No name borders
Postby Tunco » 2009.09.20 (09:25)
wedgie wrote:Just make chrome the default skin and dump the others. Then you don't have to worry about making the colours match more than one skin.
It's a skin with tons of bugs. Shouldn't be the default skin until Retronet is out. :/
Postby Chase » 2009.09.20 (16:26)
When it's fixed it will probably default, but Retronet will probably be far superior so we'll probably end up using that instead.
Or I'll make a Chrome v2.
Postby Tunco » 2009.09.20 (18:23)
Chrome v2? Why not make another skin instead making v2?
-Retronet-
Postby Chase » 2009.09.21 (18:15)
Tunco123 wrote:Chrome v2? Why not make another skin instead making v2?
-Retronet-
To be honest I'm quite happy with dumping Chrome all together once Retronet is finished.
Because Robotology seems set for a 2011 release maybe?
Postby otters » 2009.09.21 (20:31)
I prefer Hermes, though. :/
I can fix that.
Postby SlappyMcGee » 2009.09.21 (20:41)
I can fix that.
Bold. I like your style, boy.
Postby T3chno » 2009.09.21 (22:02)
I can fix that.
Incluye is the forum's Bob the Builder.
Postby Chase » 2009.10.17 (10:42)
user name problem solved. Go use Chrome. :)
EDIT: Half solved.
Postby squibbles » 2009.10.17 (12:40)
If you cannot see any changes, press ctrl + F5. You'll need to refresh cookies. I had that problem, but fortunately knew how to fix it.
