- Mr. Glass
Here's a fix for you!Techno wrote:Valve switched the default hand the Huntsman is on. ;-; I loved the original position (I'm a lefty). But since they added a lefty/righty option, ALL the weapons get switched over. That's not cool.
alias "flip" "flip_on"
alias "flip_on" "cl_flipviewmodels 1; alias flip flip_off"
alias "flip_off" "cl_flipviewmodels 0; alias flip flip_on"
bind "f" "flip"
If you've never messed with scripts before, you'll need to do the following:
First, you'll need to create the autoexec file. To do so, open notepad and save as 'autoexec.cfg', making sure you select 'all file types' before you do.
Then move the folder to: Steam > Steamapps > Username > Team Fortress 2 > tf > cfg.
Put any general scripts in the autoexec file (class specific need to be in the specific class folders).
Hope that helped.
- Legacy Elite
You're a genius.atob wrote: Here's a fix for you!
Put the above script into your autoexec file, change the bind "key" to whatever you want, and you have an instant switch between the two view models. Not only handy for those used to the old huntsman model, but also for quick switching to inch sentry nests with Soldier and Demo!Code: Select all
alias "flip" "flip_on" alias "flip_on" "cl_flipviewmodels 1; alias flip flip_off" alias "flip_off" "cl_flipviewmodels 0; alias flip flip_on" bind "f" "flip"
Hope that helped.
SEX FOR TOBatob wrote:Here's a fix for you!Techno wrote:Valve switched the default hand the Huntsman is on. ;-; I loved the original position (I'm a lefty). But since they added a lefty/righty option, ALL the weapons get switched over. That's not cool.
Hope that helped.
Content Edit: The airblast and force-a-nature not knocking back disguised spies does not make sense mechanically or in the gameplay sense. wtf?
- Legacy Elite
Actually, it does. You've never been able to juggle disguised spies using the rocket launcher or the sticky launcher, so it makes sense gameplay wise.SlappyMcGee wrote:Content Edit: The airblast and force-a-nature not knocking back disguised spies does not make sense mechanically or in the gameplay sense. wtf?
That said, I really disagree with this nerf to the airblast, since one of the best ways as a pyro to stop a spy getting a chain of stabs is to airblast him so that he can't backstab your teammates and then kill him, which, in my opinion, shows a good pyro player. Unfortunately, now you have to W+M1 the spy, while the spy can still get a few backstabs. Not sure if I agree or disagree about the nerf with regard to the FaN.
Calcy wrote:Actually, it does. You've never been able to juggle disguised spies using the rocket launcher or the sticky launcher, so it makes sense gameplay wise.SlappyMcGee wrote:Content Edit: The airblast and force-a-nature not knocking back disguised spies does not make sense mechanically or in the gameplay sense. wtf?
Well, then, I think they should have let you use rockets and stickies to knock away spies!
EDIT: OH NOES. THE RECENT UPDATE ALSO BLOCKED THE FLIP MODEL THING THAT ATOB MADE ;-;.
- Legacy Elite
I've put the plugin on the server, so I'll put the instructions on how to use it here. Put the following at the end of config.cfg, located by default in C:\Program Files\Steam\steamapps\<username>\team fortress 2\tf\cfg:Calcy wrote:By the way, guys, I'll (eventually) be placing a mod on the server that allows you to use a bind for alltalk even if alltalk is disabled. This'll effectively allow for both teamtalk and alltalk on the server. :D
alias +alltalk "voiceall; +voicerecord"
alias -alltalk "-voicerecord; voiceall"
bind f +alltalk
I found the Metanet server!
I have a ping in the high 400s!
Nobody is in the server!
[13:50:53] <Zeph> omfg 1950s jazz
Zephyr wrote:I got TF2!
I usually rile up a crowd, but I am sans PC attm.
Hey, I'll join. Join the IRC or PM me if you wanna start one up.Zephyr wrote:I got TF2!
- Semimember
Tsukatu wrote:It's been completely empty every time I've looked at it anyway. We'd actually need to promote outside of the community for it to be popular. Or populated, anyway. At all.
I used to get it pretty full, but I haven't had a PC in months.
I played 30+ hours last week, and about as many in weeks past. This week looks like it's going to keep that trend.
Still no fucking hats.
Shit is bogus.
- Beyond a Perfect Math Score
ALL YOUR HATS ARE BELONG TO ZEPHYR.
None-;_;
*edit* I'm going to try arena offblast tommorow.
New game mode: King of the Hill [KotH]
New KotH map: Viaduct. It's a snow map!
Plus might wanna change the title thread to "Official TF2 Thread" since there's not a server anymore.
