Post a Run!
Postby Cheez » 2009.07.07 (18:15)
Tunco123 wrote:
Cheez wrote:224 from Gutland without the corner shove.
I have a * next to my name, for once, so that's all that matters for me. :D
And that * speed is taken by me in 5 minutes. :)
And highscore.
Improved my speed by 4 frames, but not beaten you... yet.
This is why I should not post my 0ths here. :3
| last.fm | NUMA | RYM |
<@Izzy> van prefers it long.
Postby Tunco » 2009.07.07 (18:41)
Look at the corner jump. Awesome.
Postby Cheez » 2009.07.07 (18:43)
ME wrote:This is why I should not post my 0ths here. :3
Postby Tunco » 2009.07.07 (19:19)
*0th at 224 speed. (map above) Beaten xaelar, with 411 frames. Improvable though.
Postby xaelar » 2009.07.07 (20:32)
408 frames
Postby Tunco » 2009.07.07 (22:09)
xaelar wrote:408 frames
I'm just so tired right now, I will get this tomorrow. :/
Postby Cheez » 2009.07.07 (22:24)
Posting my 0ths here is like throwing a bone to xaelar and Tunco.
Postby Tunco » 2009.07.08 (09:47)
Cheez wrote:Posting my 0ths here is like throwing a bone to xaelar and Tunco.
And 224 speed is nominated by TFK with 400 frames.
Postby Cheez » 2009.07.08 (15:24)
xaelar got 388.
Postby Tunco » 2009.07.08 (16:44)
xaelar got 388.
That's what I call comedy.
Though, they are using the route I found, that's a consolation for me. :/
Postby Cheez » 2009.07.08 (23:14)
I beat ksktorng on [spoiler=his own map]172594[/spoiler]
Postby Tunco » 2009.07.09 (07:47)
Cheez wrote:I beat ksktorng on [spoiler=his own map]172594[/spoiler]
Yeah, then kkstrong beat you again.
Then a guy called fexe beat kkstrong.
Then I beat fexe, and got the 0th.
Postby 999_Springs » 2009.07.09 (13:29)
Tunco123 wrote:
Cheez wrote:I beat kkstrong on [spoiler=his own map]172594 (speedrun)[/spoiler]
206 frames.
MUAHAHAHAHAHA!!!
Postby xaelar » 2009.07.09 (13:50)
206 frames.
MUAHAHAHAHAHA!!!
I am angry -.-
I had the exact same time earlier but couldn't submit at that time =(
Postby Cheez » 2009.07.09 (15:31)
I really need to just keep my 0ths to myself sometimes.
._.
Postby Tunco » 2009.07.09 (16:51)
Cheez wrote:I really need to just keep my 0ths to myself sometimes.
http://n.infunity.com/numa_score_speedr ... =Seneschal :D
xaelar wrote:I had the exact same time earlier but couldn't submit at that time =(
Why?
I'm upset.
Postby glib_jase » 2009.07.09 (23:15)
I'm pretty sure my route on 96-1 can be modified slightly to incorporate the top centre gold, which should easily get 0th. I just can't figure out how to do it :-(
Postby vankusss » 2009.07.10 (00:14)
glib_jase wrote:I'm pretty sure my route on 96-1 can be modified slightly to incorporate the top centre gold, which should easily get 0th. I just can't figure out how to do it :-(
that's cool, 1 second behind 0th with agd-2 :O just figure it out before dark and you're fine :D
edit: Mr_Lim has agd-3, that makes your run less cool :(
Postby darkshadow » 2009.07.10 (05:24)
I actually have a pretty intense dislike for this level (yes I just took the speedrun, but I still don't like it). however it took all of about 2 seconds of glancing at it to see a route that I think is even faster however I may or may not end up testing it extensively because after spending time doing my speedrun I don't know if I feel like playing it again.
Edit: It looks like it's not faster.
Unreality's awesome mod
Postby Tunco » 2009.07.10 (08:48)
Speed and highscore on 170809.
Postby darkshadow » 2009.07.10 (23:37)
Okay, took 96-1 with a poor run (the route should be able to reach 109 easy).
Postby Raif » 2009.07.11 (06:55)
969 speedrun (157 frames) ;D
Edit1: Now 156 frames
Edit2: 286 speedrun (266 frames) (Thats also my 100th * on a numa map :D)
Edit3: Taken back 286 speedrun from xaelar by a frame
Postby glib_jase » 2009.07.12 (19:47)
96-1 ... My first ever 0th :-)
Using Darkshadow's route (sorry dark), although like he says it is improvable so I don't expect my score to last long. I'm pretty sure you can't get the last gold using this route - if I jump high enough to get it, I miss either the switch or the bottom gold on the way down.
Postby Cheez » 2009.07.12 (20:00)
glib_jase wrote:96-1 ... My first ever 0th :-)
Congrats!
I'm still a long way from getting a 0th, but there are still many levels I have not unlocked yet.
Postby darkshadow » 2009.07.12 (20:26)
No problem. I wasn't planning on holding onto that one (though I couldn't resist retaking it with a still quite slow run). The route can be made into an AGD but I'm working instead on an even faster route.
