'm having trouble connecting to common servers like the Netbattle registry and the Smogon server. Might this be an issue with my firewall ports, or something else?
That's odd, because I had just uninstalled 1.041 and installed 1.042, and I still couldn't connect. What server did you connect to after installing 1.042? Maybe I should just try another uninstall/reinstall.Drathmoore wrote:What version are you running? I had 1.041 running, and couldn't connect to any servers. I had to un-install it and install 1.042 before I could connect to anything.Pheidippides wrote:What server is everyone using? I'm having trouble connecting to common servers like the Netbattle registry and the Smogon server. Might this be an issue with my firewall ports, or something else?
Aside from unblocking the program in Windows Firewall, you'll need to connect via the 'Advanced Connect' button. Enter server 'nb.pmnb.net'. You'll find that the registry is down pretty often. Gimme a holler if you have any further troubles.Pheidippides wrote:That's odd, because I had just uninstalled 1.041 and installed 1.042, and I still couldn't connect. What server did you connect to after installing 1.042? Maybe I should just try another uninstall/reinstall.Drathmoore wrote:What version are you running? I had 1.041 running, and couldn't connect to any servers. I had to un-install it and install 1.042 before I could connect to anything.Pheidippides wrote:What server is everyone using? I'm having trouble connecting to common servers like the Netbattle registry and the Smogon server. Might this be an issue with my firewall ports, or something else?
- Oops Pow Surprise
What about this? :xMyCheezKilledYours wrote:Maybe we should do something like add (MN) to the end of our username to help identify who's who.
Btw, I changed my team. It was a sandstorm team, but Roserade severely whomped my team.
Edit: I've added [Mn] in front of my name. I suggest others do the same. That way, if someone's looking for a match, you only need to look in one spot to find all the Metanetters who are signed on.
600th post!
Really want to get this going.
[MN] Chasethebase sent out Absorber (Lv.100 Blissey)!
End of turn #12
.REDILVER.'s Dialga: 74% HP
[MN] Chasethebase's Absorber: 714 HP
Begin Turn #13
Dialga used Flash Cannon!
(146 damage)
Dialga is hurt by its Life Orb!
Absorber used Thunder Wave!
Dialga is paralyzed! It may be unable to move!
The sandstorm rages.
Absorber is buffeted by the sandstorm!
End of turn #13
.REDILVER.'s Dialga: 64% HP (Par)
[MN] Chasethebase's Absorber: 524 HP
Begin Turn #14
Absorber used Seismic Toss!
(28% damage)
Dialga used Dragon Pulse!
(170 damage)
End of turn #14
.REDILVER.'s Dialga: 26% HP (Par)
[MN] Chasethebase's Absorber: 310 HP
Begin Turn #15
Absorber used Softboiled!
Absorber regained health!
Dialga used Roar of Time!
(522 damage)
A critical hit!
End of turn #15
.REDILVER.'s Dialga: 16% HP (Par)
[MN] Chasethebase's Absorber: 101 HP
Begin Turn #16
Dialga must recharge!
End of turn #16
[MN] Chasethebase's Absorber: 414 HP
Begin Turn #17
(271 damage)
End of turn #17
.REDILVER.'s Dialga: 6% HP (Par)
[MN] Chasethebase's Absorber: 399 HP
Begin Turn #18
End of turn #18
[MN] Chasethebase's Absorber: 670 HP
Begin Turn #19
(6% damage)
Dialga fainted!
.REDILVER. sent out Scizor (Lv.100 Scizor)!
Pointed stones dug into Scizor!
Using Salac Berry, the Speed of Scizor rose!
End of turn #19
.REDILVER.'s Scizor: 23% HP (Par)
[MN] Chasethebase's Absorber: 626 HP
Begin Turn #20
(23% damage)
Scizor fainted!
.REDILVER. sent out Snorlax (Lv.100 Snorlax)!
Pointed stones dug into Snorlax!
End of turn #20
.REDILVER.'s Snorlax: 88% HP
[MN] Chasethebase's Absorber: 582 HP
Begin Turn #21
Snorlax is paralyzed! It may be unable to move!
Snorlax is paralyzed! It can't move!
Snorlax is buffeted by the sandstorm!
End of turn #21
.REDILVER.'s Snorlax: 82% HP (Par)
[MN] Chasethebase's Absorber: 538 HP
Begin Turn #22
(22% damage)
Snorlax used Curse!
Snorlax's Attack rose!
Snorlax's Defense rose!
Snorlax's Speed fell!
End of turn #22
.REDILVER.'s Snorlax: 54% HP (Par)
[MN] Chasethebase's Absorber: 494 HP
Begin Turn #23
(22% damage)
Snorlax used Curse!
End of turn #23
.REDILVER.'s Snorlax: 26% HP (Par)
[MN] Chasethebase's Absorber: 450 HP
Begin Turn #24
(22% damage)
Snorlax fainted!
End of turn #24
[MN] Chasethebase's Absorber: 406 HP
Begin Turn #25
Opponent Forfeited
By now I hope you've all got your Netbattle programs configured and a team to battle with. Don't worry if you haven't perfected your party Pokemon yet. There are no penalizations for team changes between rounds. Here are this week's matchups.
Round One
1. George Vs -LordofPeanuts-
2. KinGAleX Vs natures_peril
3. Drathmoore Vs Chase
4. spoon Vs aapse
5. GTM Vs Pheidippides
6. toasters Vs PALEMOON
As a reminder, each round is played to the best of three matches. You can either PM the score to me, or better yet, post the results in this thread. I'll collate the results at the end of each round and post them up.
Get in contact with your opponents as soon as you can to get your matches underway! Please conduct your matches and submit your results by next Saturday, June 20th!
Good luck, and enjoy!
- Oops Pow Surprise
by nicnac
- Oops Pow Surprise
George wrote:Alrighty, lets get this started! The tournament will be completed over twelves rounds: nine rounds of League competition and three rounds of finals competition. Communist hasn't been able to feed me his status, so I'm assuming he won't be able to participate.
Round One
4. spoon Vs aapse
And who am I against?
Beat Drathmoore 3-0, 3-0, N/A. Good game.
- Oops Pow Surprise
Sorry about that, I kept on confusing you and cheesemonger. Get a unique username, dude.MyCheezKilledYours wrote:Heh. :P
I registered before aapse and spoon, yet George apparently skipped over my post.
Anyway, I'll rectify the issue right now. You have a bye for this round, MyCheezKilledYours.
Update: What will happen for the rest of the league is as follows: Six matches will be played each round except for rounds four and seven, where only five are conducted. That way, each player will play eight matches and have a bye during league competition.
by nicnac
- Oops Pow Surprise
Sounds good.George wrote:Sorry about that, I kept on confusing you and cheesemonger. Get a unique username, dude.MyCheezKilledYours wrote:Heh. :P
I would change my username if I could, but I think I'd have to ask an Admin. I'm not sure...
his team was pretty god tho
by nicnac
- Antagonistic Fencesitter
- NUMA Profile: http://nmaps.net/user/KinGAleX
The A Team is not very successful in real life.
by nicnac
Users browsing this forum: No registered users and 45 guests
