Postby Unreality » 2008.10.13 (12:51)
Are you hungered for more levels to highscore? Do you want to compete Legacy packs with your friends and all N players in the world online?
With the love of N, I have created this add-on to the current N.
NReality6g2 is ready for testing now. Please report any bugs that you have found. And Please backup your sol file first.
http://n.infunity.com/downloads/NReality6g2.zip
It has an additional 100 episodes to the game.
It has added two new modes for the game:
Speedrun mode & slowdown mode
column 10th - 11th:
Blue_tetris super hard column 1 & 2
column 12th - 19th
Legacy Original Pack
Column 0 - tktktk
Column 1 - LittleViking001
Column 2 - nevermore
Column 3 - maximo
Column 4 - Kablizzy
Column 5 - Kablizzy
Column 6 - maximo
Column 7 - tktktk
It has epi 100 to 199 online highscores support at my highscores server.
Please report to me for any bad names/cheated scores!
All scores which are 0th or past 0th will have a "*" in front of the player name of that score
Latest top 20 episode/level scores
http://n.infunity.com/latest_ep_score.php
http://n.infunity.com/latest_lv_score.php
You can view a player highscores here:
http://n.infunity.com/user_score.php?name=[user name]
http://n.infunity.com/ep_score.php?name=[user name]
e.g.
http://n.infunity.com/user_score.php?name=mr_lim
http://n.infunity.com/ep_score.php?name=mr_lim
background:
<LittleViking> Hey, Unreality, I forwarded a PM to you from Raigan.
<LittleViking> It looks like they're okay with your mod if you use a different highscore server, and they'd prefer if you package it in an exe to help protect against hacking.
It blocks the direct usage of speedhack
It supports online level highscore recovery (by ctrl click your online score).
v6g2 feature added:
IRC integrated. Enlarge the NReality screen to see the IRC panels.
v6g feature added:
display state for showing button pressed
demo circle and prev-run circle to show the "shadow" of the demo / previous run
v6c2 to v6d features added:
Way too many drone mods added :) all mods are in version 6c2 transparent update, and then packed into v6d.
For all details visit http://metanet.2.forumer.com/index.php?showtopic=19543
v6b Bug fixed:
1. Fixed a score submission bugs. Now all version 5a,5b,6a,6b scores should be able to submit without any problems. You can re-submit your version 4 runs, but version 4 runs will always be ranked lower than version 5+ runs.
v6a Bugs fixed & features added:
1. Fixed the bug of non-login & different username score submission
2. Added foreground image for custom map. To add it, put "|background_pic_url|foreground_pic_url" in front of the last # of the map data, like:
#mapdata.......................................|background_pic_url|foreground_pic_url#
Image dimension is 792x600, please note that the top left of the foreground image will cover the first row of the map, while the background image will be covered by the first row of the map.
3. Support png/gif/jpg format for custom fore/background images.
4. You can try speedmode even if you haven't cleared 6 columns. To try underclock mode you still need to clear 6 columns.
5. All local version 4 or older runs will be replaced with new runs.
6. NReality server now host its own legit episode 0-99 highscores.
7. NReality server has removed all episode 100-199 version 4 runs, to ensure that all runs in NReality server is legit.
8. It doesn't load your userlevels.txt anymore. In userlevel screen, you can type the numa map ID, and then that numa map will be loaded for you.
9. ctrl-click your custom map highscores will submit your custom map highscores to NReality server, and then the ranking table of that map will be prompted.
v5b Bug fixed:
1. Fixed episode score update bug.
2. Fixed flavours unlock bug.
v5a Feature added:
1. Custom web background picture for user level: add "|http://www.yourdomain.com/yourpic.jpg" just before the last # of your map data. You can only use jpg as the picture format.
2. Added two game modes: Speed-run and underclock mode. For speed-run mode, the less frames your run, the better your scores. For underclock mode, you can play levels with FBF fashion.
3. Online highscores & speedrun & underclock ranking tables.
4. Goddy enhanced security.
5. Episode highscores recovery, level highscores recovery, and episode/level beaten recovery. All done by Ctrl-clicking your online top 20 highscores in the game.
6. Frame data display
v4 bugs fixed:
1. fixed the problem that forced you to clear the entire episode to have the levels unlocked.
2. fixed the problem that caused the levels of last episodes impossible to be unlocked.
3. The grid button is not tab-able now.
Disclaimer:
1. There is no N source code recompilation. I haven't modified the programming code of N. My add on made use of the N functions externally and attach additional episodes onto it.
2. I WILL NEVER STORE YOUR N PASSWORD at my highscores server.
** For those who loves this add-on, please shows your support :) thanks
reduct lag for NReality:
p.s. You can check your unsubmitted score by using NReality Score Comparer http://n.infunity.com/downloads/NRealit ... mparer.zip
Postby Pixon » 2008.10.13 (13:22)
I really ought to try NReality sometime.
Postby Universezero » 2008.10.13 (19:47)
Unreality, when are we going to get some more mods? I can't wait!
Postby handofgod » 2008.10.14 (01:43)
ditto.
