MAC cant create maps
Tetris
NUMA Profile: http://www.nmaps.net/user/Furikabute
Postby Furikabute » 2010.09.29 (20:15)
Hi guys, i started playing numa since long time, and i reaaaaally loved to make my own maps, but now i have a macbook pro, and i just dont have the needed keys on the keyboard! for example if i try to go to objects editor, i need to press "enter" or "numpad o". i have tried with every single part of my keyboard but its not working... so i just want to know if there is any posibility to change the in-game keys or if there is any combination on the keyboard that would work.
Thx !!
Postby heatwave » 2010.09.29 (21:44)
use fn+n and fn+. for objects and tiles.
Sincerely,
A fellow Macbook Pro user
Tetris
Postby Furikabute » 2010.09.29 (22:48)
Mmmm
thanks to your idea i can go to the tile editor typing fn+erase, but i cant find the objects editor, and when i go in to the tile editor i need the home key for going back, so i can only close it and open again... pls! need more ideaaaas
thank you bythway
Postby heatwave » 2010.09.30 (00:30)
oh yeah, I forgot about the home key.
ok, once you press the "e" key to start editing, you can press "fn+erase" (or "fn+period") to open the tile editor. You should also be able to press "fn+m" to enter the object editor. To go back, you should be able to press "fn+left arrow" instead of the home key.
Let me know if that works.
Tetris
Postby Furikabute » 2010.09.30 (19:00)
the fn+left arrow worked perfect! and i can save and load the text doing the same, but with up and down arrows. but still got the problem with objects editor....
thx
Tetris
Postby Furikabute » 2010.10.14 (17:27)
i guess there is no solution...
Postby heatwave » 2010.10.15 (00:10)
I've never played n on a unibody macbook pro, so I can't do much more than tell you what works on my older macbook pro. Sorry.
Tetris
NUMA Profile: http://nmaps.net/user/drayr
Postby Drayr » 2011.01.25 (21:42)
Okay, I had the same problem when I first got my Macbook a year or so back. The solution I found lies in this application:
http://pqrs.org/macosx/keyremap4macbook/
It's called KeyRemap4Macbook. Once installed (you will have to restart), you will be able to find it as a System Preference pane, and it should also appear in your menu bar. It allows you to remap a certain key (can't remember which one) to Insert. There are a lot of options, so you may have to search for that specific one. Hope this helped.
Triforce
Postby stead10 » 2011.03.12 (21:28)
I've tried using that program to re-map the keys and it didn't work. I find it stupid that on the main screen for the download of the game they specifically have a mac version yet they've overlooked the fact that macs can't edit maps which used to be 1 of my favourite things about the game and the reason i re-downloaded this game that i played years ago on a windows. If anyone knows a way for it to work please let me know I really wanna create my own levels.
Postby Vyacheslav » 2011.03.13 (04:22)
M&R most likely tested the game when the Mac keyboards were full sized and not the miniature metal flat ones they make now.
NUMA Profile: http://nmaps.net/user/apakenua
Postby Apakenua » 2011.03.25 (02:40)
Do as I have done and get a right keypad that plugges in with a usb.
What's a signature?
Postby fingersonthefrets » 2011.05.12 (16:59)
Drayr wrote:Okay, I had the same problem when I first got my Macbook a year or so back. The solution I found lies in this application:
egh I've looked through 3 times and I can't see it. This is so frustrating haha
EDIT: I'm using a macbook pro with this keyboard Image
I think the operating system is 10.5.4. anyone got any solutions?
fn + delete works for tiles, but nothing seems to work for objects (including the ones i've been seeing recommended: fn+., fn+enter, fn+0, fn+m)
NUMA Profile: http://nmaps.net/user/sayko
Postby sayko » 2011.05.16 (12:37)
Maybe a screen keyboard with PC Keyboard layout?
Postby fingersonthefrets » 2011.05.17 (01:23)
sayko wrote:Maybe a screen keyboard with PC Keyboard layout?
gonna try that now, thanks for the tip
NUMA Profile: http://nmaps.net/user/lukesv
Postby lukesv » 2011.05.17 (09:02)
I have a Mac just like that, I use a external keyboard from a old desktop computer.
Postby fingersonthefrets » 2011.05.17 (10:34)
mm, I want to be bringing mine to uni and things though, so another keyboard would make things difficult.
Ps. by "gonna try that now" it seems i meant "gonna try that in a while"
within the next day I'd say though
edit: onscreen keyboards for mac either cost (and i'm not sure they have insert function or not), or in the case of the included onscreen one doesn't have insert. bleh.
Postby sayko » 2011.05.18 (09:54)
I'm not sure if it would solve your problem, but did you try the "Help" key (or Home) in Ned? I've heard that key does same work with Insert key.
Postby fingersonthefrets » 2011.05.20 (08:41)
sayko wrote:I'm not sure if it would solve your problem, but did you try the "Help" key (or Home) in Ned? I've heard that key does same work with Insert key.
It would probably work, but the specific macbook pro I have doesn't have a home or help key :/ thanks for the suggestion though
Postby fingersonthefrets » 2011.05.31 (08:52)
Naroquatt wrote:
Okay, I had the same problem when I first got my Macbook a year or so back. The solution I found lies in this application:http://pqrs.org/macosx/keyremap4macbook/It's called KeyRemap4Macbook. Once installed (you will have to restart), you will be able to find it as a System Preference pane, and it should also appear in your menu bar. It allows you to remap a certain key (can't remember which one) to Insert. There are a lot of options, so you may have to search for that specific one. Hope this helped.
fingersonthefrets wrote:egh I've looked through 3 times and I can't see it. This is so frustrating haha
Postby im_bad_at_n » 2011.07.24 (05:29)
When I downloaded it from the site, an orange open box appeared (it's icon) in my downloads folder. I had to click on it and run that box in order to be able to install it, then restart it. Simply downloading that box will not work. Also I didn't have to do the the system preference pane: fn + m worked after installing it. :3
In Order:
last updated : 04/29/11
NUMA Profile: http://nmaps.net/user/furry_ant
Postby maya » 2011.07.24 (12:44)
i have exactly the same problem, fn+backspace (=delete) works fine for tiles but no combination will work for object editor, seen as this model doesn't have a home or help key ;-;
i'll try the keyboard remapper linked earlier on
edit: restarted after installing the keyboard remapper and fn+m works for objects now :3
Tetris
Postby Drayr » 2011.10.28 (21:28)
I sort of left out some steps :P but it works, doesn't it?
Users browsing this forum: No registered users and 58 guests
