Level data not saving ater episode completion
- Quarks
Hadiran
If you don't have that, you don't have the .sol file. You need to create localhost manually and .sol too. Be careful with that.Hadiran wrote: (acually, there is no localhost folder in the macromedia folder)
- Quarks
Any idea on how I would go about doing that? The localhost folder should be in a folder with random letters/numbers, so I'm not sure how I would choose the name for that part.Tunco123 wrote:If you don't have that, you don't have the .sol file. You need to create localhost manually and .sol too. Be careful with that.Hadiran wrote: (acually, there is no localhost folder in the macromedia folder)
Well, formatting your PC would be a answer to your question, but it would take long time, and too much crap.Hadiran wrote:Any idea on how I would go about doing that? The localhost folder should be in a folder with random letters/numbers, so I'm not sure hoe I would choose the name for that part.Tunco123 wrote:If you don't have that, you don't have the .sol file. You need to create localhost manually and .sol too. Be careful with that.Hadiran wrote: (acually, there is no localhost folder in the macromedia folder)
Well, no need to localhost, go to C:>Users>Username>AppData>Roaming>Macromedia>Flash Player>Shared Objects>I suggest you to just type any numbers and letters randomly to here>some files that should be URL -should end with .com or etc.- >if you don't have a file named localhost, create one, and click it> create a .sol file and be sure that it's a notepad file.
Win.
- Quarks
fyi, I have a Mac. The file positions aren't too different though.
- Quarks
- Quarks
Will do. Thanks.Tunco123 wrote:Hmm. Email your problem to M&R, [email protected]. They could help you about your problem.
- Quarks
I did. It didn't work though. :(golfkid wrote:Hey, did you ever try going to the configure screen and logging in/making an account? I did that on a seperate computer that hadn't had N played on it to test this out. It didn't save my progress initially, but then as soon as I logged in it saved my data in a .sol.