NUMA Profile: http://nmaps.net/user/Splinter
Postby Splinter » 2008.10.14 (22:03)
*beyond pointless request*
Couldnt the blue_tetris super hard columns come AFTER the legacy teams columns? :p
Postby Unreality » 2008.10.15 (14:43)
heh i'm still busying with my own flash multiplayer game http://www.infunity.com
I will get back some time to work on NReality :) ( are the nreality haters gone yet? :p )
by the way, since legacy pack 2 & 3 will come after legacy pack 1, so I think super hard column shouldn't be after legacy pack 1 :)
MBTI Type: ESTP
Postby kkstrong » 2008.10.15 (15:52)
The NReality haters are gone ^_^
Postby Unreality » 2008.10.16 (01:31)
kkstrong wrote:The NReality haters are gone ^_^
has the map judging finished? :)
MBTI Type: ESTP
Postby kkstrong » 2008.10.16 (05:12)
No, both judges dropped, and I can;t find replacments, so I may just end up judging myself...
Postby Condog » 2008.10.17 (07:23)
Nreality is currently failing to load NUMA levels correctly. Is this to do with NUMA or infunity, and could it be fixed soon? Is this happening to anyone else?
Postby Riobe » 2008.10.17 (07:34)
Condog wrote:Nreality is currently failing to load NUMA levels correctly. Is this to do with NUMA or infunity, and could it be fixed soon? Is this happening to anyone else?
No mods worked for me before, now NUMA Maps just won't load altogether now...
Fix please Unreality. =/
MBTI Type: ESTP
Postby kkstrong » 2008.10.18 (02:18)
Yeah Condog, same for me.
Postby squibbles » 2008.10.18 (02:30)
I'm fairly sure that the server is down at the moment...I am unable to connet to his site to see who won my comp :(
Postby Nexx » 2008.10.23 (17:18)
n.infunity is refusing to load the full list of a player's highscores again. Maybe my internet's just slow, but it seems like it loads for a while and then it times out and just stops. I remember this used to happen, but then you did something and it worked again. Any ideas?
EDIT: Another old problem has come up again! Remember I contacted you awhile back because my drone jumper played choppily in NReality and fine in N v1.4? You fixed it, and it worked for awhile at least, but as of I-don't-know-how-recently, the choppiness is back.
Postby Condog » 2008.10.23 (23:55)
Avarin wrote:n.infunity is refusing to load the full list of a player's highscores again. Maybe my internet's just slow, but it seems like it loads for a while and then it times out and just stops. I remember this used to happen, but then you did something and it worked again. Any ideas?
I'm pretty sure the server is down at the moment. I can still load maps via NUMA and some of the first mods work, but nothing more than that. As we haven't heard from Unreality in a while, all we can do is trust that he is fixing the issue. Just remember that fixing Nreality isn't going to be his highest priority, so it might take some time.
Postby ska » 2008.10.24 (00:41)
My NReality has been crashing quite frequently and unexpectedly lately, it used to only every rarely crash (when i had lots of programs running or it lagged) but now it seems to crash randomly, more often for no reason in particular (even with NReality as my only running program running at 8 mf/s.) Anyone else noticed an increase in faulty speed-hack detection lately or is just me? It's extremely annoying.
Postby EdoI » 2008.10.25 (19:08)
Hey dude! I get error soon while downloading NReality (n.infunity.com I get it after 11.7 KB; on ...google... I get it after 500 KB's I think). Any outside mirrors?
You know what I think it would be really cool? You know HOMM 3's famous map generator that is imlemented in the game? Well, it would be cool if you see with LV that you implement it too, just by clicking 'random map' that would be in userlevels section. You press it and the map appears.
I don't know is it possible, I'm not that kind of programmer.
Postby EdoI » 2008.10.25 (19:27)
Postby KlanKaos » 2008.10.26 (07:59)
My problems to add to the ever-growing list:
NReality won't record my personal bests. Every time I complete a map it's a new one, and it never saves.
It also won't load highscores.
Postby Yoshimo » 2008.11.01 (20:45)
Hehe, I found a way to make flavors with Nreality. Just incase you haven't decided you like bunnies
Check it out.
Hmm, by the way, I think something is wrong in this map. Hmm...
Postby Rikaninja » 2008.11.04 (06:31)
Awesome, this nreality thing is spectacular! I even play levels which don't involve nreality on the program now!
Nice work Unreality, I can't imagine what the world would be with out you!
Thanks agin :)
Postby EdoI » 2008.11.04 (18:41)
Stopped on 725 KB's. Twice.
I still need ==MIRROR DOWNLOAD==
Postby Geti » 2008.11.06 (13:48)
EdoI wrote:I still need ==MIRROR DOWNLOAD==
shush, shouting will get you nowhere with us. downloading has worked fine for the rest of us. download it at a friends place.
now, Unreality, would it be possible for you to give us the power to stretch the play area again? i miss my fullscreen N. just make a button for "stretch to window".. please? the reason im asking is a few updates ago i could right click nreality and set an option where it filled the window, as well as setting it to low quality for my resource poor machine, and these are both options that i miss. back please? in button form maybe?
God knows if i'm back.
Postby Rikaninja » 2008.11.07 (05:47)
When I downloaded NReality everything went fine.
Could you please start a thread where we suggest (hopefully possible) new features for NReality?
I've already thought of one; Like the other drones (lasers, chainguns, zaps etc.) could the NReality drones like ghost drones and stuff be inserted in the same way. I find that code can be troubling. Especially with the playermods!
And once again let me mention that your a genius!
Postby 乳头的早餐谷物 » 2008.11.07 (05:55)
Rikaninja wrote:When I downloaded NReality everything went fine.
If you want anyone using the default skin to read your posts you probably shouldn't set your text colour to black.
