Postby glib_jase » 2012.02.27 (06:35)
Due to the "semi-random" nature of chainguns it may be possible to get this to work on 9-0 which should be faster than using the jump-pad?
Postby ska » 2012.02.27 (12:18)
glib_jase wrote:Due to the "semi-random" nature of chainguns it may be possible to get this to work on 9-0 which should be faster than using the jump-pad?
good idea.. but it's not very effective, even without the chaingun...
what is effective is the falling corner jump on the left side...
Postby eru_bahagon » 2012.02.27 (13:58)
Better use the same beginning as me (not mine!). Faster than ska. And pretty similar to your demo.
Postby ska » 2012.02.27 (14:41)
hmm.. I tried that.. thought it was about the same speed.. well, thanks eru :P Nice run.
Postby golf » 2012.03.05 (06:07)
Not really an innovation, but here goes. I came up with this after playing 5-3 and watching the other replays. If somebody could combine Pony's route with grabbing the far left gold, that would be an easy 0th. I just know that I had a hard enough time with skipping that one that I'm not able to do it.
Postby Raif » 2012.03.05 (14:39)
golf wrote:Not really an innovation, but here goes. I came up with this after playing 5-3 and watching the other replays. If somebody could combine Pony's route with grabbing the far left gold, that would be an easy 0th. I just know that I had a hard enough time with skipping that one that I'm not able to do it.
Neither Eddy or van could pull this off. I don't remember why exactly but they both had the same reasons. I think it was something to do with a drone.
Postby vankusss » 2012.03.16 (23:58)
raif tell me something about this
Postby Raif » 2012.03.17 (01:13)
vankusss wrote:raif tell me something about this
Impossible, by my testing.
Postby glib_jase » 2012.03.29 (19:31)
Quicker start for 56-3. I was so surprised the CJ took me so far that I then went to pieces, and I can't nail it again!
Postby ska » 2012.03.30 (15:46)
great innovation, glib :)
Really thinking outside the box there. I BELIEVE IN YOU.
Postby vankusss » 2012.03.30 (16:05)
Looks promising, my bold eye estimated a rough saving around 20 frames. Go on, glib_jason!
Postby Kool » 2012.03.30 (20:32)
I say 30 frames more or less ;) great innov glib. giving it a go atm
Postby vankusss » 2012.03.30 (22:22)
56-3, route:
And since you need around 60 frames to beat the drones, do this:
and clean the top.
EDIT: I have a run now, but it doesn't seem to be faster. Maybe there is faster route for bot/top. Or it's just inevitably slower, who knows. But it definitely looks cooler.
Postby glib_jase » 2012.04.01 (22:17)
Pains me to say it but I've taken the 0th without using any of these innovations. I just couldn't repeat my CJ start.
Postby EddyMataGallos » 2012.04.01 (23:46)
Wow nice run glib :D a pity you didnt use your innov, but anyway, still really fast ;)
Postby TheRealOne » 2012.04.02 (03:39)
glib_jase wrote:Pains me to say it but I've taken the 0th without using any of these innovations. I just couldn't repeat my CJ start.
Very nice glib. That ending was stunning. Even with out the innovation it was a solid run. That will be near impossible to beat with out the innovation now though.
Lords a-Leaping
Postby mfb » 2012.04.04 (16:26)
Could this save some time at 180-3?
Postby amomentlikethis » 2012.05.21 (22:27)
Would this be possible on 31-0 speedrun?
Hi.
Postby TheRealOne » 2012.05.23 (01:09)
I highly doubt it, You need a lot of sideways momentum to be forced up that high by a thwump. Take a look at my Ode to Thwumps map. I do one of those pushes across the top and you can see how hard I had to hit that thwump to get that much height.
Postby Kool » 2012.07.24 (23:39)
An innov for 7-2 sr (watch in ghost vs. van's run) if it wasn't for my screw up at the top right switch I would have been in the clear D:
http://pastebin.com/GwvnYt62
Postby ska » 2012.07.25 (03:54)
Kool wrote:An innov for 7-2 sr (watch in ghost vs. van's run) if it wasn't for my screw up at the top right switch I would have been in the clear D:
sweet innov, Koolio.
Postby Kool » 2012.07.25 (22:33)
Thank you sir :)
Also 35-3 hs innov, you guys will see it shortly in a subbed demo (instead of falling to the right as van does, fall to the left and land on the 1-tile)
Postby glib_jase » 2012.08.01 (18:45)
Small innovation this one ... on 59-3 using van's and xaelar's start, after the second switch it's possible to "skip" over to the right hand side:
Postby vankusss » 2012.08.29 (19:32)
My route on 79-2. I'm sure you can get within 20 frames of 0th, dunno about beating it (maybe using golf's trick on the left side - it's possible, i did it once (dunno how it works though)).
Postby golf » 2012.08.30 (00:11)
I don't think you can use my trick on the left side, because you need to be coming at the bb from the side with a decent speed, and not from above. Otherwise a very good route, I agree it probably is able to be Analu's time.
