Actually all you did was remind me to retry routes on that level using the jump pad. I had to come up with the route myself because I couldn't understand you when you described the route with a six-letter acronym. While meta came up with it first I did come up with that route independently.TheRealOne wrote:glib_jase wrote:darkshadow wrote:God Friggin' Damn It!
Edit: Got it five tries later.
Dude, that is an awesome innovation - how do you spot this kind of stuff? It just goes to show that even when a high scoring route looks like it has no alternative, it's always worth taking a second look.
Also, very nice 96-1 run, no way I can compete with that. I've given up trying to get that lower gold on the left when dropping down - it's the one point during the run when you need to avoid the rocket and you can't get far enough to the right at the top of the jump to get the right angle. Although no doubt someone will prove me wrong ;-)
Acctually that innovation was Meta_ing's. He showed it to me yesterday, and I let it slip to dark about it and he took the 0th a short while later.
Post a Run!
Unreality's awesome mod
hs and sr (depends on the route, it can be the same with right route)
slow FBF sr demo
i think that OutrightOJ is near max for hs with his 149 (submitted on sr)
i found this map pretty fun, that's because i'm putting it here
slow FBF sr demo
149 frame highscore, 148 frame speed,vankusss wrote:175006
slow FBF sr demo
131 frame underclock run, anyone up for this? :D
EDIT: 175026:
130 frames hs / sr, 125 underclock
175062 highscore and speedrun (both). I found this map pretty fun.
Claimed the highscoremohamedraif wrote:175062 highscore and speedrun (both). I found this map pretty fun.
Edit: Ties xaelar's speed run... twice in a row
I don't think you submitted itMickyTP wrote:84943. Really like my innovation. Should be easily improbable though.
<Izzy> Who are you?
<Meta> I'm meta?
( #n-highscores )
<Meta> I'm meta?
( #n-highscores )
It's 89493 xP
Taken both 0ths on that level (both speedrun and highscore)ToeFaceKiller wrote:It's 89493 xP
- Oops Pow Surprise
Taken highscore back from vankusss with a bad run. However, I don't have much time to play right now so it'll have to stay as it is.mohamedraif wrote:Taken both 0ths on that level (both speedrun and highscore)ToeFaceKiller wrote:It's 89493 xP
Edit:- Taken back speedrun from vankusss too. Now I really have to go.
26476 from kryx
<Izzy> Who are you?
<Meta> I'm meta?
( #n-highscores )
<Meta> I'm meta?
( #n-highscores )
The start of my 6-2 run is much faster than the current route. I'd like to see what xaelar or eru could do with it.
Edit: Another kryX bites the dust. 93-3. The route can be modified even more to do this (yes AGD is easily possible):
- RoboBarber
0th ;)The start of my 6-2 run is much faster than the current route. I'd like to see what xaelar or eru could do with it.
Nice innovation. I've become 195.025 with a missed gold.
Took 80000 from Meta.
Anyone want to try this on 6-4 speed (I'm still pretty pissed I screwed this up)?
Edit: And will someone please put together a decent run on 26-3 speed.
Edit: My 18-3 can be improved to at least 127.500 if not more.
Is this usually what happens on 10-1 or is it just me?
Taken by 13 frames over Van, with a pretty crappy run.jasdanu wrote:175449
33-4. I've had a route on the backburner for awhile that could reach well over 142 but required a lot of difficult jumps and needed one spot on rocket dodge so I decided that for now I'd just take it with this. (Interesting fact the route that gets to over 142 shares pretty much nothing with LAT's route)
Tied you :D (speedrun)TheRealOne wrote:Taken by 13 frames over Van, with a pretty crappy run.jasdanu wrote:175449
EDIT: 141.45 on 33-4. I'd love to see that route dark. Because I think this is one of the best and funniest levels from N :D
EDIT 2: 33-2 by 0.475, innovation again by dark ;)
Nice runs xaaaaeeeelaaaar! ;)xaelar wrote:Tied you :D (speedrun)TheRealOne wrote:Taken by 13 frames over Van, with a pretty crappy run.jasdanu wrote:175449
As per request:
The ending should be quite clear.
Edit: This might be slightly faster on 20-3:
Nicely done however while that method is easier it's actually significantly slower.xaelar wrote:33-3 by 3 frames.
EDIT: Improved 33-4 to 141.675 using most of darks innovation. I think this ending is faster and easier dark :D
EDIT 2: 141.900 :D
Edit: Make that maybe 8 frames slower. However I guess I showed how easy 142 is even with this method.
Edit 2: Congratz on 71400 total score xaelar.
