Computer Problems
Postby t̷s͢uk̕a͡t͜ư » 2009.09.23 (09:36)
I was trying this thing, but I can't get it to do right. Help!! :o
Postby Atilla » 2009.09.23 (11:13)
Have you tried reversing the polarity of the secondary transfluxor array?
Postby Vyacheslav » 2009.09.23 (11:27)
Try restarting first and then see if your problem occurs again.
Postby otters~1 » 2009.09.23 (13:42)
Take off your clothes. Blindfold yourself.
Postby T3chno » 2009.09.23 (22:01)
You know what you need?
Some Pan-Galactic Gargle Blaster.
Postby smartalco » 2009.09.23 (23:22)
Try holding down ctrl-shift-option-F6-4-8-*-home-s-k-Esc-RMB for exactly 7.4 seconds on the first tuesday after a full moon.
Postby otters » 2009.09.24 (01:09)
You'll need to aptget the telnet client and try to reflux the hosts folder. If that doesn't work, reboot your handlers and reflap.
Postby t̷s͢uk̕a͡t͜ư » 2009.09.24 (04:51)
I tried to do what you said but I might've done it wrong. The problem persists, albeit only partially.
Where did I mess up?
Postby aids » 2009.09.24 (05:05)
flagmyidol wrote:Take off your clothes. Blindfold yourself.
Sig'd.
Postby Vyacheslav » 2009.09.24 (12:19)
Tsukatu wrote:I tried to do what you said but I might've done it wrong. The problem persists, albeit only partially.
Hey, what are your computer specs? OS?
Postby Tanner » 2009.09.24 (13:22)
87654321 wrote:Hey, what are your computer specs? OS?
Also, towards which cardinal direction does your DVD drive open? Try pointing it towards Mecca.
Postby t̷s͢uk̕a͡t͜ư » 2009.09.24 (18:34)
I think it's a Dell, but it could be a Mac.
Postby otters~1 » 2009.09.24 (21:27)
I admit I smiled at that.
Postby Lenny » 2009.09.25 (09:07)
Hahaha, that's quite clever.
Also, your ambiguous multi-OS could easily be causing the problem. You may want to consider unplugging every single plug, then turning it into an amazingly large paperweight.
Postby 乳头的早餐谷物 » 2009.09.25 (09:27)
Get a Mac.
Postby Tunco » 2009.09.25 (12:30)
ortsz wrote:Get a Mac.
Install Linux to your Windows Vista/XP whatever.
Postby scythe » 2009.09.25 (12:48)
Have you tried formatting your motherboard?
Postby Vyacheslav » 2009.09.25 (13:34)
Have you tried pressing the any key?
Postby otters » 2009.09.25 (15:45)
If the keyboard can't connect, press F1 to continue.
Postby t̷s͢uk̕a͡t͜ư » 2009.09.25 (18:35)
I solved the problem.
Thanks!!
As this is probably a common problem, I'm going to sticky this so that people can link to it if someone comes by with the same issue.
Postby T3chno » 2009.09.26 (00:01)
I told you to not use the phone with dial-up connected. :P
Silly Suki
Postby Ampersand » 2009.09.26 (02:08)
GLOBAL ANNOUNCEMENT'D!
Postby beethoveN » 2009.09.26 (02:36)
what thing?
If we shadows have offended,
William Shakespeare
Postby OneSevenNine » 2009.09.26 (04:12)
Make a little voodoo doll of your system32 folder, and poke it randomly until you find the corrupted data. Then cut out the affected area, burn it, and scatter the ashes onto your motherboard.
:loud music:
Postby Ignate » 2009.09.26 (05:31)
Smack your computer with a wrench.
And if that fails, use Glad Force Flex Bags. Crisis aversion guaranteed.
