Took 57-3. ;) A thwump push could save like 20-30 frames or even more.
Thanks for the compliments guys, I'm really happy about the progress I've made since I started playing again in August and it's cool that others are noticing it as well.
Macro, your run is pretty neat; I didn't think it was improvable by that much :P
yeah... that would be hella dope to pull off in a complete, real-time run.alsojp27ace wrote:Nice run macro, I was originally trying to get a cj into thwump push, put I couldnt do it at all consistently
Retaken 57-3 :)alsojp27ace wrote:Retaken 57-3 :)
I think with a BWJ off the thwump, instead of jumping off the 1-tile, might allow you to reach the fall on the right side with out touching the floor. That would save a nice chunk of time. I am not sure if the gauss will get you though.macrohenry wrote:Retaken 57-3 :)alsojp27ace wrote:Retaken 57-3 :)
That's definitely possible. I even did it a few times, but died later in the run.
EDIT: Took 29-4 with a new route, but I'm sure there are even faster ones.
EDIT 2: Tied 54-1.
EDIT 3: Took 26-0.
EDIT 2: Tied 54-1.
EDIT 3: Took 26-0.
I doubt it. Unless you can gain more velocity, I think 124 is the max.jasdanu wrote:Ok it might just be me but I think there is one frame left on 129-3. I originally got 124 but as I keep watching the demo, it feels like 123 is possible if we can get closer to the laser.
Playing some N again after another fairly long break; took 55-3.
crap... just took the 0th without seeing this innov...alsojp27ace wrote:Welcome back, nice run. Here's a little innov you can try if you can be bothered (You have to start running a few frames late or you run into the drones, but other than that its pretty simple)MiBeM wrote:Playing some N again after another fairly long break; took 55-3.
569 without - to 556 (still improvable obviously...)
Edit 1: i will try and clean it up more when i'm less intoxicated.
Edit 2: Got 537 after more than a hour of trying tonight, and will probably be taken in less than 5 minutes by macrohenry. Nevertheless, I'm actually pretty satisfied with the run as it stands.
YES! Still hasn't been beaten yet! :D
- Walking on Broken Glass
- NUMA Profile: http://nmaps.net/user/Kool-aid
;__; sorry ska your innov/route was way too juicy, not sinking my teeth into it would be blatantly disrespectful to biggie smalls.ska wrote:YES! Still hasn't been beaten yet! :D
Don't blame me, blame the B.I.G.
Edit: Check this for 55-4 http://pastebin.com/4gLkV4sd I'm trying to get one more lj on top
Damn that ascent was clean and that little innovation at the exit switch save a surprisingly large amount of time. I wouldn't have thought the WJ was that much slower. Nice job man.Kool wrote:;__; sorry ska your innov/route was way too juicy, not sinking my teeth into it would be blatantly disrespectful to biggie smalls.ska wrote:YES! Still hasn't been beaten yet! :D
thanks brudda, yo check out that pastebin I just edited in to my last post for 55-4. It saves a shit ton of frames if I can pull 3 off.
Whoa! That is a novel idea right there. I would not have thought of that. Yeah it is a hell of a lot faster. Hopefully it doesn't require too much luck of the third one. Low Jumps are so finicky with respect to the ninja's position. Certainly possible though.Kool wrote:thanks brudda, yo check out that pastebin I just edited in to my last post for 55-4. It saves a shit ton of frames if I can pull 3 off.
Nice tweaking! Biggie Smalls sends you his love from above. (Metaphorically speaking, of course.)Kool wrote:;__; sorry ska your innov/route was way too juicy, not sinking my teeth into it would be blatantly disrespectful to biggie smalls.ska wrote:YES! Still hasn't been beaten yet! :D
Biggie Biggie Biggie can't you see. Sometimes kool's runs just hypnotize me.
Also, nice idea for 55-4. Could someone MBD that, to see how much time it could actually save if properly executed?
Low jumps can be surprisingly useful in some levels. I have worked out an innovation using a low jump for a highscore on a different level. I hope I'll be able to show you what I mean soon.
Took Ep77!
EDIT: and Ep78!
EDIT: and Ep78!
Sig by Aidiera.
My Accomplishments
Managed to do three low jumps on 55-4. It's only a 536f run because I messed up the rest of the run. The low jumps are actually not much faster than the current route if you compare van's run with mine.
Took 87-4 and tied 62-0.
cool. I'd like to see you use Meta's rcj in 87-4 though... there's more time to be saved there...macrohenry wrote:Managed to do three low jumps on 55-4. It's only a 536f run because I messed up the rest of the run. The low jumps are actually not much faster than the current route if you compare van's run with mine.
