Photoshop Help
I'm trying to make a sig in the Photoshop CS4 that I just installed. However, when I try to place a filter on a layer, I can only use the filters: Blur, Noise, Render, Filter, Sharpen, Stylize, Video, and Other, but the filters I want are blocked off from me. This may be the product of it being used a 30-day trial, as I have a student version, and have not gotten my code (I'll do the stuff I need to later). If it is, then that'd be really easy to fix.
I do requests. v
PNI's sig | #2 | #3
BNWN's sig
Rambo5252's sig
TribulatioN's sig
Isaacx's sig
nnn's sig
eganic's sig
deltainferno's sig
Slick265's sig
Sigs made for me
My competitionMy writing forum
- Walking on Broken Glass
- NUMA Profile: http://nmaps.net/user/%5D%7BNO3
I've had this problem, I think it may have something to do with the format, as in 16 bit or 8 bit... or something...Why Me wrote:I'm trying to make a sig in the Photoshop CS4 that I just installed. However, when I try to place a filter on a layer, I can only use the filters: Blur, Noise, Render, Filter, Sharpen, Stylize, Video, and Other, but the filters I want are blocked off from me. This may be the product of it being used a 30-day trial, as I have a student version, and have not gotten my code (I'll do the stuff I need to later). If it is, then that'd be really easy to fix.
I just played around with those kinda things which I knew nothing about, and it got working...
sorry I can't be more helpful
Nevermind. It doesn't work on that image, but it does on other images. Strange. This thread can be closed, or even removed if necessary.
I do requests. v
PNI's sig | #2 | #3
BNWN's sig
Rambo5252's sig
TribulatioN's sig
Isaacx's sig
nnn's sig
eganic's sig
deltainferno's sig
Slick265's sig
Sigs made for me
Are you in RGB/8? I think it might by in CMYK because that doesn't do anything when I go in that. :/
I was in RGB/32. But the other one (the one that worked) was in RGB/8.Flight wrote:Are you in RGB/8?
I do requests. v
PNI's sig | #2 | #3
BNWN's sig
Rambo5252's sig
TribulatioN's sig
Isaacx's sig
nnn's sig
eganic's sig
deltainferno's sig
Slick265's sig
Sigs made for me
Ah. I'm guessing you opened up an image and it was in that form.Why Me wrote:I was in RGB/32. But the other one (the one that worked) was in RGB/8.Flight wrote:Are you in RGB/8?
Yes, I opened up a render from planet renders, and, when my image wouldn't work, I just started working on that canvas.
I do requests. v
PNI's sig | #2 | #3
BNWN's sig
Rambo5252's sig
TribulatioN's sig
Isaacx's sig
nnn's sig
eganic's sig
deltainferno's sig
Slick265's sig
Sigs made for me
