ModMaster v1.4 *** Dronie Award :: Program Of The Year ***
MBTI Type: ESTP
Postby kkstrong » 2009.05.19 (19:47)
Just an update on the program. I have made some major modifications on the program, including many more features. However, I am working on a site to host it on, and to get updates from through the internet, so that you do not have to download modmaster every single time I update. We'll see if it works!
(I've never designed a functional site before, if anyone would like to help me out or teach me some basics, it would immensly speed up the process, and help me out a lot!
Postby Superpok » 2009.05.21 (04:45)
i can do a little bit of visual stuidio, but not much really, but great job on the program!
the only thing i can see is to make it a little more clear on what you should replace the x, y, path etc... with
that would help
Signature Bars
Postby origami_alligator » 2009.05.21 (07:53)
kkstrong wrote:On the objects/drones that you can code individually on:
  • You will only be able to do one line at a time. To make several of these objects in a map simply:
    1. Enter in Values in each text box (note: if you leave a text box blank, it will not crash the program, the program will just simply ignore it)
    2. Press the "Calculate Code" Button
    3. Copy and Paste given code, and replace words with correct values
    4. Repeat until desire is fulfilled (what will happen is the code will just be replaced)
Note: I have entered in the default values for all of these. If you calculate code with these given values, the object will appear normal in NReality.
On objects/drones that you cannot code individually on:
  • You will only be able to calculate one mod at a time. To use this function:
    1. Choose Mods you would like to use. By checking the boxes, you will turn off the read-only function assigned to the text boxes, and you will be able to write in the text boxes. ( you can see the readonly function is marked by a slightly bluish tint)
    2. Enter in values for boxes.
    3. Press the "Calculate Code" Button.
    4. Copy and Paste given code, and replace words with correct values.
      If you would like to do this several times, remove the values of "x,y,path" and replace them with desired code.
    5. Repeat until desire is fulfilled (what will happen is the code will just be replaced)
Thought I'd make this section look a little nicer for ya. ;D
MBTI Type: ESTP
Postby kkstrong » 2009.05.24 (05:51)
MBTI Type: ESTP
Postby kkstrong » 2009.05.24 (06:17)
Hmmm.... 1.2 had a major bug in the triggers section, so here is 1.3
http://www.box.net/shared/6kk2thvl4k
Triforce
Postby claskotheknight » 2009.06.05 (18:07)
this is a great program thanks for makeing it, but i have a few improvments
take out the check boxes
make the link in the playermods tab work
have the ! that you have to put in automatic
put a direction,and a path dropdown arrow
have a x and y coordinate box and
explain how to put in multiple things that start with a | and have them all work
MBTI Type: ESTP
Postby kkstrong » 2009.06.06 (02:04)
The reason I didn't put in the x,y, path, and direction is because this is too help with NReality mods, and it wold get annoying to have to place them in. However, once I figure out how to split text, I can make it better, but until then I don't know what to tell you.
As for the other suggestions, I'll consider em.
Triforce
Postby claskotheknight » 2009.06.06 (23:25)
and for now what is the link in the playermods meant to be?
MBTI Type: ESTP
Postby kkstrong » 2009.06.07 (18:00)
Triforce
Postby claskotheknight » 2009.06.08 (21:10)
thanks =)
MBTI Type: ESTP
Postby kkstrong » 2009.10.23 (15:40)
Postby amomentlikethis » 2009.10.24 (01:39)
kkstrong wrote: - Hyperlink in playermods sections working
<3
Hi.
NUMA Profile: http://nmaps.net/user/n0_ma11y
Postby n0_ma11y » 2009.11.09 (23:12)
tihs is so scik adn aswmoe. ncie job P.S, I use tihs aolt.
map pack ^
Postby Izzy » 2009.11.10 (00:16)
n0_ma11y wrote:tihs is so scik adn aswmoe. ncie job P.S, I use tihs aolt.
The most used language here is English. You should try it.
Postby n0_ma11y » 2009.11.14 (05:14)
sOme of the pathing things are wrong.
map pack ^
Postby Cheez » 2009.12.10 (01:19)
I have the same problem as Xaelar.
What is the Framework thing supposed to do to help me? I'm running an XP by the way.
| last.fm | NUMA | RYM |
<@Izzy> van prefers it long.
Postby chume14 » 2009.12.13 (15:36)
Hey so the section of the program which generates icon mods is broken if you want to put an icon on a tile-drone it should generate this
||||122,_icon,^^http://img189.imageshack.us/img189/9536/cannonball.png|#
but it generates this instead it has the wrong number for tile-drone and many of the other mods
||||0,_icon,^^http://img189.imageshack.us/img189/9536/cannonball.png|#
Also when you add a pathing mod to something which already has multiple ^ it then gives you to many ^'s befor the pathing section you should fix this cause it took me ages to work out what I was doing wrong when I first started modding.
Thanks for this program it's really useful good work
Postby ninja_matt » 2009.12.30 (10:10)
Well done, this is awesome!
Postby Cheez » 2010.01.13 (00:03)
By the way kkstrong, in the playermods, it's not maxgroundspeed; it's maxSpeedGround.
Postby fawk » 2010.02.06 (21:23)
Not particularly important, but on the Nreality site the link to this thread still links to therealn.com
Postby Neil_Bryan » 2010.03.14 (02:19)
Best program ever!
I even haven't downloaded the latest ModMaster version....yet. But I'll say, it's a lot easier now making codes for Nreality this time!
Names of Towns
Shortest: Y
Triforce
NUMA Profile: http://nmaps.net/user/rubberninja
Postby rubberninja » 2010.04.04 (17:58)
where can i locate nreality helper 2? i really want to use modmaster!
MBTI Type: ESTP
Postby kkstrong » 2010.04.05 (14:44)
It is on the first topic of this post. Please read before posting next time.
Also ~~800 downloads~~
Triforce
Postby rubberninja » 2010.04.07 (09:34)
kkstrong wrote:It is on the first topic of this post. Please read before posting next time.
yeah, i know, but i mean which file when i download it.
MBTI Type: ESTP
Postby kkstrong » 2010.04.12 (15:26)
Modmaster 1.4.exe
