Post a Run!
Postby xaelar » 2010.07.19 (20:27)
Nonono, I'm just lurking.
162387 sr
Postby ska » 2010.07.20 (12:05)
xaelar wrote:Nonono, I'm just lurking.
162387 sr
Took it using hs mode by a solitary frame... for some reason, it didn't submit to speedrun more :/
Postby Raif » 2010.07.20 (16:05)
163-1 speed 0th by 8 frames with Dawiki's accidental innov. 36 should be possible (Edit: Ok, maybe not.)
Postby ska » 2010.07.21 (16:46)
203075 hs
got really close to maxing this but i hit the drone near the exit one frame too early...
anyway, finally got a half decent agd run subbed =)
Edit:
159-4 sr (with an innovation)
113618 sr
203119 sr and hs
Postby xaelar » 2010.07.22 (17:49)
Took 203075 ;D
+ 113618 sr
Postby ska » 2010.07.22 (17:50)
ok speed 203125
come on irc more you lurker ;) nice run... is 203075 almost maxed?? one more frame or so?
EDIT: 203169 hs
Postby Raif » 2010.07.30 (18:32)
175133 speed. I don't have a good run or anything just wanted to show the innov I found.
Hint: You just need to hold the last jump for 7 frames to get through.
Postby Izzy » 2010.07.31 (00:43)
mohamedraif wrote:163-1 speed 0th by 8 frames with Dawiki's accidental innov. 36 should be possible (Edit: Ok, maybe not.)
I still can't get that. Do you hold nothing in the first frame?
Postby Raif » 2010.07.31 (03:00)
Yeah.
Edit: 98805 speed, beat the 0th by about 200 frames :D
Postby ska » 2010.07.31 (12:30)
10002 hs/sr
Postby natrues peril » 2010.08.01 (16:21)
203519
by nicnac
Postby vankusss » 2010.08.02 (16:47)
203558 hs=sr
warning: that run is intense
Postby 999_Springs » 2010.08.02 (17:27)
Taken by 1957 frames.
Postby vankusss » 2010.08.04 (21:05)
189-4 hs
Postby natrues peril » 2010.08.05 (13:40)
125-1
someone get that last piece of gold, its really bugging me..
edit: nvm
also easily improvable, you can get the 2 peices of gold from the left of the exit switch as u hit the switch and you can double jump the 1 tiles in the corners
by nicnac
Postby ska » 2010.08.06 (05:44)
took 189-1 hs, 12345 hs
Edit: 203823, 133797 both hs.
Re-Edit: 203913 hs is also a pretty decent run.
Postby Raif » 2010.08.10 (14:34)
bwj off a normal door:
Jumping off a normal door:
I think these are only possible cause of the gold.
Postby Hendor » 2010.08.10 (19:22)
I think my 44-1 hs route is faster if you were to clean it up and add in a corner jump or two. I actually made that run about a year ago, but forgot about it.
Postby Raif » 2010.08.10 (21:07)
Hendor wrote:I think my 44-1 hs route is faster if you were to clean it up and add in a corner jump or two. I actually made that run about a year ago, but forgot about it.
Yeah, it looks faster, I bet you can save more than .500 with that route (Probably more).
(I was bored and had some free time :P)
Postby amomentlikethis » 2010.08.14 (13:23)
203181
203228
203666
203903
204061
204062
204069
204072
204073
204086
Hi.
Postby ska » 2010.08.14 (17:24)
1337 hs/sr
Edit: also took 204072 hs the other day, 99% it's maxed.
took 204102 hs from van too.
Postby 999_Springs » 2010.08.15 (19:27)
Strange bug I found. danield9tqh's 45-1 highscore works if you view it on NReality v6d4 but it's broken if you watch it on N v1.4. Anything to explain this?
Postby Raif » 2010.08.15 (19:34)
999_Springs wrote:Strange bug I found. danield9tqh's 45-2 highscore works if you view it on NReality v6d4 but it's broken if you watch it on N v1.4. Anything to explain this?
The demo works perfectly on v6d4, v6e and v1.4. Also if you are using the replay box to view the demo make sure you don't leave an empty line at the bottom without putting a # at the end of the demo.
Postby 999_Springs » 2010.08.15 (19:48)
I'm viewing it on v1.4 straight from the highscores menu.
Edit: OOPS I MEANT 45-1 SORRY!!!
Postby Raif » 2010.08.15 (19:52)
999_Springs wrote:I'm viewing it on v1.4 straight from the highscores menu.
O_o I have absolutely no idea why the gauss shot him.
Users browsing this forum: Google [Bot] and 17 guests
