Surviving a fall on 43-0
I didn't originally post this because it never happened again and I didn't save the demo, but I was just curious if this ever happened to anyone else. I fell onto the ground after using the right side launch pad and survived, what the heck?
Unreality's awesome mod
- NUMA Profile: http://www.nmaps.net/user/malde37
- Location: In your head. There sure is alot of space here...
Can't say I have.
Like my Avatar? PM me and I'll make you one.
As a good friend of mine once said: "Woot!"
BeTa TeStInG Is ObViOuS
My webcomic, The ShadowStone Gang, can be found here.
True Quotes(Click here)
*The Monsters in my mind can beat up the ones in yours.
*I always pack one and a half pairs of underwear. That's one full one now, and, when you turn it inside out, another half later.
*I will never be seen without my goggles. For ,I see with them.
*I think I just ate my toe.
True Quotes from a Tornado Survivor
there are 10 types of people in this world. People who understand Binary, and people who don't.AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
Did you brush up against any of the protruding tiles on your way up? That may have kept you from going high enough to have a lethal fall.
There are no protruding tiles.Skyling wrote:Did you brush up against any of the protruding tiles on your way up? That may have kept you from going high enough to have a lethal fall.
Edit: It seems to regularly occur when dropping from high enough:
It may be that the start of the jump is calculated from how far into the launchpad you would be at the end of the frame therefore reducing the final height if you're hit it with the proper timing while going fast enough.
Oh, I thought you had said 45-0. Heh. Nevermind, then. Weird.
This sounds like the most probable explanation to me. Using the highly unscientific method of placing a horizontal line in front of the N window, you can clearly see that the height of the jump where you survive is significantly lower than the height of the jumps on that map when bouncing between the launch pads. Also when bouncing between the pads, the height of each jump looks constant regardless of any changes in direction, how much gold is collected etc. In other words, the only factor that changes the height of the bounce would appear to be the speed at which you hit the pad in the first place.darkshadow wrote:It may be that the start of the jump is calculated from how far into the launchpad you would be at the end of the frame therefore reducing the final height if you're hit it with the proper timing while going fast enough.
It also looks like the final jump on your 0th run is at the lower 'survival' height so you could *possibly* have avoided the wall-jump. Quality innovation in any case, congrats on the run!
Thanks. However I occasionally get a height that's about a pixel beyond survival height and I think I got it then.glib_jase wrote:It also looks like the final jump on your 0th run is at the lower 'survival' height so you could *possibly* have avoided the wall-jump. Quality innovation in any case, congrats on the run!
