IRC issue
Postby amomentlikethis » 2009.09.19 (02:42)
I've just moved to university and found that mIRC and Opera IRC are blocked. Yesterday I was able to connect to IRC using Mibbit.com, which I know sucks, but I'm guessing not much else will work.
Today, however, I'm getting this error: OperServ: The session limit for your host webchat.mibbit.com has been exceeded.
I don't know if this is a block by the university, but if not do you know any way to resolve the problem?
Is there any way to get on to mIRC without a proxy?
Hi.
Postby Tunco » 2009.09.19 (10:00)
Try to change your DNS server.
Postby origami_alligator » 2009.09.19 (13:54)
amomentlikethis wrote:I've just moved to university and found that mIRC and Opera IRC are blocked. Yesterday I was able to connect to IRC using Mibbit.com, which I know sucks, but I'm guessing not much else will work.
It means exactly what it says. Mibbit puts a cap on how long you can be on an IRC server from what I understand.
You could try downloading various other IRC clients. HyrdaIRC and Pidgin are what I'm familiar with and they both seem to do everything necessary. There are various others though that a Wikipedia search for "List of IRC clients" would show you.
Postby t̷s͢uk̕a͡t͜ư » 2009.09.19 (19:33)
I don't remember, but Meebo(.com) might have an IRC client.
Otherwise, if you're feeling more technical, you could find a remote machine on the outside that doesn't have that port blocked, and then tunnel all the traffic from it to you through ssh.
Postby amomentlikethis » 2009.09.20 (09:50)
Thanks for the help. I wouldn't have a clue how to do what Tsukatu said, but I'll have a look into different clients.
Hi.
NUMA Profile: http://nmaps.net/user/ninja143
Postby ninja143 » 2009.09.21 (14:01)
Ok I had the same problem, and I know its not as good as mIRC or opera, but try Chatzilla. It seems to go through on the network that is at my school, I just downloaded it to Firefox and was able to get on
Make sure to type
/server irc.mountai.net in and it should go pretty well.
Good luck!
Postby ChaoStar » 2009.09.21 (18:37)
ninja143 wrote:Ok I had the same problem, and I know its not as good as mIRC or opera, but try Chatzilla. It seems to go through on the network that is at my school, I just downloaded it to Firefox and was able to get on
Make sure to type
Good luck!
I'm pretty sure that cZ is the best.
Postby Pikman » 2009.09.21 (22:58)
Tsukatu wrote:Meebo(.com) might have an IRC client.
Nah, it just links a bunch of social networking and chat sites into a single place. No IRC there.
