Post a Run!
Took it using hs mode by a solitary frame... for some reason, it didn't submit to speedrun more :/xaelar wrote:Nonono, I'm just lurking.
162387 sr
got really close to maxing this but i hit the drone near the exit one frame too early...
anyway, finally got a half decent agd run subbed =)
Edit:
159-4 sr (with an innovation)
113618 sr
203119 sr and hs
+ 113618 sr
come on irc more you lurker ;) nice run... is 203075 almost maxed?? one more frame or so?
EDIT: 203169 hs
Hint: You just need to hold the last jump for 7 frames to get through.
I still can't get that. Do you hold nothing in the first frame?mohamedraif wrote:163-1 speed 0th by 8 frames with Dawiki's accidental innov. 36 should be possible (Edit: Ok, maybe not.)
Yeah.Izzy wrote:I still can't get that. Do you hold nothing in the first frame?mohamedraif wrote:163-1 speed 0th by 8 frames with Dawiki's accidental innov. 36 should be possible (Edit: Ok, maybe not.)
Edit: 98805 speed, beat the 0th by about 200 frames :D
by nicnac
warning: that run is intense
someone get that last piece of gold, its really bugging me..
edit: nvm
also easily improvable, you can get the 2 peices of gold from the left of the exit switch as u hit the switch and you can double jump the 1 tiles in the corners
by nicnac
Edit: 203823, 133797 both hs.
Re-Edit: 203913 hs is also a pretty decent run.
Jumping off a normal door:
I think these are only possible cause of the gold.
- Legacy Elite
Yeah, it looks faster, I bet you can save more than .500 with that route (Probably more).Hendor wrote:I think my 44-1 hs route is faster if you were to clean it up and add in a corner jump or two. I actually made that run about a year ago, but forgot about it.
(I was bored and had some free time :P)
- MBTI Type: ESFP
203666
203903
204061
204062
204069
204072
204073
204086
Edit: also took 204072 hs the other day, 99% it's maxed.
took 204102 hs from van too.
The demo works perfectly on v6d4, v6e and v1.4. Also if you are using the replay box to view the demo make sure you don't leave an empty line at the bottom without putting a # at the end of the demo.999_Springs wrote:Strange bug I found. danield9tqh's 45-2 highscore works if you view it on NReality v6d4 but it's broken if you watch it on N v1.4. Anything to explain this?
Edit: OOPS I MEANT 45-1 SORRY!!!
O_o I have absolutely no idea why the gauss shot him.999_Springs wrote:I'm viewing it on v1.4 straight from the highscores menu.
Users browsing this forum: Google [Bot] and 22 guests
